Question about Kenmore Washing Machines
Have a Kenmore front loader. Start cycle 30 min. Washes & drains. Fills back up to rinse and won't drain water after rinse cycle.
Model number 402.49032010
jsrock516
  • 5911 Answers
SOURCE: kenmore washer won't drain
The symptoms you describe are often caused by a lid switch malfunction. It may be loose or not making good contact. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair if you wish to accomplish this on your own. A replacement switch usually cost between $25 and $35. I hope this helps you. Let me know if you require further assistance.
Posted on Aug 17, 2008
  • 36 Answers
SOURCE: Incomplete wash cycle.
It sounds as if you have something acting as a flap causing the restriction. You should take the hose that leads from the tub to the pump off and see if there is anything just inside the tub. I have noticed that alot times you could have a coin that blocks the opening. You may have to remove the inner tub to remove anything in there
Posted on Jan 02, 2009
  • 99 Answers
SOURCE: WHirlpool Waser model LSR8133HQ0 - tries to fill for rinse cycle
hellow my name is joyce and It sounds like you have a issue with your cut off valve that controls the water flow to your machine in between cycles, this is controled by your timer switch you may want to call technichian to repair. sounds like the only problem you have with the timer is on the rinse cycle not the wash cycle, but it defently needs to be fixed. if I can help you find a repair person please let me know.
thanks you and let me know if I can further assist you.
joyce
Posted on Feb 06, 2009
  • 4 Answers
SOURCE: washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Posted on Mar 20, 2010
jsrock516
  • 5911 Answers
SOURCE: Washing machine keeps draining during rinse
You may be experiencing a condition known as "siphoning". This is caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain as it tries to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Posted on Apr 08, 2010
How do I find the model number for my Singer sewing machine? The model number is not on the machine. The serial number is B684078. It was made in the early 1900's.
  1. 1990 - present. For sewing machines manufactured since about 1990, look for the model number on the handwheel side of the machine near the on/off switch or the electric cord receptacle.
  2. 1970 - 1989. You will find the model number on the front panel of machines manufactured in the 1970s and 1980s.
  3. 1960 - 1970. ...
  4. Before 1960.
Machine Model Numbers ' Singer Sewing
How do find the model number for my Singer sewing machine Google Search
Nov 01, 2017 | Singer Sewing Machines
I have a Winchester pump with no model number.
Identify it in the images here
https://www.google.ca/search?q=winchester+pump+shotguns&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1438&bih=677&source=lnms&tbm=isch&sa=X&sqi=2&ved=0ahUKEwjdmoOSoPDQAhVB5GMKHfAkC0kQ_AUIBigB&dpr=0.95
[PDF]Winchester Firearms Manufacturing Dates by Serial Number www.winchesterguns.com/.../winchester.../serial-number.../Winchester-Manufacture-...
  1. Cached
shotguns are not complete or why they are not always verifiable. A few ... totally accurate database of serial numbers from 1866 forward that we are aware of.
What year was my Winchester manufactured Serial Number Reference
www.winchesterguns.com/support/faq/date-your-firearm.html
  1. Cached
  2. Similar
Winchester Firearms Manufacturing Dates by Serial Number and Year ... about why the historic serial number records for Winchester rifles and shotguns are not ...
Winchester Dates of Manufacture
oldguns.net/sn_php/winmods.htm
  1. Cached
  2. Similar
WINCHESTER DATES OF MANUFACTURE ... Model 24 · Model 25 · Model 36 · Model 37 & 37- A · Model 40 · Model 41 · Model 42 · Model 50 · Model 59 Shotgun.
Model 1897 - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=win1897.dat
  1. Cached
  2. Similar
... DATES OF MANUFACTURE. Winchester Model 1897: Covering numbers: 31608 - 1024700. Please enter a serial number and click the submit button.
McHenry Sportsmen's Club - Winchester Model 12 Serial Numbers
www.mchenry-sc.org/Engineering/Model_12.htm
  1. Cached
  2. Similar
Dec 31, 2005 - Winchester Model 12 Serial Numbers. The table below represents the serial numbers and production dates of. Winchester Model 12 Shotguns: ...
Winchester Serial Numbers - ProofHouse.com
www.proofhouse.com/win/index.html
  1. Cached
  2. Similar
Jump to Shotguns - Shotguns top. Model 1879 · Model 1887 · Model 1893 ... Ranger Pump · Ranger Semi-Auto · Shotgun-Rifle Combo · Super X Model 1. winchester pump shotguns Google Search
Dec 13, 2016 | The Optics
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
Serial #3506979
any one of these sites will help you find the serial number and date of manufacturer. The forums will help with values, or the Blue Book of Gun Values.
  • Model 1894 (Mod 94 ) - Winchester Dates of Manufacture www.oldguns.net/sn_php/windateslookup.php?file=win1894.dat Winchester Model 1894 (Mod 94): Covering numbers: 1 - 5103249. Please enter a serial number and click the submit button.
  • Winchester Model 1894/94 Dates of Manufacture www.savage99.com/winchester1894_dates.htm Dates of Manufacture* for: Winchester Model 1894/94. Winchester Lever Action Repeating Firearms, Vol. 3, The Models of 1894 and 1895 by Arthur Pirkle.
  • Winchester Model 94 Serial Numbers - Gun Collections Online guncollectionsonline.com/winchestermodel94.htm 41 rows · Gun Collections Online. Specialists in Marketing Your Gun Collections ...
  • Related searches for winchester model 94 serial numbers
  • Serial Number info for Winchester Model 94 - The Firing ... https://thefiringline.com/forums/showthread.php?t=322230
    • 109 POSTS
    • FIRST POST: 2008-11-27
    2012-08-04 · I have a Winchester model 94 serial # 2775xx3. The chart in this thread for serial # id show a lapse between 64 and 65 models. The 65 models all start with ...
  • How can you find the age of a Winchester Model 94 - Answers www.answers.com > ... > Firearms > Winchester Firearms What is the age and value of a Winchester Model 94 serial number 3910875? ... What is the age of a Winchester model 94 serial no 1929746?
  • Winchester Model 94 Identification - 8's Garage 8sgarage.com/Armory/Rifle/Data/Manuals/Winchester 94 Identification... · PDF file Winchester Model 94 Identification PRE-64: The Winchester model 1894 was introduced in October of 1894 apparently starting at serial number 1.
  • What Is The Year And Value Of My Winchester Model 94 ... www.gunvaluesboard.com/what-is-the-year-and-value-of-my-winchester... What is the year and value of my Winchester model 94 serial number 5271797?
  • Value Of A Model 94 Winchester Rifle 30-30 Serial Number ... www.gunvaluesboard.com/value-of-a-model-94-winchester-rifle-30-30... also have 3 winchester model 94 32 specials all are in fair condition stocks are worn and bluing has light scratches serial numbers are 3133157...2822367...2889678 ...
  • Model 1894 ' Winchester Collector winchestercollector.org/models/model-1894 ... the Model 1894 became the first Winchester ... The 1,000,000th Model 94 was presented ... from serial number 1 thru 353999. The Winchester Model ...
  • Jul 19, 2016 | Winchester Model 94 Short Rifle .30-30 20...
    Looking for what year my Winchester model 94 was manufactured in. The serial number is 2374881
    Here you go. These sites will help you.
    • 108 POSTS
    2012-08-04 · Serial Number info for Winchester Model 94 User Name: ... Is there a place on line to research and find dates and serial numbers on The Winchester Model 94 ...
  • Winchester Model 1894/94 Dates of Manufacture www.savage99.com/winchester1894_dates.htm Winchester Model 1894/94. Winchester Lever Action Repeating Firearms, ... Our database contains values of serial numbers through 5103248 which ended the year ...
  • Model 1894 (Mod 94) - Winchester Dates of Manufacture www.oldguns.net/sn_php/windateslookup.php?file=win1894.dat WINCHESTER DATES OF MANUFACTURE. Winchester Model 1894 (Mod 94): ... Please enter a serial number and click the submit button. ...
  • Winchester Model 94 Serial Numbers - Gun Collections Online guncollectionsonline.com/winchestermodel94.htm Winchester Model 94 Serial Numbers. In 1894 Production began with Serial Number 1 and the Winchester Model 94 Serial Numbers run more or less, ...
  • Winchester Model 94 Identification - 8's Garage 8sgarage.com/Armory/Rifle/Data/Manuals/Winchester 94 Identification... · PDF file Winchester Model 94 Identification ... The Winchester model 1894 was introduced in October of 1894 apparently starting at serial number 1.
  • winchester 1894 serial number decoder ' Jeremy blog fitubangscam.blog.com/2013/05/04/winchester-1894-serial-number-decoder Ladder sight CARBINE Winchester 1873 1892. Winchester Model 1894 - Wikipedia, the. Winchester 1894 Serial Number ' Gun. Winchester Model 94, winchester model 94 ...
  • Winchester Dates of Manufacture - OldGuns.net oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. ... (Mod 94) Model 1895 Model ... Model 59 Shotgun ...
  • How can you find the age of a Winchester Model 94 - Answers www.answers.com > ... > Firearms > Winchester Firearms How can you find the age of a Winchester Model 94? ... What is the age and value of a Winchester Model 94 serial number 3910875?
  • How do you find out if a Winchester Model 94 is pre-64 ... https://answers.yahoo.com/question/index?qid=20081128210042AA3vaql
    • RESOLVED
    • 14 POSTS
    • 13 TOTAL ANSWERS
    2008-11-28 · Best Answer: The serial number is the best bet 95s had grip safeties as late as my 1982 model Put the serial number in here and it will give you ...
  • Dates ' Winchester Collector winchestercollector.org/dates Serial Number. Get Manufacturing Date . Manufactured Date. ... History of Winchester; Winchester Model Information; When Was Your Winchester Made? Winchester ...
  • http://www.bing.com/images/search?q=winchester+model+94+serial+number+decoder&FORM=HDRSC2
    May 22, 2016 | Optics
    Top draw is stuck on rinse / can't move push button to go on anything else
    make this tests and fix it. God bless you
    Dispenser Lever
    If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
    Enter your model number to see parts for your dishwasher.
    Help me find my model number
    Detergent Dispenser Cover
    If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
    Wax Motor Actuator
    If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
    Detergent Container
    If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
    Dispenser Lid
    If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
    Detergent Dispenser
    If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
    Dispenser Door Spring
    If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
    Dispenser Latch
    If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
    Dispenser Door Pin
    If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
    Dispenser Actuator
    If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
    Dispenser
    If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
    Wax Motor
    There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
    Bi-Metal
    If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
    Dispenser Slide
    If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
    Dispenser Repair Kit
    If the dispenser is broken this dispenser kit may need to be replaced.
    Main Control Board
    The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
    Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
    How much salt do I put in ,,, and why won't it
    follow this steps and fix it. God bless you
    Dispenser Lever
    Wax Motor Actuator
    Detergent Container
    Dispenser Lid
    Detergent Dispenser
    Dispenser Latch
    Dispenser Door Pin
    Dispenser Actuator
    Dispenser
    Wax Motor
    Bi-Metal
    Dispenser Slide
    Main Control Board
    Jul 08, 2013 | Dishwashers
    Roper washing machine fills and washes, but when it gets to the spin cycle there is no sound and it won,t spin.
    Hi m3gamma1,
    Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
    ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
    If this does not help, the drain pump may be faulty.
    Kind Regards
    JEDEMEYER1
    * If this solution helped you, please rate it
    Sep 05, 2011 | Washing Machines
    My Kenmore high efficiency 3.5 cu. ft. front loader washer is acting funny. I start the normal cycle. It fills up with water. Washes., rinses, drains, then fills up slowly, to a point and then I get the...
    If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
    If this has assisted you please consider a 4 thumbs up for the rating.
    Thanks and good luck,
    John C
    Jul 01, 2011 | Kenmore Front Load Washer
    Sony Lens Cap for A100
    The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
    55mm Front Lens Cap - G Series logo
    Model Number: ALC-F55G
    72mm Front Lens Cap - Carl Zeiss logo
    Model Number: ALC-F72Z
    77mm Front Lens Cap - Carl Zeiss logo
    Model Number: ALC-F77Z
    77mm Front Lens Cap - G Series logo
    Model Number: ALC-F77G
    α Rear Lens Cap
    Model Number: ALC-R55
    62mm Front Lens Cap - Carl Zeiss logo
    Model Number: ALC-F62Z
    49mm Front Lens Cap - Sony α logo
    Model Number: ALC-F49A
    62mm Front Lens Cap - Sony α logo
    Model Number: ALC-F62A
    62mm Front Lens Cap - G Series logo
    Model Number: ALC-F62G
    67mm Front Lens Cap - Sony α logo
    Model Number: ALC-F67A
    55mm Front Lens Cap - Sony α logo
    Model Number: ALC-F55A
    72mm Front Lens Cap - Sony α logo
    Model Number: ALC-F72A
    77mm Front Lens Cap - Sony α logo
    Model Number: ALC-F77A
    Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
    Thanks for using Fixya.
    We wish you a happy holiday season..
    Dec 21, 2010 | Sony Lens Cap for A100
    Washing Machines Logo
    26 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
