Question about Epson Stylus Photo RX700 All-In-One InkJet Printer
How do you reset the counter on an Epson Stylus RX700 without changing the ink pads?
4 Suggested Answers
SOURCE: Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Posted on Mar 26, 2009
websnail
  • 419 Answers
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
Posted on May 12, 2009
SOURCE: RX700 Ink drip reset counter?
which buttons do I press when turning on my RX 700 after changing the ink pads which will reset ink drip counter? Thanks
Posted on Mar 10, 2010
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
My printer is epson tx650.the problomis that it say 'the printer's ink pad is at the end of their service life'. please assist me with the solution.says RAKITA
Sadly the other solution is the usual corporate party line regarding "Parts at the end of their service life" and is intended to encourage printer owners to purchase new printers.
The reality is quite different.. Epson printer are generally capable of upwards of 3 to 10 years or service with minimal care unless the printer is being hammered 24/7 with almost constant printing, which is very unlikely.
Waste pads however are an achilles heel that do need some form of action to either replace or work-around to resolve.
The options available are either:
1. Go to a service centre where it is indeed prohibitively expensive to have the printer disassembled to replace the pads and have the waste counter reset.
OR..
2. Get an external waste ink kit to redirect any waste ink to an external tank (it doesn't remove the current pad contents) and obtain the relevant tool (either a compatible AdjProg service program) or WICReset tool with a key (one needed per reset) so you can reset the printers internal waste ink counter.
The cost of the latter option is around 20-25(GPB) total (including shipping) so compared to the tooth sucking Epson Customer "Care" option it's not exactly rocket science as to which is more cost effective.
Please ignore the rubbish about other parts being near the end of their service life... About the only other thing to note is that the printer gears might need a little grease but beyond that and flimsy plastic paper guides the printer can easily last 5 years with a little care.
Mar 05, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
Screen showed message that "parts
The message that you received indicates the ink pad absorbers are full and prevents the printer from running because unchecked it would leak ink everywhere including outside of the unit. To fix this you need to replace the pads with new ones and reset the counters to let machine know you have changed the pads. On top of that you must download a utility program for your model that will allow you to set up the counters so the printer will run. I strongly recommend replacing your printer especially when it is a refurbished item, even Epson feels it is better to replace.
Jan 08, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
End of service life error message epson inkjet printer RX700
This refers to the internal counter, actually located in the software on the computer determing that your waste ink pads are likely saturated and need replacement. You can download software from either Epson at http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp or at http://www.ssclg.com/download/sscserve.exe. Both of these software packages will allow resetting the counter. However one should either take the printer in to an authorized Epson or independent printer service company or if comfortable with messing around inside computers and peripherals, one can check the waste ink pad(s). On the RX700 there is a small access panel, on the back of the unit, on the left hand side when facing the back of the RX700. It is held in place with a Phillips head screw and small plastic latch tab on its bottom side. The pad material is clearly visible from here, with a pair of clear plastic waste ink tubes directed down into this waste ink receptacle. If this is saturated, wet and discolored, it should be replaced, before resetting the counter. Not doing so risks the excess waste ink overflowing and making a mess and possibly even shorting out some of the circuitry.
Sep 18, 2010 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson stylus photo rx685 the problem is, waste ink pad in the printer is saturated, I have removed all the wested ink in the priter, but is the same problem that am experiencing. Please help me solve this...
go to www.octoinkjet.co.uk/wib/ to download one of their inkjet ink pad reset utilities. It may just solve your problem. I couldn't clean or replace the ink pads on my epson RX700, so I bought their special adaptor kit. It solved the problem for me. If you already have cleaned the ink pads, maybe you can just download the reset utility. I hope it works for you.
Jul 07, 2010 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson RX700 printer, end of service life message
This usually means that the waste ink absorbers are full. If your printer is under warranty, you can get them dealt with and the counter reset at an Epson Customer Care center. If your printer is out of warranty, you should consider if it is worth the fix. You can get this done by Epson or an independent printer repair person. (They might sell the parts for a dyi job.)
Once that is done, you can get a reset utility from the following URL: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp . If you execute the reset without the pad replacement, you will get ink smearing on your documents after a while.
I hope this helps.
Jan 29, 2010 | Epson Stylus Photo RX700 All-In-One InkJet...
How to Solve Both Red Light Blinking Problem in Epson R230
Blinking alternately or not? If alternately, see status monitor. It may be end life service (waste ink pad full). Reset waste ink counter using Rx700 adjusment program. If not, it may be a general error.
Nov 12, 2009 | Epson Stylus Photo RX700 All-In-One InkJet...
Jun 02, 2009 | Epson Stylus Photo RX700 All-In-One InkJet...
Epsion stylus r230 series had got problem it refers that service
This is a standard problem for all Epsons sooner or later.
Your options are simple:
1. Take it to an official Epson service center and pay rather a lot of money to have the waste ink pads changed
or
2. Locate the SSC utility here:
http://www.ssclg.com/epsone.shtml
.. install and then follow the instructions for resetting and clearing the protection counter settings.
You will still need to decide what to do about redirecting your waste ink but there are plenty of resources for that if you look around google using the keywords: "epson waste ink kit"
Whatever you do, don't ignore the waste ink as it will overflow eventually.
Hope that helps.
Feb 20, 2009 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson Rx500 waste ink collection pads cleaning/renewal......can this be done DIY If so can you advise with detailed method etc Regards Tibbs
The same instructions available all over the internet for the R300 should suffice for the RX500...
In terms of resetting the waste ink counter, the SSC utility will provide the necessary compatibility as well...
Apr 13, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson Stylus Photo RX700 All-In-One InkJet Printer Logo
48 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
