Question about IBM Infoprint 1585n Laser Printer
Howto reset the nvram of ibm infoprint 1585? - IBM Infoprint 1585n Laser Printer
SOURCE: resetting IBM infoprint 1552 maintenance counter
Go Here: it's a PDF file which explains how to reset the printer's maintenance count.
http://www.marketpoint.com/files/pdfs/mk_ibm_1532.pdf
Posted on May 15, 2008
  • 4 Answers
SOURCE: want to reset my IBM Infoprint 1412
• Press and hold Cancel until all of the lights come on to reset the printer.
Posted on Jul 15, 2009
  • 32 Answers
SOURCE: IBM Infoprint 1532
There is probably a small piece of paper in the back of the printer in the fuser. Shutdown the printer and wait a few minutes as this part is hot. You may need to remove a few screws to take off the back cover and check inside the fuser.
Posted on Jul 24, 2009
  • 32 Answers
SOURCE: IBM infoprinter operating manual
You should be able to find it in the support section of this page: http://www-07.ibm.com/printers/sg/products/workgrp_laser/info1125.html
LHeruska
  • 94 Answers
SOURCE: Ibm infoprint reseter
Here is a procedure I would like you to do to reset the light:
1-Power the printer on and get it to the Ready state (i.e. the light on the operator panel is on)
2-With the printer on and in the Ready state, open the front cover
3-Press and hold the Cancel button until all of the lights begin flashing up and down.
4-Release the Cancel button and close the door. The photoconductor count should now be reset
To confirm that the photoconductor page count has been reset, it is recommended that you print a
menu settings page and check the photoconductor level. Do the following:
1.With the printer at the Ready status, press the Continue button once. The Ready
light will begin flashing and one or two pages will print out.
2. Look for a section labeled Cartridge Information and locate the word Photoconductor
under this heading.
3. Confirm that the photoconductor level reading is either OK or close to 100%.
4. If the reading is low, try printing 10 - 20 pages.
5. Print the menu settings page(s) again.
6. Confirm that the photoconductor level reading is OK or close to 100%.
7. If the photoconductor reading is still low, there is a second, more detailed, procedure you
can perform to reset the count.
8. If the reading is still low after both procedures have been attempted, the printer may require service
Posted on Feb 05, 2010
Tip
IBM Infoprint 1332
I want Dwn load driver IBM Infoprint 1332
on Aug 04, 2008 | IBM Infoprint 1332 Laser Printer
I just installed a new photoconductor into my IBM InfoPrint 1622 and I need to reset the page counter and the instructions have been lost. I need instructions on how to reset the counter.
IBM infoprint 1622 - Photoconductor
When replacing a photoconductor on an IBM infoprint 1622 you must follow these following steps to reset the counter.
1. Open up the printer front cover and Install the photoconductor. 2. Close the cover. 3. Turn the printer off. Press and hold the 'Select' and 'Return' buttons, then turn on the printer. 'Config Menu' should appear on the display. 4. Press 'Menu' until 'Reset PC Cnt' appears. Press 'Select'. 5. Press 'Menu' until 'Exit Config Menu' appears. Press 'Select'. 6. Open the front cover. 7. Press and hold the red 'Cancel' button with the triangle on it for 3 seconds. All the lights should then cycle. 8. Close the front cover. The Photoconductor Maintenance counter is now reset.
Feb 21, 2011 | IBM Infoprint 1622 Laser Printer
Need to reset the counter
First, you enter the config menu by powering off the printer. Hold the middle and right arrow buttons and turn the printer back one. Continue to hold until you see Performing self test. Then release. You will then see config menu. Scroll down to reset maintenance count and press select. It will reset and bring you back. Then restart the printer.
Jul 02, 2009 | IBM Infoprint 1585n Laser Printer
Want to reset my IBM Infoprint 1412
Mar 12, 2009 | IBM Infoprint 1412n Laser Printer
IBM infoprint 932 service printhead error
go on line and type in
ibm infoprint 1352 laser printer error 932
enter
or
ibm 1352 infoprine error message 932
rod
Feb 06, 2009 | IBM Infoprint 1352 Laser Printer
Factory reset for IBM Infoprint 1412
open toner door, press and hold stop button whilst powering on printer. or Telnet into printer i.e telnet <ip addr> then use command 'set http on' then 'save'
Jul 13, 2008 | IBM Infoprint 1412 Laser Printer
Print Cartridge
Unfortunatly, no. This is the compatibility list for that part number: IBM2.gif InfoPrint 1352 / 1352n / 1372 / 1372n Laser Toner Printers
May 14, 2008 | IBM Infoprint 1332 Laser Printer
Resetting IBM infoprint 1552 maintenance counter
Apr 22, 2008 | IBM Infoprint 1552n Printer
IBM infoprint 1312 toner light
open the toner door then press and hold down the stop button, whilst holding this down switch on printer and hopfully this will reset the page count, i think.
Jan 23, 2008 | IBM Infoprint 1312 Laser Printer
IBM Infoprint 1585n Laser Printer Logo
90 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
