Laptop overheating my laptop is geting heated up after a while. It is running very slow after that . can you please tell me what the problem could be and how do i fix it. My friend told me may be some dust has been collected inside. Can someone please give me an expert advice.
Ya overheating of a laptop is but normal as made by the maufacturer due to absence of power fans to cool down the heat from the power supply so for that reason just take it normal or else it could be due to other factors like memory being too low.for the idea of being too slow you will have to meet a technician to increase the capacity of your memory
Posted on Jun 22, 2009
Frozen Laptop
If it is not overheating, try running the free version of Advanced System Care.
Speed Up Slow Computer Keep PC and Internet Secure Freeware Download IObit
Sep 11, 2015 | Toshiba Computers & Internet
My laptop is geting automatically close after running for long hour
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 05, 2013 | Acer Aspire 5742 Notebook
HP Pavilion dv2610us overheating causing laptop to slow down?Is this because my laptop battery died
Overheating is not caused by dead battery. The most common cause of it is a faulty system fan. If the fan has mechanical defect or has degraded performance due to accumulated dusts and particles around it, it will cause overheating. Overheating can cause system to slow down at first, then if you keep using it without minding the overheating problem, your laptop can freeze and shut down on its own.
Here are some tips for overheating issue:
- Use canned air to blow out dust and particles from the system fan.
- Do not operate the laptop in areas where the temperature is high, it will worsen the problem.
- Replace the fan if you notice that it is not working properly as before cause it will further damage the laptop.
Hope this helps.
Jul 09, 2011 | HP Pavilion dv2610us Notebook
I have heat issue in my laptop. Laptop is getting heated so soon and video is getting very slow. I have nVidia graphic card. Kindly help me out of it.
So i suggest you that you can buy a new cooling pad for your laptop as well as check whether the zink paste is available between the processor and the heat transferring metal for more info reply me
Jun 18, 2011 | Computers & Internet
Hello, i have a Acer Aspire 5100 Laptop which i bought in 2007. Recently i have started having problems with HD-Ready videos (720p). before when i use-to play 720p videos on my laptop it use to run...
As you say the laptop handles the video well in the beginning, then when it runs for a few minutes it has trouble rendering the video in sync with the audio.
The reason for this problem is that 720p videos need the Graphics card in the laptop to work hard, this process generates heat and this heat needs to be removed from the laptop or the whole system does what's known as throttle down.
It slows down to reduce the heat it produces, thus preventing damage to the system.
The solution to this problem is to clean as much dust out of the laptop computer as possible, use a vacuum cleaner. Turn the laptop off and remove the battery. Clean the vents, it is a good idea to raise the back underside of the laptop with a pencil or the like. Some-thing that will raise the laptop off the work surface without obstructing the vents on the underside of the laptop. By raising the laptop it will allow for greater airflow through the laptop, therefore reducing the operating temperature of the laptop therefore making it more efficient and responsive.
Your laptop shuts itself down, this confirms that it is overheating. It does this so it does not damage itself.
If it still overheats then you will need to contact a computer technician to give it a good through cleaning. To clean the dust between the heatsink fins. Possibly increase the fan speed or replace the fan.
Take care!
damnor01
Jun 10, 2011 | Acer Aspire 5100 Notebook
The above as over heated and seems to fail after about ten minutes of being on this is an intergrated card can it be fixed without replacing the motherboard it is in an asus laptop.
I suspect that your cooling fan has stopped working or the sealing mating between the fan surface and the CPU is not intact. These fans quit working because dirt and grime gets into the fan shaft and friction slows the fan . also if the fan gets accidentaly moved on the CPU, then this breaks the heat transfer tape between the CPU. This over heating causes the CPU to fail. Open the machine and observe if the fan is running correctly.
Apr 14, 2011 | Computers & Internet
Dell Studio 15 runs slow... My Dell studio 1558 takes long time to boot & processing is also slow,i have tried disk cleanup and defragment hard disk but nothing worked,it has the following...
sound like your core is geting hot is your fan working is so try cleaning it with small birst of air plus check your bios settings..if not overheating try factory settings...
Apr 14, 2011 | Dell Studio 1558 Notebook
Why does my 2004 Suzuki Intruder LC 1500 over heat if I go slow?
Most big bikes with air cooler fins have problem on overheating when it idles, running slow, and not running.
Better check your fan motor, it might be not running. Check also the oil cooler.
Tell us more after you have check on those, and we'll be happy to guide you to fix it!
Dec 07, 2010 | 2004 Suzuki VL 125 Intruder LC
Asprie 3690 acts like it overheats, has no battery life unless plugged in, going to order a new one. but runs really slow on start up and shut down and through out programs. Can hear fan running, then...
The overheating is causing this. Still, if you think that battery is doing that, take off your battery pack and turn it on with the adapter only.
Overheating is a very common problem with notebooks, To solve the overheating problem you will have to clean the heat sink and the fans of the laptop.
If you need assistance on how to clean the fan and the heat sink, please comment and I will be there to help you out.
Apr 11, 2010 | Acer Aspire 3690 Notebook
Overheating
Its pretty easy to tell when your laptop is overheating. Youll have those tell-tale red marks on your legs from where the hot bottom of the laptop has been resting against your legs.
Fortunately, most laptops will automatically shut down if they are over heating to prevent any further damage to hardware like hard drives and motherboards.
If you would like to know the running temperature of your laptop, download this little utility.
Hope this helps,
TJ
Dec 15, 2008 | Toshiba Satellite A35-S1592 Notebook
Computers & Internet Logo
203 people viewed this question
Alun Cox
David Payne
David Payne
