Question about Huawei M835 MetroPcs Cdma
How do I reset my DSC 3G3070 dialer - Huawei M835 MetroPcs Cdma
Gsm have two blinks,is this problem with sim card?
Your problem is that the GSM 3055 is obsolete. This is a 2G communicator and cell towers in your area no longer support this device. Same with GSM 3060. You will need GSM 3G3070 for communications or the GSM 3G2060R interactive unit for use with smart phones.
HSPA 3G Universal Cellular Alarm Communicator
HSPA Cellular Alarm Communicator PowerSeries
Mar 05, 2014 | DSC Gsm Radio Universal Wireless...
Tip
How To Reset Your Sony Ericsson Vivaz
<b>Factory Reset</b><br />This will delete all user data.<br /> <br />Soft reset to delete user data, such as contacts, messages, and downloaded games:<br /> <ol> <li>Tap <b>Dialer</b> and enter <b>*#7780#</b>.</li> <li>Tap <b>Yes</b> to restore all original phone settings.</li> <li>Enter the lock code (0000 by default) and tap <b>OK</b>.</li> <li>The phone restarts.</li></ol> Hard reset to delete user data and all settings:<br /> <ol> <li>Tap <b>Dialer</b> and enter <b>*#7370#</b>.</li> <li>Tap <b>Yes</b> to restore all original phone settings.</li> <li>Enter the lock code (0000 by default) and tap <b>OK</b>.</li> <li>The phone restarts.</li></ol>
on Feb 15, 2011 | Sony Ericsson Vivaz Cell Phone
Tip
Secret codes for andriod Phone's Samsung galaxy.
<span>Every phone comes equipped with a secret codes where technician can easily access its internal settings and run testing modules. These codes or secret access are usually not specified in the phone manual that comes with it. Here are a few secret codes that all Android mobile phones users should know, especially samsung users.</span> <span><br /></span> <span><span> <p><b>Accessing Phone Info</b><br />To access the internal Phone Information, Battery Information and History, as well as Usage Statistics, open up your dialer and press *#*#4636#*#*. From here, you can find out additional phone information and make the necessary adjustment (only if you know what to change, otherwise, don't simply amend these settings).<br /> <p><b>Reset All Data</b><br />To reset all phone data, press *#*#7780#*#* from your dialer.<br /> <p><b>Format phone</b><br />To format the entire phone, press *2767*3855#<br /> <p><b>Camera Info</b><br />To know more about your android phone camera firmware, press *#*#34971539#*#* from the dialer.<br /> <p><b>Shutdown / Button Action</b><br />Pressing *#*#7594#*#* will allow you to access the Shutdown setting.<br /> <p><b> (GPS)</b><br />Go to the phone dialer and press *#*#1472365#*#* and you will have access into LbsTestMode menu. From here, you may test and amend some default GPS configurations.<br /></span></span>
on Nov 23, 2010 | Cell Phones
Unable to open anything like messages, web browser and phone dialer
Turn the phone off and u have to do a hard reset on the phone and then it will work like its brand new like it did when you got it out of the box
Apr 09, 2013 | LG KM555 Cell Phone
How to factory reset
Do a Menu->Settings->Resets-> Factory Reset. If there's no such option on the Dialer keypad enter *2767*3855# (Note: it will erase all you data)
Jul 18, 2012 | LG Metro Pcs Optimus M 2gb Ms695 Phone...
There is a key combination to perform a hard reset for an LG KP500?
  1. Start by pressing Power button, device must be working to succeed this operation.
  2. Pressing Call key will open phone's Dialer.
  3. Type in this code into dialer. (Code: 1809#*500#)
  4. Factory reset operation needs to be confirmed by clicking green Call key.
hard reset for an LG KP500 Google Search
Jun 19, 2017 | LG KP500 Cell Phone
How do i get the dsc pk5501 to call my phone when an alarm is activated? Is it even possible? also how do i change the exit delay time and delay time upon entry? thanks
The alarm panel will only transmit data over a phone line. It is intended to call a central station. You could put your phone number in the panel, but all you would hear when you answered would be sounds similar to a fax machine. There are external voice dialers available that you could trigger from your panel that would call you with a recording.
The panelguides.com link below has many installation manuals for different DSC panels including programming information for your entry/exit delays. The link will take you to the DSC page. You'll need to look for the model of your panel, not the PK5501 keypad.
http://panelguides.com/panel-guides?task=viewcategory&catid=181
Hope this helps.
Mar 19, 2011 | DSC Pk5501 Lcd Keypad 64 Zone Powerseries...
How do i connect my Security company`s radio tx to the DSC PC 1864
Depends on the model of the radio. If it is a TL150 or TL250, it can attach to the T-Link headers on the control board. It is also possible that the radio can do 'dialer capture', where it attaches to the Tip and Ring of the control panel for telephone line monitoring. All of that said, you should have a certified alarm installer do the installation, as they can verify and test communications without dispatching police / fire / ems to your residence. If this is a business location, installing yourself can also lead to some legal liability issues, check your state and local regulations.
Feb 26, 2011 | Home Security
Voice mail does not respond to commands from auto dialer screen
when on your phone vertically press the track ball and your keypads will show up thus allowing you to use you voicemail commands
Oct 28, 2008 | HTC G1
Huawei M835 MetroPcs Cdma Logo
190 people viewed this question
Top Huawei Cameras Experts
sandrasteven
h2oskierfl95
JonSnell Electronic
JonSnell Electronic
Are you a Huawei Camera Expert? Answer questions, earn points and help others
