Question about Sport & Outdoor - Others
Categories of sampling - Sport & Outdoor - Others
Codes P2270& P2272 after oil change check engine light on drove under 100 miles both O2 sensors bad .Could shop have caused this somehow??? Maybe banging them or something ?
make sure they are plugged in tight Definition of Diagnostic Trouble Code P2270 Category: Powertrain Definition: O2 Sensor Signal Biased/Stuck Lean Bank 1 Sensor 2Note: This definition of P2270 is applied to all manufacturers
P2270 - O2 Sensor Signal Biased/Stuck Lean Bank 1 Sensor 2 Comments ' Add Yours
Possible causes
- Faulty Rear Heated Oxygen Sensor Bank 1
- Rear Heated Oxygen Sensor Bank 1 harness is open or shorted
- Rear Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Exhaust gas leaks Help with this
When is the code detected?
The Powertrain Control Module (PCM) detected the HO2S12 sensor has reported a lean condition for an extended period during an intrusive test
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- High Fuel Consumption
- Excessive Smoke from Exhaust
P2270 Description
The Powertrain Control Module (PCM) supplies a voltage of about 450 mV between the HO2S high and low signal circuits. The oxygen sensor varies the voltage over a range from about 1,000 mV when the exhaust is rich, down through about 10 mV when the exhaust is lean.
The PCM monitors and stores the heated oxygen sensor (HO2S) voltage information. The PCMevaluates the HO2S voltage samples in order to determine the amount of time the HO2S voltage was out of range. The PCM compares the stored HO2S voltage samples taken within each sample period and determines if majority of the samples are out of the operating range.
Definition of Diagnostic Trouble Code P2272 Category: Powertrain Definition: O2 Sensor Signal Biased/Stuck Lean Bank 2 Sensor 2Note: This definition of P2272 is applied to all manufacturers
P2272 - O2 Sensor Signal Biased/Stuck Lean Bank 2 Sensor 2
' Add Comment
Possible causes
- Faulty Rear Heated Oxygen Sensor Bank 2
- Rear Heated Oxygen Sensor Bank 2 harness is open or shorted
- Rear Heated Oxygen Sensor Bank 2 circuit poor electrical connection
- Exhaust gas leaks
What does this mean?
The Powertrain Control Module (PCM) detected the HO2S22 sensor has reported a lean condition for an extended period during an intrusive test
Possible symptoms
P2272 Description
P2272 Information for specific makes
P2272 BMW
P2272 DODGE
P2272 FORD
Jul 30, 2015 | Cars & Trucks
Synonyms for type
brand, breed, category, character, description, form, group, lot, nature, number, sample, sort, standard, strain, variety
Oct 24, 2013 | Computers & Internet
Letter samples
OK, I think you have the wrong category?
Apr 30, 2013 | Computers & Internet
Price for thekodak easy share c190
Used and refurbished samples are selling for about USD 36 on up. Given that the camera is three-and-a-half years old in a category whose product lifecycle is less than half that, there isn't going to be much demand for one.
Jan 25, 2013 | Kodak EasyShare Cameras
I want Manual of Disassembling Foxconn 45CMX
http://www.foxconnsupport.com/download.aspx?models=en-us0000341&category=C000000001&Series=en-us0000002&keywords=&sort=
This is Foxconn's link for downloads and the manual is available.
This is the prior page:
http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000341
On the left of the page, it has a sample of manual for disassembling which I did't download but, might be worth a try.
Good luck,
Dave
Aug 06, 2011 | Foxconn 45CMX socket LGA775 motherboard...
From where i can download vga driver for msi mother board, xp sp2?
Hi.
To get free VGA driver for MSI motherboard.visit this website http://www.driverguide.com and join and sign up. type msi motherboard located at the (printed circuit board (PCB)) then click search.
select your present operating system to download compatible driver.
Please see sample image picture.
Jun 28, 2011 | MSI : KM2ML AMD...
My phone will not vibrate at all anymore
Hi
Make sure your ringer is not in vibrate mode. Try These this thing first
Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls.
Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.)
Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option.
Press OK to assign a ringer. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not. Make sure the increase the volume using keys on side of your phone.
If none of these works the ******** motor needs to be cheked for loose connections inside the phone.
Thanks for using Fixya
Mar 24, 2011 | LG Ally Cell Phone
How can i get a free wallpapaer for my aspire one notebook?
You can select and download a free wallpaper for your notebook. Click here. All images are sized to a 1024x600 desktop resolution.
Here are some of samples you will find.
Mar 19, 2011 | Computers & Internet
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
