Question about 3Com Computers & Internet
3C16476 MANUAL IP CONFIGURATION ADDRESS
SOURCE: C3200 Network Configuration
I found the software on the website.
Posted on Sep 07, 2008
SOURCE: HP JetDirect IP Address
how to assign the IP address to Hp color laserjet 2550Ln printer?
Posted on Sep 17, 2008
SOURCE: HP LASERJET 3055 Manual IP Address not saving
Try flashing the firmware: one of the fixes is this - (Improved IP address management of DHCP to Manual changes).  See link below. Firmware
Gerben People tend to evaluate events in light of their paradigm rather than evaluate their paradigm in light of events.
Posted on Oct 07, 2008
Switch off the printer and press * & enter key together &switch on wait till you see " permanent storage int"
then release button your printer comes back to original defaults
then re-configure printer as you require
Murali,
PALLAVI INFOTECH
BANGALORE
Posted on Jun 01, 2009
  • 903 Answers
SOURCE: 4300 laserjet wont print docs.
Have you tried changing the IP address from within the driver's properties? Go into the print driver properties, and under the Ports tab, edit the 4300's port and change the IP address that it is associated with. You may need to reboot the printer once you make the change and save it, but that should allow you to change its IP address.
Posted on Jun 16, 2011
Reset IP HP2015DN
Hi, not sure why this is coming under the router section. You'd need to post a little more information about the problem. Is it with the IP address settings on your router or those wirthin the printer itself. If its
the printer itself - the problem solution is available here possibly.
But Google Resetting the IP address on
HP2015DN
Details To open the HP Embedded Web Server, type the IP address or hostname of the printer in the address field of a supported Web browser. To find the IP address, print a Configuration page from the control panel of the printer by pressing and holding the Go button for 5 seconds. The HP Embedded Web Server URL can be bookmarked for quick access at a later date. Supported web browsers include the following:
  • Internet Explorer 6.0 (and later)
  • Netscape Navigator 7.0 (and later)
  • Firefox 1.0 (and later)
  • Mozilla 1.6 (and later)
  • Opera 7.0 (and later)
  • Safari 1.2 (and later)
  • Konqueror 3.2 (and later)
The HP Embedded Web Server has the following three tabs that contain settings and information about the printer:
  • Information tab
  • Settings tab
  • Networking tab
Once the HP Embedded Web Server opens, perform the following steps to configure a static IP address:
  1. Click the Networking tab.
  2. Click Network Settings under Configuration in the left menu bar.
  3. Click the TCP/IP tab.
  4. Use the drop-down menu to change the IP Configuration Method to Manual.
  5. Type the new IP Address in the box to change the IP Address .
  6. Change any other applicable networking information, if applicable.
  7. Scroll down the page and click Apply .
  8. Click OK on the confirmation screen and then close the browser window.
  9. Wait a few minutes and then print the Self Test/Configuration page and the HP Jetdirect Configuration page to verify that the IP Address has changed.
Dec 03, 2013 | Computers & Internet
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
How to change the ip address of a hp jetdirect 170X
The manual is located here, and it recommends the following procedure, which starts on page 18.
Connect the Jetdirect box to the printer and the network and power on.
Press the Test button on the back of the Jetdirect box to print a configuration page.
The configuration page should show the IP address of the Jetdirect box.
If this is an IP address in the normal range of your network, ie the first three numbers of the Jetdirect box's IP address and your computer's IP address is the same (such as 192.168.0.) then simply type the IP address into your computers internet browser and you can reach the configuration page. The steps on page 58 detail the user interface for the web login.
If the Jetdirect box does not get an IP address withing 2 minutes of it booting up, it assigns itself an IP address of 192.0.0.192, and you can connect to it over the network if you change your own network settings to 192.0.0. and a number from 1-254 (but not 192).
May 04, 2011 | HP Jetdirect 170x Print Server
Need to allow a telnet session thru a speedstream 5660 modem/router having a public ip and allow it to connect to a private ip on the internal LAN. how do i accomplish this?
According to the user manual:
Page 16:
HTTP Web-browser Access
Most HTML browsers can be used, though Internet Explorer 4.0 or Netscape 4.0 are recommended. IE 2.0 and Netscape 2.0 and their predecessors are not supported. The HTML interface can be used to access the LAN (or WAN) IP address or it can be used with FTP to upload and download files to and from the router.
To log on to the modem via HTML:
1 Bring up your favorite web browser.
2 Enter the Ethernet IP address of the router (10.0.0.1 or Speedstream) in the "Location" or "Address" area where you enter web page addresses.
3 Refer to "HTML Web Interface" on page 20.
Page 20:
HTML Web Interface
The HTML interface for the router first displays a page showing the current configuration of the router. The first page also provides links to the following functions:
Advanced Setup
Leads to a more detailed interface with several links that allow more in-depth configuration of functions available on the router. This interface provides the following links:
Configuration Procedures
Status and Statistics
Command List
This is where the user manual ends. I would suggest clicking "Configuration Procedures" and find the section for configuring Network Address Translation (NAT).
In that section (if it exists), you'll want to provide the private IP address of the computer running the Telnet server and forward port 23 to this IP address.
If NAT capabilities do not exist, I would consider changing the router to Gateway mode (described in the user manual) and buying your own router to handle the NAT firewall.
Dec 29, 2010 | Efficient Networks SpeedStream 5660 Router
Were do you enter your code
Are you entering the passcode for wireless connection? There is a configuration page you can open with your browser for most of the routers and with a specific ip address as the URL. You will have to specify an ip address for your computer at the same subnet. If the manual says the default ip address of the router is 192.168.0.1, then you can specify the ip address of your computer to 192.168.0.2 or something alike. Then you can open the configuration page, use the default administrator password specified on the manual to login. Then open the wireless configuration page and specify network ID and security features. If you choose WEP or WPA, you can specify a passcode or a passphrase for each device trying to connect to the router wirelessly.
Sep 09, 2010 | Computers & Internet
Hp leserjet 4250n network ip change solushion
Print out the current configuration of the printer, Press the Tick button, navigate to Information, press the tick button, navigate to Print Configuration, press tick button.
On the printout find the current IP address. Open a web browser and type the IP address into the address bar, press enter.
The printer setup will be loaded into the web brower. Navigate to the network configuration so you can see the IP, gateway and subnet IP addresses.
You can now change these but once you have your browser dispay of the printer will disappear.
Type the new IP address into the web browsers address bar and you should get the new configuration displayed.
Sep 03, 2010 | HP LaserJet 4250n Printer
How to wirelessly print to HP 2410v Photosmart printer
This is the official how-to for network setup from HP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00781863&lc=en&dlc=&cc=us&product=303759&lang=
Introduction Print the network configuration page and obtain the IP address, subnet mask, and default gateway address for the printer. Printing the network configuration page
  1. Press the Setup button.
  2. Press the arrow buttons to select Network and then press OK .
  3. Press the arrow buttons to select Print Network Configuration Page and then press OK . The Network Configuration Page prints.
Obtaining the IP address, subnet mask, and default gateway address The IP address, subnet mask, and default gateway address are printed on the Network Configuration Page
The manual link is here:
http://h10032.www1.hp.com/ctg/Manual/bpu70241.pdf
Hope this helps:
WizardRepair
Jul 18, 2009 | HP Office Equipment & Supplies
Wireless printer
  1. Print a Network Configuration Page from the product.
  2. On the front panel of the product, press Setup .
  3. Press the arrow buttons to select Network and then press OK .
  4. Press the arrow buttons to select Network Settings and then press OK .
  5. Press the arrow buttons to select Network Configuration page and then press OK . NOTE: If the page does not print, unplug the power cable from the back of the product, wait a few seconds and then plug it back in. Repeat the previous steps, a-d, to print the configuration page.
  6. Change the IP settings to Manual from the printer:
  7. On the front panel of the product, press Setup .
  8. Press the arrow buttons to select Network and then press OK .
  9. Press the arrow buttons to select Advanced Settings and then press OK .
  10. Press the arrow buttons to select IP Settings and then press OK .
  11. Press the arrow buttons to select Manual and then press OK .
    1. Set the IP settings from the Manual IP Settings Menu using the following instructions:
      For this item...
    Do the following: IP Address Type in a static IP address on the same subnet. Select an IP address outside of the Dynamic Host Configuration Protocol (DHCP) range. Choose an IP address with the same first three digits as the assigned IP but a much higher fourth digit (between 1 and 254). For example, if the original IP was 192.168.0.1, assign the static IP to 192.168.0.200. Subnet Mask Do not change the Subnet Mask. Default Gateway Do not change the Default Gateway
  • tahnks
    TTYAGI
    Apr 30, 2009 | HP DeskJet 6988 Printer
    How do I set the IP address on my HP 8150
    1. Launch your web browser.
    2. In the Address: or Go to: field, type the IP address assigned to the
    printer (for example: http://192.168.1.1) or the host name (for example:
    http://myprinter).
    If you do not know the IP address for the printer, it is listed on the
    printer configuration page under Protocol Information in the TCP/IP
    section.
    To print a configuration page:
    a. On the printer control panel, press Menu until INFORMATION
    MENU displays.
    b. Press Item until PRINT CONFIGURATION displays.
    c. Press Select to print the configuration page. After the process is
    completed, the printer will return to the READY state.
    From there, you can configure the printer using the web GUI. Consult the manual if you need at:
    http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/bpl10150/bpl10150.pdf
    Hope this helps, and have a good weeked.
    Dec 12, 2008 | HP LaserJet 8150 Printer
    Sep 27, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
    Computers & Internet Logo
    71 people viewed this question
    Top 3Com Computers & Internet Experts
    micky dee
    didi2005
    Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
