E5 error on split ac - Heating & Cooling
Global Air split system. What does E5 error indicate?
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.
AC Repair Company
Feb 26, 2016 | Heating & Cooling
Comperasor running e5 problem
Change capacitor motor and outdur working almost
But 3 minute working ok
After E5 error show display screen on indur with outdour fan stop but compressor sound
Apr 23, 2015 | Haier HSU18VC7-G Mini Split Wall A/C Unit
My tcl split ac works for 5 min, then gives e5 code.
E5 s a communication error between the indoor and outdoor units. It is stated in the service manual that the wiring between the indoor and outdoor has probably separated at one end of the terminal block. Most of the time however, it is usually a failure of either the indoor or outdoor electronic boards. A multimeter and knowledge of how to read "communications voltages is required. The machine will continually assess itself electronically to make sure all components are working properly. If after a given amount of attempts to communicate with the outdoor unit the machine still cant "talk" to the other 1/2 , it will show an E5 error and shut itself down. You could try switching off the power at the isolator or meter box for at LEAST 15 minutes and then turn back on to see if it resets. This sometimes works. Do not, just switch off and switch straight back on again.
Mar 24, 2015 | Heating & Cooling
Blue star split 1.5 tr ac eror code e5
The H16 code came on, still does not work machine how to solved H16 error. ???
Jul 02, 2012 | Heating & Cooling
Dawlance monogram error code e5
P1 error code in dawalance inverter
Jun 12, 2012 | Heating & Cooling
My onida split ac shows F6 . What can I do?
onida 1 ton split ac F6 earror how problem retified
Mar 10, 2012 | Heating & Cooling
IDEC aircon E5 error what does it mean?
i am air con tech and i face all ready this problem may be it will help u . e5 error is ur air con not have gas becoze of that the low presser switch give error on disply thanks best regard for all. pls let now if its help full
May 27, 2010 | LG LSC183VMA Split System Air Conditioner
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
