Question about Kenmore Refrigerators
Er 1F message
I am getting an error message er 1F on my Kenmore elite 31.0 cu ft. French door bottom freezer. After reviewing trouble shooting book does not state how to reset this error. Thank you
  • 4 Answers
SOURCE: Kenmore elite french door freezer on bottom
Odds are due to the fact the ice maker was left on for an extended time with a full tray of ice the mechanisms froze. You can take a hand held hair dryer and defrost the parts, just be careful not to get too over zealous and melt the plastic parts. It should only take a few minutes to defrost.
To avoid this problem from occurring again, I turn the ice maker off when the ice tray is full.
Regards,
Ann
Posted on Nov 22, 2008
SOURCE: Kenmore Elite French Door w/
Shows an error on display ER IF. The ice maker has stopped working.
Posted on Dec 03, 2008
SOURCE: kenmore elite french doors bottom freezer Model #
Well you got a kenmore that i believe is actually made by either Samsung, or LG, since Kenmore does not make any refrigerators, they are ALL taken from other name brands with the name kenmore put on the front. I would start by looking at your owners manual for troublshooting codes, but chances are you have a faulty evaporator fan motor, either the motor itsself is out of balance, or possibly ice is obstructing fan blade, and you'll need to find the source of that problem instead. hope this helps
www.FixMyFridge.net
Posted on Mar 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: Help....kenmore trio refrigerator, error message "er co"
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: Temp control is displaying Er and FF code
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Had a power outage for a few seconds, the control panel is not working on my refrigerator, it reads er lf.
This error means some thing is wrong with the fan to the ice maker. It might also be a bad control board. If it is still under warranty get he board replaced. Kenmore has had some problems with these particular boards. You make be able to reset board by unplugging unit for a while and plugging it back in. Hope this helps
Jan 03, 2014 | Kenmore 31 cu. ft. French-Door Grab-N-Go...
The display is showing ER FF WHAT DOES THAT MEAN
error fresh food means refrigerator probably bad thermistor in refrigerator ( ff refrigerator ) fz freezer
Jan 27, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
I am getting an ER FF message on my refigerator in the section where it normally gives you the fridge and freezer temp.
f =heat exchang you have to check the condensor fan and evaporator fan , clean the condensor coil . if the frost build up to block air way. need to check heat element and defrost thermostat. good lock
Jan 10, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
I have a Kenmore Elite Refrigerator, Model No. 795.77573600. The ice and water dispenser give the error message Er 1F. In searching online it appears that this problem is related to the ice compartment...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Aug 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite french doors bottom freezer Model # 795.77573600. There is an message Er FF and is very noisy.
www.FixMyFridge.net
Mar 08, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
We have the kenmore elite trio bottom freezer refrigerator model 795.7756 - we have error message ER IF, we know the ice maker will not come on and have tried resetting it. How can we get the icemaker to...
Sep 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer working fine but refrigerator not cooling
Do you have the ER DH error message showing? If so, it is a failed senser, an $11.99 part that many of us are having trouble with.
May 18, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
13 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
