Question about Whirlpool AWM5125/1 Front Load Washer
Hotpoint washer over filling
My hot point washer is over filling with to much water and will not go into the agitating cycle it will over flow with water what do i need to repair it
  • 97 Answers
Hello Friend, Your solution is simple. You need to replace the water level pressure switch. It's simple to replace, just remove the knob from front panel and gain access to the rear of control panel. You will see the water level pressure switch from the backside. It has a flexible rubber tube attached to it. Just remove the rubber tube and the wires making note of location of wires. Install new switch and re-install wires and when re-installing rubber tube, be sure to moisten nipple on new switch before you re-install the rubber tube. moistening the nipple before re-installing the rubber tube will insure an air tight seal. This should solve your problem. Happy to help, Tim.
Posted on Jun 24, 2009
My hot point will not fill with water the supply is ok
The screens where the hoses connect to the washer are clogged with mineral deposits, which is not allowing the water to flow into the washer. I've had the same problem.
Sep 03, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
Hotpoint VLXR1020A Top Loader Washer The washer only leaks when it is filled with water and agitating. It does this on the soap cycle for the first minute or so and then again on the rinse cycle for the...
Mine did that cuz I didn't have the hot water hooked up and it came out there... It didn't do it at first, just randomly started to do it so I put a soda bottle cap on it.....
Feb 13, 2011 | Hotpoint VLXR1020A Top Load Washer
Not spinning or draining, only fills and agitates
the mixing valve in the rear needs to be repaced-it controls the water flow Also sounds like the clutch of the transmision maybe be a factor if the machine doesn't spin
Jul 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer functions but doesn't fill with water, with
if it agitates without water then the fill pressure switch is stuck , this will lead the unit to beleive its full already.
replace the water level/fill switch for the fix.
Phil
Jun 10, 2009 | Washing Machines
Kenmore 110 Top Load Washer-cold water fills extremely slowly
No it is probably the screen that is either in the end of the hose that attaches to the machine, and/or the screen is placed so that the cone is toward the machine instead of pointing away from the machine.
If the cone is pointing towards the machine any debris in the lines would collect and eventually fill the screen cone and slow or shut off water flow.
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint washer fills begins to agitate then refills continously.
Very likely your drain hose is set too low. You can solve this with a standpipe or a kit called a siphon break.
Dec 31, 2008 | Hotpoint VBSR3100GWW Top Load Washer
HOW TO REMOVE AGITATOR ON A HOT POINT WASHER
if anyone is still doing this.. i had a hotpoint model type vbxr1060. It had just a cap on agitator no extra bolts and used two hammers to get underneath the base creating leverage..
Work both hammers in (using the nail puller side) as far as possible towards the center of the agitator on opposing sides and use them to pull up and slightly outwards towards the sides of the basin. When you get it off you will see why this works as the agitator's base has mini clips that grasp the base of the air bell housing. hope this tip helps someone.
Oct 25, 2008 | Washing Machines
Hotpoint washer mod # vbxr1070w1ww
hi thanks for the question i would check the lid switch on that washer very common problem thanks the appliance doc
Sep 27, 2008 | Hotpoint Washing Machines
Whirlpool AWM5125/1 Front Load Washer Logo
134 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
