Question about Heavy Machinery
How to replace blade on a Murray 12/ /ic/38 riding mower
SOURCE: Murray riding lawn mower
I have a 12 HP Murray riding mower about 6yrs old model 30577X8A. I am having trouble shifting it in and out of gears, ever thing runs just fine can you help?
Posted on Jul 05, 2008
  • 323 Answers
SOURCE: Yard Machine riding mower blade not coming off
They do come off in the same direction. Spray penetrating oil or WD-40 liberally all over it and let it soak for a while, Get a pipe wrench (if you're already destroying the shoulders on the nut anyway) and work it close until the nut is a good halfway into the jaws. Make sure you have a good block of wood to keep the blade from spinning
and apply force. If you cannot get enough pull on the pipe wrench, find a section of pipe to make a "cheater bar" slipping it over the end of the handle and down a good 6 inches, and extend it out further. It will definitely come off.
Sirwriter
Posted on May 17, 2009
  • 257 Answers
SOURCE: Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Posted on Aug 15, 2009
mickey813
  • 472 Answers
SOURCE: murray riding mower the blades will not engage
sounds like the cabel it broke
Posted on Oct 01, 2009
mowerman1857
  • 389 Answers
SOURCE: murray 42'' riding lawnmower owners manual
www.murray.com
Locate the tag with your model and serial number on the tractor. Be sure you get the number EXACT or it won't work.
Go to Murray's website and download it. They usually have parts listings at the back of the Owner's Manual
Posted on Oct 04, 2009
Where can I find a Murray 12 HP 38 " lawnmower model 38608X92C manuel?
Murray can send you one some mower shops maybe able to print you one or part of it
Jul 26, 2014 | Murray Garden
Need diagram for belt instalation for murray 46" cut
Select Index Numbers here:
2 Asm, Jshaft Housing Head W
3 Q2 Pulley , 46"
4 Shaft, Splined Jacks
6 Nut, Pulley
7 Hub, Blade Adaptor
8 Q4 Blade 46" Mulcher
9 Washer, Bellevile(ard
10 Washer Hardened (ard
11 Nut Hex (ards)
12 Screw, 3/8, 16X1.25
24 Rod Belt Guide
25 Belt Cross Drive Ja
26 Belt Primary 46" J
34 Bracket Cover
35 Bracket, Pulley Cover
36 Qx Lburg# 094605E700 -INACTIVE-
37 Use Lburg# 093349 Zi -INACTIVE-
38 5/16, 18 Hexwdfllk Wh
39 Screw, 5/16, 18X.75HH
40 Cover, Pulley Right
41 Screw, 10, 16 .190X.62
72 711327
72-1 Wheel, Gauge
72-2 Bolt, .500X3.275HHSH3
72-3 Spacer, Slev .515X1.
72-4 Nut, 3/8, 16 Hxctrlkj
72-5 Qxcolor Code Require -INACTIVE-
79 Pin Detent Ring (DP5
80 Asm, Mulcher Plug 46
81 Bolt Carriage (ards
82 Nut, Wing (ards)
89 Zerk, Grease Fitting
Apr 21, 2014 | Murray 46 Primary Lawn Mower Blade Belt...
I need a diagram on how to fit a cutter deck belt for a murray sentinel 15.5/ 106. Belt number 037 x 88 Keith
The routing is usually pictured on the belt cover such as in your picture. If you send me the model no. to the rider, I will verify proper routing.
Feb 11, 2011 | Murray 38 Lawn Mower Blade Belt '90'96...
HOW DO I GHANGE THE DRIVE BELT ON A MURRAY RIDING MOWER
http://www.ereplacementparts.com/ type in your model number all the diags you need, yours Henry
Oct 16, 2010 | Murray 38 Lawn Mower Blade Belt '90'96...
Need diagram to replace murray 42 inch cut belt
http://www.ereplacementparts.com/ type in model number of your mower ie 40560x50c All parts and diags ypu need ,Yours Henry
Aug 07, 2010 | Murray 38 Lawn Mower Blade Belt '90'96...
Heavy Machinery Logo
Top Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
