Question about Electrolux Washing Machines
Elecrolux inspire efw12680w
My machine went to beginig of the program when its should begin to drain and spin....no warnings
5 Suggested Answers
SOURCE: Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Posted on Feb 17, 2010
barkencoa
  • 3463 Answers
SOURCE: washing machine doesnt empty or final spin
You need to check the filter.
Remove lower rear cover of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Fit back and test.
Posted on Mar 12, 2010
  • 713 Answers
SOURCE: No spinning action on my MW511 Fisher and Paykell
Hi just read your posting.Now with the error code you have shown it tells me you have an out of balance fault.To find out if the fault is with the out of balance switch or the motor controller you will need an electrical test meter. the reason for this is to test the switch for conductivity,not to test for power or anything dangerous.Have you or can you borrow an electrical test meter to test the switch?please reply and I can guide you throe the repair of this fault.
Posted on Jun 15, 2010
greg_margo
  • 1959 Answers
SOURCE: washer does not completely drain to allow for spin
The most common cause for standing water in a washer is a clogged drain pump. Another possibility is a kink or clogged drain tube. Below is a youtube video with instructions on removing a drain pump on most front load washers including your Frigidaire model. Best of luck and thank you for using Fixya!
Posted on Dec 27, 2011
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
ANY IDEAS AS TO WHY MY MACHINE HAS STOPPED DRAINING? PLEASE
washing machines engage the drain pump at the beginning of a spin cycle
If there is still water in the tub after the spin then the pump is not working to pump the water out
I would check for something stuck in the impeller of the pump stopping it from spinning, burnt pump motor , no
power to the pump program board /relay, something blocking the inlet to the pump
Feb 10, 2016 | Washing Machines
Water will not flow
The fill valve could be defective.
Dec 18, 2013 | Frigidaire Washing Machines
Elecrolux EWF 1020
If it gets louder the faster it spins its more than likely the drum bearings, if its a constant noise starting when the machine is emptying it could be the pump or something stuck in the pump,If so check in the filter for hair clips etc.
Nov 06, 2013 | Electrolux Washing Machines
The code E20 is showing on my w/machine,whats the problem?
e20 on AEG Elecrolux and zanussi is machine not draining efficently. blockages in the machine or drain can cause it. if your model has a filter or coin trap clean that out. or dismantle the pump to look for something jamming the impellor. may need a need pump.
Aug 06, 2010 | Washing Machines
Washer won't drain or spin
your not going to like me? its the programer playing up,,,pricy part too?
see i was right,,,you hate me now!
Jun 08, 2010 | Frigidaire FTF2140E King-Size ENERGY STAR
Fixing lg whasher
??? not enough information, what do you mean by this? the clothes are still wet when they come out the machine does not spin at all?
the machines have a set time to drain before they spin usually three minutes if the water has not dropped below a level before the set time the machine will stop, check the drain
Clothes begin to get wetter than before? how old is the machine motor brushes usually last 2-3 years depending on usage when they wear down the parts of the program that put the most power through the brushes can fail first (Spin)
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
