Question about Sony Car Audio & Video
Watson crc8448mu error 13 - Sony Car Audio & Video
2 Suggested Answers
SOURCE: i have a watson CRC8448MU
eror 12 when I put mem card
Posted on Jun 30, 2012
Mando watson rc9206
go to www.fitness.manualsonline.com or www. retrevo.com
God bless you
Jul 09, 2013 | Televison & Video
I was having a Watson Client problem... and today I get: Exc in ev handl: Error: Bad NPObject as private data! What's up with this, now! Still having Watson Client problem and can't open Word! Help
This is a virus ..I suggest to reinstall the program ..and remove the old one completely ..If this will not fix the issue you will have to reinstall operation system to fix it for good.
Dec 24, 2011 | Computers & Internet
When turning on it will only go to a blue screen says go to safe mode or get tech support but even in safe mode it will only go back to blue screen. Can't download anything or do anything. At the...
Try uninstalling a few unnecessary programs
Just run fewer programs or buy additional RAM click start right click on my computer select properties you will see all imformation about your computer including installed ram
or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly
click start right click on my computer,properties advanced scroll down to system and recovery open settings write and debugging information the drop down button select none
ideally, it should already be the default debugger for your system.
The Dr. Watson debugger program logs all information related to failed processes to the Drwtsn32.log file. In addition to this, the debugger program can be configured to create memory dump files related to the failed processes. You can refer these dump files to analyze the reason behind a process failure.
Perform the following steps to configure Dr. Watson as the default debugger program to record user-mode program errors:
  1. Open Start menu, select Run, type Drwtsn32.exe -I and then press Enter. This command sets Dr. Watson as the default debugger.
  2. Next, run the Drwtsn32.exe command.
  3. In the Dr. Watson for Windows dialog box, select the following check boxes:
    • Append to Existing Log File
    • Visual Notification
    • Create Crash Dump File
  4. Now, when your computer restarts after the STOP 0xC000021A error is generated, run the Dr. Watson command.
  5. Here, view the paths to the Dr. Watson and User.dmp logs.
  6. Open Windows Explorer, navigate to the log files and then open them.
  7. Here, check the cause behind the STOP 0xC000021A error.
also you might download and use this registry cleaner it is 100%totally free to use
http://download.cnet.com/ccleaner/
hope this helps you
Jul 24, 2011 | Computers & Internet
I need manual instruction to remote model - watson RC9206
http://lmgtfy.com/?q=watson+RC9206+manual
there you go, it's the second link.
Mar 09, 2011 | Directed 434MHZ Remote Control
My touch pad constantly freezes and is inhibiting my work flow due to restarting the notebook all the time. please help
The first cause can be fixed rather easily. Simply run fewer programs or buy additional RAM or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly...!..
also you might download and use this registry cleaner it is totally free to use
hope this helps
don
Feb 23, 2011 | Computers & Internet
Keep getting a memory dump error
this problem only can fix by reinstall your computer operating system (windows)
Feb 22, 2011 | ASUS G51JXA1 PC Notebook
After shutdown my computer i see blue screen saying: stop c000021a fatal system error, please solved this problem.
Most of the time, this error occurs due to the failure of the Winlogon.exe process. This usually happens if a faulty third-party Graphical Identification and Authentication (GINA) DLL exists on your system. GINA is a replaceable DLL component that is used to perform the following tasks:
  • Implement the authentication policy of the interactive logon model.
  • Perform user interactions, such as authentication and identification.
At times, a remote control software may replace the default GINA DLL file, msgina.dll, on your computer and you may face the stop error. This is the reason why it is a good idea to first check if you have a third-party msgina.dll on your computer. To do this, run the regedit command to open the Registry Editor tool. Here, navigate to the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Here, check if the value GinaDLL REG_SZ is on the right pane. If the value is there and its value is different from msgina.dll then it means that a third-party software has changed this value. In case this value is not there, it implies that that your system uses msgina.dll as the default DLL file for GINA.
If this error follows a new driver, service or third-party software installation, you must try to uninstall this new software to repair the error. To do this, you may use a good third-party program uninstaller tool, such as Perfect Uninstaller to ensure complete removal. You may also try to install an update for the software, if it is available.
You may also try to boot your computer with Last known good configuration information to see if the error goes. If nothing works, you may have to perform and in-place upgrade of your operating system to resolve the error.
utmx_section("bottomad") Additional Recommendations...
Driver Update: Many errors are related to driver problems such as obsolete, outdated or incompatible drivers. A driver update tool is recommended to scan your system for corrupted and outdated drivers and to ensure that all your drivers stay up-to-date.
hope this helps
Nov 17, 2010 | Computers & Internet
Watson RC9206
I have a remote control Watson RC9206 and I lost my manual...and codes.Please help me!
Sep 05, 2009 | Directed 434MHZ Remote Control
Car Audio & Video Logo
62 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
