Question about Daewoo DTQ-14U5SC 14" TV
Why do i just get a blinking standby light on my Daewoo DTQ-14U5SC Tv. It won't turn on, just the blinking standby when I plug it in.
  • Guy Plante Jun 22, 2009
    Hi there, Thanks for responding. Yes< I have the remote, and tried it with new batteries, but it didn't work. As soon as i plug it in, the red light starts blinking, and makes a little sound out of the speaker, like it's trying to turn on, but nothing.
  • Guy Plante Aug 02, 2009
    That didn't work either. It must be a fuse or something else i guess.
  • 3,267 Answers
Do you have the remote with you? Mostly the sets can be switched on for viewing only from the remote button.............sodeep
Posted on Jun 22, 2009
  • Sudeep Chatterjee
    Sudeep Chatterjee Aug 02, 2009
    Have you checked the voltage. It must be normal, otherwise you would have noticed, because red blinking means check the video/audio input since it has no signal to display. However if this happened one fine day then most probably your HT circuit is getting insufficient voltage from the HT transformer which boosts the voltage to 11KV for the tube.....................sodeep
Lines vertical
These lines are called vertical retrace lines, and caused by the video output section; or improperly set screen voltage. All of these type of lines will be a little slanting type, across the screen all over, with an approximate one inch apart to each other. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 21, 2013 | Daewoo DTQ-14U5SC 14" TV
How to connect HD antenna
get yourself a set-top box and connect from there
Oct 14, 2013 | Daewoo DTQ-14U5SC 14" TV
DTQ-13V1FC TV no standby light
Main power supply regulator section to your TV has the fault. Check and replace faulty component/s there.
Jul 04, 2012 | Daewoo DTQ-13V1FC TV
How do i find tv code number for model number DPT 42A3 daewoo tv
Your TV brand is Daewoo i thinks. check these codes. 0002,0345,0243,0543
If you want more details, visit this site. The site name is "Electro-help". Just type this site number to your browsers' search box. You can see the site either at the bottom of the first page or at the top of the second, if you search for it on Google. You can get it from yahoo search too. It has been subtitled 'electronic equipments service help'.
Jun 15, 2012 | Daewoo DTQ-14U5SC 14" TV
Standby Light Keeps Blinking. Can't get TV to come on.
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expense, just locate any good qualified repairer.
Jun 18, 2009 | Daewoo DTQ-14U5SC 14" TV
Red light brinking
Hi
Can you give the HOT voltage? this issue is by defective HOT section maybe you have leak or shorted capacitor.
Thanks!
Apr 12, 2009 | Daewoo DTQ-20U4SC 20" TV
Daed. Daewoo DTQ-13V1FC
tv appears to be in standby mode.. how can i get the tv to actually turn on?
Thanks, bd
Mar 26, 2009 | Daewoo DTQ-13V1FC TV
Buttons on front of tv not working
Try to clean the buttons pcb fitted inside of tv as there is some moisture and may be track open on the pcb board where these buttons are fitted . You may check the internal connectors of Buttons pcb and the mother board inside where some leakage leads to such issue. Clean the pcb and connectors clearly and perfectly then this issue will not occur further.
Dec 20, 2017 | Daewoo DTQ-29S1FCN 27" TV
Daewoo DTQ-14U5SC 14" TV Logo
498 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
