Question about Electrolux 30" Self-Cleaning Slide-In Double Oven Electric Convection Range - White
F5 code on electrolux range
What does an F5 code mean on slide in electrolux range
4 Suggested Answers
SOURCE: electrolux slide-in range with a f 23 reading
call service
Posted on Oct 11, 2008
  • 149 Answers
SOURCE: Replace or repair?
f3 is oven is to hot so needs a sensor
f5 is that the door latch/switch is playing up.
i would repair it
Posted on Mar 23, 2010
  • 5531 Answers
SOURCE: The Oven and Range are working; however I have a
The F5 code means that the range door isn't latching properly (for some Whirlpool ranges). Check the latch when the oven is cool. If it is loose, tighten the screws that hold the latch. Try opening and closing the door to see if the latch is clicking shut properly. Then unplug the range for 30 seconds to a minute to reset the unit. If the error clears, you're done.
If the error persists, clean the latch area. With the oven not in use, rub the latch area with a cloth that you dunked in hot water and wrung out the excess water. Then dry with a paper towel.
If cleaning doesn't help, the latch probably needs to be replaced.
I hope this helps. Please give me the model number of your range for additional ideas. Whirlpool has the user's manuals for most of their appliances at their site. See http://www.whirlpool.com/custserv/index.jsp and the Manuals and Literature search box.
Posted on Jun 06, 2011
What does code d-o mean
Good Afternoon friend, that's a great question!
From my understanding your Electrolux range is displaying a code of "d-o". The code could stand for open door, could be missing a sequence, or a miscommunication within the control panel. I would recommend performing a reset on your range and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue I would suggest having a professional technician out to perform a proper diagnosis and repair. Hope this information is helpful. -Matt
Mar 09, 2015 | Electrolux Wave-Touch EW30GS65GS 30"...
Error code 5f, what other solutions do you have
Good Morning stanley m, thanks for your inquiry!
Based off the information you have provided your Electrolux range is displaying an "F5" error code. Typically, "F5" stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I see you stated that you turned your range off and on I would suggest performing a reset on your oven and you can do that by disconnecting from your oven for roughly ten minutes. If you continue to have issues with the "F5" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
Jan 28, 2015 | Electrolux EW30ES65GW 30" Slide-in...
My stove have code f 23 What this mean?
Thanks for your inquiry, Adrian Gonzalez!
From the information you have provided your Electrolux range is displaying an error code of "F23". "F23" stands for communication failure between the EOC (Electronic Oven Control) and ESEC (Electronic Surface Element Control) I would attempt to perform a reset on your range and you could do that by disconnecting the power from the range for ten minutes. If you continue to experience a problem with the error code it could be an issue with the EOC or VSC (Variable Speed Control) board. Hope this helps. -Matt
Nov 22, 2014 | Electrolux White Gas Slide In Stove Range...
What does E15 fault in a electrolux stove mean?
Thank you for your inquiry, friend!
I understand that you are looking for the meaning of "E15" on your Electrolux range. "E15" stands for ESEC self-test failed, which could either mean and issue within your UIB (User Interface Board) or relay board. I would recommend having a professional come out to diagnose and repair your appliance. Best of luck. -Matt
Aug 19, 2014 | Electrolux 30 Inch Black 30" Electric...
My oven is beeping on an E11 error code on my electrolux range. How do I stop this?
E11 indicates a communication error where a technician needs to diagnose the control board.
Jul 23, 2012 | Electrolux EW30ES65GS 30" Slide-in...
Kenmore model 790.96113403 F5 error code
it means that your oven is showing a restart code
Jun 13, 2012 | Kenmore 99123 Electric Kitchen Range
What does F 5 mean when I try to turn on the oven
For F5 code on Electrolux slide in electric range, cycle circuit breaker and depress the "+" and the "-" on the # panel together for 5 seconds. This should reset the range.
Mar 12, 2012 | Kitchen Ranges
F5 message
Hi Anita:
Error Code F5 means that the oven control is bad.
In order to solve it you will need replace this oven control/clock.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Nov 23, 2011 | Jenn-Air SVE47100 Slide-In Electric...
What does Error code E 11 mean? The counter top burners quit
Sorry to read about your problem, I hope this helps you out.
Error Code:
E11
Cause: Latch Problem Example: Will not clean Corrective Action: Replace latch in affected oven
Dec 25, 2010 | Electrolux EW30ES65GS 30" Slide-in...
Unable to install the electrolux slide in electric range
  • Electrolux may have supplied generic installation instructions, failing to account for design differences
  • Electrolux failed to validate the installation instructions against the actual hardware
Jun 23, 2017 | Electrolux EW30ES65GS 30" Slide-in...
Electrolux 30" Self-Cleaning Slide-In Double Oven Electric Convection Range - White Logo
513 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
