SOURCE: fault code F05 on an indesit washing machine WIXE
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove large black fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hop[e this helps you.
SOURCE: Indesit WIXE 127 The machine is
Demo Mode
If the machine is on Demo mode 'D on' will be displayed and the machine will NOT function.
To reset the machine for normal use:ยท
Turn the power off at the wall.
Push in and hold down the Start/Stop and the Start/Reset
buttons, while still holding down, turn the machine on at the
wall.
'D off' will be displayed and the machine will function
normally.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: Code F-05 showing on INDESIT
Hi
Locate and remove the large black fastened to bottom of the drum.
Hope this helps you.
