Question about Maytag Atlantis MAV6000 Top Load Washer
Changing fill hoses---the connection to the washer is very narrow
Cannot tighten hoses properly they are leaking
Are the rubber gaskets in place on the hoses? Some hoses come with rubber gaskets others do not and they have to be inserted.
Posted on Jun 26, 2009
My kenmore washer molel 110-82873120 is leeking from the top.
Dear R.A.,
If your washer is leaking you should first check the hoses.
  • There are several types of hoses found on a washing machine and the most common are the drain and fill hoses.
  • The fill hoses connect the household supply to the water inlet valve and are normally located at the rear of the washer. Check to make sure that the threaded fittings are tightened securely and that the leak is not caused by the faucet.
  • The drain hose is also located at the rear of the machine and may not be properly installed into the household drain. Verify that the leak is not caused by a restricted household drain that is backing up through the stand pipe.
  • Washers will also have internal hoses that connect the inlet valve to the tub. A defect in this hose would create a leak during the fill cycle.
  • Access the tub inlet by lifting the main top or removing the cabinet and inspect the hoses for signs of abrasion or cracking.
  • Also inspect the other components of the water inlet system such as a siphon break or tub injection assembly for signs of a leak. Check for loose or corroded clamps, and cracked or perforated hoses.
  • Your inlet Valves may also be totally defective and cause the washer to overfill therefore causing a leak over the top.
  • Check for the tub Pressure switch assembly may be defective causing such leak.
  • Your model requires removing the complete cabinet.(front and sides come out as on piece) Here a link to all your machine parts
I think we cover all the possibilities.
Best of Luck,
JP
KENMORE AUTOMATIC WASHER Parts Model 11082873120 Sears PartsDirect
Jul 03, 2015 | Kenmore Washing Machines
Washerleaks when filling why
Good Morning Friend,
I understand that the washer on your Frigidaire laundry center, model# FEX831F, is leaking water while it is filling. Listed below are some options that you can check first.
    1)There might be a loose hose connection either at the faucet or on the washer. Check and tighten the hose connections. Also, make sure that the rubber sealing washers are installed. If the rubber sealing washers are not there, this can cause leaking.
    2)Check and make sure your houses drain pipes are not clogged. If they are, unclog the drain pipes. Contact a plumber if necessary.
    3)Make sure you are not using too much detergent and are using "HE" detergent. If you are either using too much detergent or not using "HE" detergent, this can cause oversudsing, which can cause leaking.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
May 22, 2014 | Frigidaire FEX831F Top Load Stacked Washer...
My ge potscrubber 650 is leaking onto the floor in front of the dishwasher. What is the likely problem?
Check you filter and screen .Check whether you need an replacement for them.
If you dishwasher has foam coming out from under the door, then the problem is that dish soap somehow ended up in the dishwasher or excessive rinse aid . It is not recommended to prewash the dishes before loading them into the dishwasher as only a small amount of dish soap can cause the sudsing that you experienced. Only detergent specifically designed for automatic dishwashers such as Electrasol®, Cascade® or Cascade Complete® should be used. Spilling rinse aid while filling the dispenser will cause sudsing also.
To clear the suds from the dishwasher sprinkle several tablespoons of non-dairy coffee creamer over the suds. The fat in the creamer will help break down the bubbles. Wait five minutes for the suds to lessen.
Many pump leaks happen around the seal on the pulley. Some pumps have a weep hole that lets water drip out when this seal begins to go bad. The solution is to rebuild or replace the pump.
You'll want to confirm that the fill hoses are connected and properly tightened. Always use new rubber washers when re-installing the hoses. Take care not to over-tighten the connection. Other leaks may be caused by the drain hose being cracked, or by a leaky connection at the water-inlet valve. Too many suds may cause the appearance of a leak when actually it's just a sudsy overflow. Sometimes a drain hose leak occurs at the end of the hose where it attaches to the washer. If the hose is long enough you can cut the leaky end off and re-clamp the hose back on. Usually though, when a hose begins to leak, it is best to just replace the hose.
Sep 10, 2010 | Dishwashers
I have a ge washer wpsr3120w0aa that leaks water when rinsing
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
©2006 Publications International, Ltd.
If an inlet valve is faulty, check the water connection and the
valve screens. Try gently tapping the solenoids;
if this doesn't work, replace the inlet valve assembly.
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
Troubleshooting Water Leaks
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Step 9: Check the water pump, using the procedures that follow.
Aug 29, 2009 | Washing Machines
Old admiral clothes washer leaks at front
Aug 25, 2009 | Maytag PAV2300 Top Load Washer
Kenmore series 80 washer leaking.
about the #1 leak on ken more/whirlpool washers are the pump.it is in the frount middle.you can dry up around washer and slide news paper under it then run load.that will narrow your surch area unless just over filling thats another matter.God bless,tom
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Water pouring out from soap tray !!!
hi Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Sep 13, 2008 | Washing Machines
Leaking underneath but all hoses are connected
When a washer is leaking, there are several areas where the liquid could be coming from.
If it only leaks during a spin cycle, it's probably caused by a leaky drain hose
Leaks on a front-load washer can occur around the door seal. This can happen because of a build-up of dirt and soap on the seal itself preventing a proper seal from taking place. Wipe the door seal carefully making sure that the edge of the gasket is clean.
Parts of a plastic bleach dispenser can crack or break off, causing a leak intermittently during the flush process. This is because bleach is a very corrosive chemical. Heavy use of liquid chlorine bleach can pit and rust stainless steel parts..
Tub leaks are usually caused by a rotted tub. If this is your problem, consider buying a new washer. Sometimes a constant imbalance can be the culprit. This imbalance can rub a hole in the tub if it consistently runs off-balance. It may be possible to repair the tub with an epoxy kit. Tub replacement isn't usually very economical.
The main tub seal can also leak. This is located where the transmission and the outer tub in the centre. If this seal goes bad, it can be very difficult to replace.
Sometimes the water-inlet valve develops a buildup of mineral deposits and rust. To check this, remove the water-inlet valve and visually inspect the surface.
There is a cool product that is designed to help prevent water damage from a leaky washer. It's called a Washer Floor Tray This tray catches water leaks and prevents floor damage from overflows. This product is a must for upstairs laundries
Sep 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
303 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
