Question about Belkin (F5D7231-4) Wireless Router
Tried to secure my wireless connection, but all I did was stop my UTStarcom adapter from getting internet access. I now can't log onto my UTStarcom router setup page anymore. Can't I just reset this? I can get online fine through LAN, but I want to undo the WAN username and password, but I can't access 192.168.2.1 anymore. I keep getting a search page. There is no reset button in the router
    Scholar:
  • 58 Answers
Symptom You are trying to access the Belkin router’s Web based Configuration page and you are not able to do so. You can access the Configuration page from any computer behind the router.
Resolution To address this issue, follow the instructions below:
  1. First check for the physical connections between the computer and the router. There should be a cable (cat5 or above) running from one of the LAN port of the router to the Ethernet card in the computer.
  2. If the computer is wireless, it should be associated to the Router/AP.
  3. Check for any firewalls (Mcafee, Norton Internet Security) on the computer, which should be disabled.
  4. Check for an IP Address on the computer in the range of the router i.e. 192.168.2.x (x can range from 2 to 254). The router also assigns an automatic IP address to the computers in the range 192.168.2.x (x can range from 2 to 100). For instructions on how to check the IP address on the computer, Refer to Article 13.
  5. If you are not getting an IP Address on the computer from the router you will need to manually assign an IP Address to the computer.
  6. You also need to restore the Internet Explorer browser to its default settings.
  7. Go to Control Panel and click Internet options. Select the Program Tab and click on Reset Web Settings.
You should be able to get the router's configuration page if the above instructions are followed in order.
Cause You not being able to logon to the router's configuration page could be due to the following reasons:
  1. The computer is not able to establish connectivity with the router (wired or wireless). This can happen due to physical reasons E.g.: Improper cabling, bad cable, and no wireless signals.
  2. The computer not getting an automatic IP address from the router (DHCP ** assigned).
  3. Firewalls (Mcafee, Norton Internet Security) on the computer blocking the communication between the computer and the router.
  4. Improper browser settings (Internet Explorer)
** Dynamic Host Configuration Protocol
Summary The Router is a configurable device and you can manually log into the router’s configuration page to set its various operating parameters like connection type, security features and options to update the router’s firmware.
Posted on Jun 22, 2009
Just got a new linksys e3000 router. all other laptops working fine except one toshiba with vista. i have another toshiba with vista that is working fine also though. it will connect wirlessly if i disable...
You have to update the wireless adapter driver on the toshiba website. I'm guessing you have an Atheros adapter because those usually have this problem. The driver is not advanced enough to log onto a WPA or WPA2 encryption, WEP will work fine. The driver updates have a 50/50 chance of fixing the problem otherwise you are stuck with WEP.
Jan 11, 2011 | Linksys E3000 Wireless Router
It shows as connected then when i try to connect to the internet it say navigation is lost so i cant access the internet.
it maybe a firewall blocking access or the secruity code 1) disable the firewall and see if it now connects 2) log into the router and goto the wireless section and remove the secruity now see if that will connect a useful tool to use, if you can copy onto the PC, http://www.xirrus.com/library/wifitools.php this will detect all the networks broadcasting - so you can now see if the adapter will detect your wireless network
Mar 16, 2010 | Belkin Computers & Internet
Secury enable wireless network
the security is enabled on the router or access point noty in the wireless adapter,,, u can connect a comp to the router or accesspoint with a cable and access the page of the router or access point and disable security in it ,,,
Jun 03, 2009 | 3Com Officeconnect Wireless (303000011)...
Can't access Belkin setup page 192.168.2.1 anymore.
There should be a small reset pin hole in the back of the device. Hold down the reset button for 15 seconds and it should reset the router to factory defaults
May 27, 2009 | Belkin (F5D7231-4) Wireless Router
DI-514
PLEASE RATE ;] you can find out whos accessing your router by logging into it. Usually 192.168.1.1 once your in there is usually an option for attached devices or connected devices it should show you what computers or devices are connected to that router
Feb 06, 2009 | D-Link DI 514 Wireless Router (DI-514)
Have dlink router but belkin wireless adapter cant connect
sounds like a security conflict, if you log onto the router and disable the wireless security will the laptop connect to the internet?
Dec 31, 2008 | Computers & Internet
Unable to secure wireless network.
log onto the wifi router. set your ssid to whatever you want it to be and security to whatever p/w you want it to be. this will usually require a reboot. this will need to be done on the primary pc
if you only have one. connect it all physically as it should be. then do the above. disconnect the compuer from the ethernet cable and it should be a wa-la. hope this helps :)
Dec 23, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
Belkin wireless G+ usb adapter
AOL has been and will always have problem (had to do repairs on AOL computers since 1994)
If you have a DSL or Cable connection why pay again for AOL? That means you are paying twice for the same internet connection - and AOL causes lots of problems.
For AOL problems, it is best to contact AOL.
Jul 21, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Hye
On the security enabled network you need the pass phrase associated with the secured network and its configuration(WEP, WAP, ect...). If you are authorized to use this account contact the system administrator and he/she will give you pass phrase and configuration info needed to configure your network connection. If you are not authorized to be on that system and the are using WEP there is a program called net stumbler that captures several thousand packets and analyzes them using an ingenious algorithym and discerns the passphrase needed to gain access to the protected network in a couple of minutes. Net stumbler is also a great tool for the hobby war driving. This is a game where people drive around looking for internet hotspots and logging there location and getting in. It's more of a status thing than a criminal thing. It is illegal to access soomeone's network even if it is left open with no protection, believe it or not. I just read a story about a kid in England getting arrested sitting on a public bench accessing a womans wireless service from her flat accross the street. An officer aproached him and noticed he was online. Even thought the woman had left her wireless router wide open the kid was charged with theft of service. You have to be careful because networks log all connections and personally identifyable information about all computers that log onto a network. I hope you found this informative. Please take the time to rate it for me.
George
Jul 08, 2008 | Acer InviLink 802.11b (91.49C10.002)...
Belkin (F5D7231-4) Wireless Router Logo
168 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
