Question about Garden
2240 John Deere hand throttle is very hard to operate. How do I loosen up?
blueextc3221
  • 15935 Answers
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
  • 138 Answers
SOURCE: my 1997 john deere just dont run as fast and hard
check your throtlle cable ... it is very possible that if the engine runs fine just doesn't run as fast as it used to that you throttle cable has slipped in the clamp and you need to adjust it ...
Posted on Aug 21, 2009
  • 8404 Answers
SOURCE: John Deere
did you try the manufacturers web site?
another place to try is www.archive.org
Posted on Nov 03, 2009
nova2nv
  • 197 Answers
SOURCE: hand break on the John Deere LTR 180 is stuck and
To temporarily fix you need to remove brake linkage to trans.If this works you need to get it to the dealer to replace park brake rod.
Posted on Nov 14, 2009
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
Where do I find the starter soleniod on a 2007 2520 John Deere?
Peter, To find the solenoid, just follow the positive cable from the battery to the solenoid. The solenoid may be mounted right on the starter of your tractor.
Amazon com Starter Solenoid 12 Volt 3 Terminal Intermittent Duty Denso...
NEW STARTER SOLENOID JOHN DEERE UTILITY TRACTOR 2040 2240 2520 4400 820 920
Apr 11, 2016 | Garden
Need to know where the fuse is for the fuel pump for my 625i to fix my fuel pump
Troubleshooting - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM136969.../OMM136969_L013.htm...
Fuel shut-off valve turned off (if equipped). · No fuel or ... Open-circuit in wiring. Engine is hard to ... Fuel pump output not adjusted to specification. · Improper fuel ...images for john deere 625i wiringimages for john deere 625i wiring
Dec 05, 2015 | Peg Perego John Deere Gator HPX Ride on...
Where do u place the attachment lift lever on a john deere L130 r where can i find a diahgram for it
Operating - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMGX21647.../OMGX21647_K35.html
Picture Note: Console on Models L120 and L130. A - Throttle ... Put attachment lift lever (A) into the slot adjacent to desired cutting height. · Slide the height ..
Aug 18, 2015 | John Deere Garden
Replace a fanbelt on john deere 4020 diesel tractor
Most older models had the adjustment on the alternator. loosen it and push it toward the engine. remove & replace the belt. Pull the alternator away from the engine until the pulley cannot be turned by hand due to the tension. Tighten the adjustment bolt to secure it. Don't overtighten the belt.
Sep 22, 2014 | John Deere 4020 Gas & Diesel Tractor...
I wish to know which direction do i turn the bolt to take the cutting blade of a john deere ride on/ clockwise or anticlockwise?
As you are looking at the blade and bolt from under the mower, if the blade is rotating counterclockwise, then the blade bolt is standard threaded and will turn counterclockwise to loosen. If the blade is turning clockwise, then the bolt is left hand threaded and will turn clockwise to loosen. John Deere produces mower decks with both setups.
Dec 30, 2010 | John Deere Garden
No operators manual
I doubt your going to find a free manual for anythng John Deere makes let alone an older tractor. However..... You can get an operator's manual direct from JOHN DEERE by calling 1-800-522-7448 with credit card in hand.
A bit about the tractor itself. Note the links On the linked page below:
http://www.tractordata.com/farm-tractors/001/8/0/1801-john-deere-1640.html
Again.. even with a source as good as that webpage you do not see an Operator's or an Owner's manual link.
IF your doing a course at a local college, try the college bookstore first. The manual will be much cheaper than buying it from John Deere.
Thanks for using FixYa,
Kelly
Apr 21, 2010 | John Deere Tractor 1020, 1520, 1530,...
Ihave an old john deere lawn mower 21 inch #GX1458. Is the blade screw left or right hand thread
Always unscrew the bolt in the same direction of blade travel.If the blade travels clockwise,loosen bolt by going clockwise.
Mar 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 14SB mower with Kawasaki FC150V series - Throttle adj.
Hello rfbarrett:
From your Description it Sounds like the Plate that is Attached to the Carburetor (that the Throttle cable Attaches to) Thru Shaft (holds and Moves the Throttle Valve) has Loosened and is Simply Turning on the Thru Shaft and Not Moving the Thru Shaft and Throttle Valve at All.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers 14SB and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Garden
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
