Question about Hoover Washing Machines
How to clean the water pump on a hoover premier 710?
  • 209 Answers
SOURCE: Hoover Premier 10.1 kg washing machine
do you actually see the motor spinning? or think you hear it, check the belt hasn't come off, or gone slack, it needs to be fairly tight but not too tight, if the belt and pulley go round but the drum doesn't then you have serious damage and need a new inner drum hope i have helped and if i can help more get back to me, i am an appliance engineer of 20 years
Posted on Oct 07, 2007
Benimur
  • 6966 Answers
SOURCE: top loading hoover premier 710 model
If you have checked everything else, then it may be the drain pump or the "filter/catch". There is no real filter but rather is a part of the drain system. Normally it is at the very bottom of the machine. You need to remove the lower front panel. There would be 3 clips that holds it in place. Once the inside is exposed, there would be a black circular cover at the right hand side. Unscrew it out and clean the inside. It would normally be filled with water and some other "stuff" so pls have cleaning materials handy and/or anything to absorb the spilling water. You can now check the pump, the impeller and verify that indeed there are no clogs/blockage.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 24, 2008
Benimur
  • 6966 Answers
SOURCE: hoover premier 710 washing machine
It would appear that a Hoover Premier 710 is a basic 4kg top loading washing machine. Often top load washing machines would have 3 or more suspension (spring) system/shock absorber that are responsible for maintaining the upright balance of the outer tub. If the washer has been in operation for some time, it is likely that these support/suspension/spring may have developed a fault. In some other instances, it could be the mounting points of these suspension/spring that may require looking over. It would be necessary to open the back and inspect all components of the suspension system. Additionally, if one is found defective, it may be to your advantage to replace all so as to impose an equal tension/support to the tub.
Alternately, in some versions/models, it could simply be the balance sensor switch that is false triggering. Again, this would require opening the unit and determining if this switch/sensor is defective.
Posted on Jul 24, 2008
  • 21 Answers
SOURCE: Hoover Premier 710 - always fills to capacity (can't adjust water level).
my one the same, I just adjust the water level switch to 60% then it work on full level, but no flood,I hope this help :)
Posted on Apr 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: Hoover Premier 710: which inlet valve to buy?
It appears your single inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
I need the lid for hoover premier 710 4 kg.washing machine. model A6578, serial no. 091383
only from hoover agent spares , machines at the dump or washing machine repair shops who may have some as spares
Mar 28, 2017 | Hoover Washing Machines
Hoover premier 710 washing machine out of balance
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Jul 24, 2008 | Washing Machines
Hoover steamvac won't spray water/cleaning solution
Clogging of the pump that sprays water/cleaning solution is very common in Hoover and Bissell Steam Vacs. Try running a cycle of 1part vinegar or CLR to 3 parts warm, distilled water through the vacuum pumps. The heads get clogged with soap and the water pumps get clogged at the opening of the flash heater due to minerals in hard water. If you want to extend the life of your steam vac, don't use the heater unless you are using distilled water. This can get expensive, so I recommend not using the heater.
Sep 11, 2009 | Hoover F7431-900 SteamVac Vacuum
yes it's a double and in your case it's best to take it off and go to your local appliance store so they can match you to the best possible resolution. Good luck to you.
Apr 06, 2009 | Washing Machines
Top loading hoover premier 710 model
May 17, 2008 | Indesit W 123 Front Load Washer
Apr 30, 2008 | Hoover HTC243 Top Load Washer
HOOVER LOGIC 1300
you need to access your drain pump and check it for an obstruction but when you pull the hose off keep in mind it might have a lot of water in it i usually use a shop vac and pull all the water out through the drain hose before removing the hose or opening the pump sorry i cant be more specific but ive never cleaned the pump on a hoover
Mar 23, 2008 | Hoover AAA140 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
