Question about MicroBoards PF-2 InkJet Printer
Drivers for MicroBoards PF-2 InkJet Printer
Sss
SOURCE: pf-2 says out of paper when l have cd it
Yes the inks have a 1 year span. The system in the printer reads a barcode on the ink cartridges. It is located on the far left of the machine as you are facing it. Lift the cover and you can see it.
Posted on Mar 17, 2008
SOURCE: Microboards PF-2 inkjet scanner problem
Try covering the label of a regular HP78 cart (or a oem cart) with the
alumn. air duct tape... reboot the printer and the PC... and boom no
more expenive ink.. has worked for me on three DX-2 units for 3yrs+
Posted on Oct 15, 2008
SOURCE: Microboards PF-2 won't load several cd´s in array
make sure the cartridge reader is no more then 1mm away from the cartridge as it slides past! also check the microswich which is ont he print head slider
Posted on Jul 09, 2009
HansPP
  • 2510 Answers
SOURCE: I lost the installation CD
Try this site for a driver:-
www.microboards.com/support/Default.aspx?id=1310
Posted on Feb 10, 2011
techwaredist
  • 30 Answers
SOURCE: DISC STOP FEEDING AUTO TO PF-2 PRINTER MICROBOARDS
Most likely the gravity fed disc cingulator needs to be replaced. My company can replace that Microboards Printer part for you. Call 952.944.0083 or visit.
Posted on Feb 21, 2011
How do i clean the print heads
Get the manual here, and it will show you the clean function... http://www.manualslib.com/manual/103031/Microboards-Technology-Pf-2.html
Jun 28, 2014 | MicroBoards PF-2 InkJet Printer
I need pf-2 driver
Driver is available at this address:
http://www.microboards.com/uploadedfiles/support/microboards/software/SureThing.Microboards-5.2.640.0-enu.exe
Mar 15, 2011 | MicroBoards PF-2 Disc Printer
DISC STOP FEEDING AUTO TO PF-2 PRINTER MICROBOARDS PRINT FACTORY..
Jan 24, 2011 | MicroBoards PF-2 InkJet Printer
I am attempting to install my PF-2 on my Windows 7 PC using my Virtual PC and Windows XP mode. Does this work?
Have you actually gone through the installation process? I understand what Virtual PC is supposed to do, but it may not be compatible with the PF2 drivers and SureThing software. Did you try talking to someone at Microboards? If you haven't tried the installation, it might not hurt to at least try. If you have tried and it doesn't work, then I guess you're stuck. :-( Good luck!
Aug 12, 2010 | MicroBoards PF-2 InkJet Printer
Diamond_Regg: Microboards disc rolling problem
1st thing you need to do is completely uninstall then re-install the PF-2 print driver.
www.techwaredist.com
Oct 16, 2008 | MicroBoards PF-2 InkJet Printer
Microboards PFII just keeps rolling discs and will not print
Di arleady did the first thing that we advise of customers to do - reload the PF-2 print drivers. Since that did not work you a most likely looking at needing the print engine replaced. This typically costs $600+ depending on how full of ink the inside of your printer is. Hoefully your printer is still under warranty with Microboards. If not, you can call Microboards at 952.556.1639 or check ou this repair company
http://www.techwaredist.com/repairshop.asp
Only 1 copy at time
The previous poster is most likely correct. You have to use Microboards ink for the PF-2, PF-3 and PF-Pro printers. The part number you need is the PRF38ml. The PF-2 printer has a sensor for the barcode on the PRF38ml as well as a RFID chip for verification.
If this does not fix your issue, then the sensors that scan the barcode and the RFID chip may be broken, dirty or out of alignment. If so, you need to contact Microboards or an authorized Microboards repair center for repair services.
Dec 15, 2006 | MicroBoards PF-2 InkJet Printer
MicroBoards PF-2 InkJet Printer Logo
Top MicroBoards Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Tom Chichester
Are you a MicroBoards Office Equipment and Supply Expert? Answer questions, earn points and help others
