Question about Epson Stylus C48 InkJet Printer
Printer carriage is stuck at right hand side and both green and red lights are on
4 Suggested Answers
kman203
  • 99 Answers
SOURCE: noisey printer carriage clicks at left hand end loud buzzing at right hand side
Open up hatch, see if anything got stuck lick staple, paperclip, paper, etc.
If nothing found suggest replacing printer due to cost of repair.
Hope this helps.
Thanks!
Posted on Mar 24, 2008
NJFIRESTORM
  • 84 Answers
SOURCE: 1400 carriage
if the printer power light is off and the paper and ink light are flashing there are a few things you can try.
1. remove all paper from the printer.
2. lift cover and check for paper jam
3. check to see that the ink cartridge cover is completley closed. (the covers do actually pop themselves open and jam)
if none of these fix your problem then your in the hands of epson tech support. they can be reached @ 562-276-7282
Posted on May 12, 2008
  • 1218 Answers
SOURCE: Epson 1280 Solid red mainteance light
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5005876-epson_stylus
Posted on Oct 04, 2010
How can I open cartridge holder on my epson stylus photo 1400. It's stuck over on the right and red lights are flashing.
Turn on printer, and unplug power chord while the carriage moving.
Then move carriage by hand freely.
Sep 02, 2014 | Epson Stylus 1400 InkJet Photo Printer
Empty carriage stuck in my HP 7500A printer
Hello,Lester Makang
Your carriage got stuck in service station,is there any noise coming from the right side of printer then there will be broken gear.
Power on your printer,after you got carriage jam error open cartridge access door and wait 5 second when you see that gears trying to move,use your hand to pull your carriage to left side.Don't use much force.If your carriage got free then install your print head and cartridges.If this will happen again then take it to service center they will change the service station or broken gear but the cost goes much high.
Nov 06, 2012 | HP Officejet 7500a E910 Multifunction...
Printer says "Open Door Clear Cartridge Jam" How
You might wanna try removing and reinserting the cartridges and make sure that they are properly fitted in.
Sometimes cleaning the cartridge and the carriage where you took out the cartridges from with a damp lint free cloth does the trick.
If you still have that message, open the cartridge access door.
If the carriage is stuck at the right side of the printer, move the carriage to the left side by hand. If it's stuck on the left side, try moving it by hand in the right side of the printer. Then while the printer is turned on, unplug it from the wall outlet and then plug it back in.
If the printer does not turn on, use the power button.
Try printing again.
Feb 03, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
The status and power lights are flashing and the printer carriage is stuck in the far right position. There are no paper jams or any other visible problems. Any help would be appreciated!
  1. Disconnect the power cord from the printer.
  2. Open the top cover.
  3. Find the metal clip that is attached to the exposed side of the carriage
  4. Follow the metal clip to the bottom of the carriage. Straight back from the bottom of the carriage is another metal clip that is pointing toward the back of the printer
  5. Using a screwdriver or similar tool, push the metal clip (indicated by call-out 2 in the graphic below) toward the back of the printer.
  6. Gently rock the carriage up and down while pulling the carriage from the right-hand side toward the center of the printer.
  7. If the carriage is still locked in place, push the metal clip
  8. After the carriage is pulled out from the right-hand side of the printer, remove both print cartridges
  9. clean the connections and reconnect them
  10. Push the carriage back to the right-hand side of the printer.
  11. Close the top cover.
Properly storing the ink cartridges will increase their life. The following are guidelines for storing cartridges for future use.
Place the cartridges in a standard paper envelope
Jan 05, 2010 | HP DeskJet 940c InkJet Printer
Carriage won't move over to install new innk cartridge
Personally. my carriage move (ink maintenance button) stopped working within the first month...i have this printer for almost 6 years now, I just manually move the carriage over by hand
Dec 16, 2008 | Epson Stylus C62 InkJet Printer
Hi-
Is iot on the position where you can install the ink cartridge? try turning it off and unplug it from power supply then after 10mins replug and turn it back on. keep me posted, but if it will do the same thing chances are there is something wrong with the belts on it, better have it fix or have it check. Thanks for using fixya!!
Jun 26, 2008 | Epson Stylus Photo 1280 InkJet Printer
Carriage hits the right inside of printer - will not print
if the lights are flashing along together there is a cariage stall. The ink cartridge craddle is hitting something. Find out what and remove it if doesn't belong there. First of all remove and reinsert both cartridges. One of them may be inserted wrong.
Mar 19, 2008 | Office Equipment & Supplies
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Open Questions:
See all Epson Stylus C48 InkJet Printer Questions
Epson Stylus C48 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
