Question about Boating
2003 yamaha 4 stroke will not rev when put in gear,at full throttle motor remaims at idle rpm
  • 77 Answers
There are two sets of cables coming from your control box. Onne of the cables switches you from foward/neutral/reverse, and the other cable is for the throttle. either you've have some linkage come loose on your throttle cable, of the cable has broken inside the plastic tube it's housed in.
Posted on Jun 23, 2009
Mercury 150 hp 2 stroke 2003 everything runs fine with idle throttle lever engaged but when you put motor into gear i stalls idle to slow how do you adjust it thanks
If someone changed props this can cause this problem. You need to be careful that any adjustment is made for throttle rod and not for carbs if not an injected engine. You do not want to fool around with air mixture. Some throttle cables use threaded linkage and length of rod is adjustment for rpm. Others use a stop screw or hex head to move the throttle lever away from the housings.
Apr 01, 2017 | Mercury Cars & Trucks
ADJUSTING CARB ON A YZ 450 F
Hi, Anonymous the carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt it faces out towards the air filter end of the carb . The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle adjustment bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle adjustment bolt accordingly for 950-1050 rpm if necessary, adjust the air fuel mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your air fuel mixture bolt can acquire without going past 3 full turns from bottom then readjusting the idle adjustment bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Yamaha YZ450F story about fuel screw
How To 4 Stroke MX Fuel Screw Adjustment YZF CRF KXF RMZ FCR Part 1 of 2
Yamaha YZ450F Owner Service Manual
OEM parts for Yamaha
Yamaha YZ450F Owner Manual
Apr 04, 2014 | 2003 Yamaha YZ 450 F
REVS HIGH WHEN FIRST CRANK IT, GETS HIGHER WHEN PUSH CHOKE DOWN. RUNS OK AT HALF CHOKE.... TRYING TO SELL IT, RAN FINE HAS JUST BEEN SITTING UP FOR A YEAR. PLEASE HELP!?
Hi, Anonymous and the usual suspects are:
1. Throttle cables improperly adjusted or pinched.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Broken throttle return spring.
8. Damaged diaphragm or slide.
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Dirt Rider Magazine
YZ 125 Climbing high idle Yamaha 2 Stroke
How to Get Your 2 stroke Idle Perfect YZ125
Yamaha YZ125N1 Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Feb 17, 2014 | Yamaha YZ 125 Motorcycles
2002 Yamaha yzf 600 rpm stays hi when reved
1. Throttle cables improperly adjusted, pinched or need lubrication.
Motorcycle revs stay high after rolling off throttle motorcycles
YZF600R Idle Problem Rev Problem
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
Yamaha YZF600RP Owner Manual
Sep 08, 2013 | 2002 Yamaha YZF 600 R thunder cat
My 1982 Yamaha 650 maxim begins to rev around 4,000 rpm after it warms up for under 5 minutes. I have tried carb cleaner. Can anyone help?
3. Intake system air leak.
4. Fast idle choke ramp is not releasing.
5. Broken throttle return spring.
6. Damaged diaphragm or slide.
7. Faulty MAP, TPS, ATS, O2, VSS sensors or wiring/connector
Xj650 HIGH IDLE puts itself to full throttle
HELP My bike idles at 4000rpm
Yamaha XJ750 Owners Workshop Manual
http://www.carlsalter.com/pdfs/Yamaha_XJ600SK_Owners_Manual.pdf
Sep 02, 2013 | 1982 Yamaha XJ 650
Adjust air fuel mixture
YZ450 setting idle pilot screw popping on decel YZ 400 426 450
YAMAHA YZ450F Owner Service Manual
http://www.yamaha-motor.com/assets/service/manuals/2004/lit-11626-17-11_784.pdf
Jun 02, 2013 | Yamaha YZ 450 F Motorcycles
I have 1998 r1 and it's high reving on idle
Hi, Steve and the usual suspects are:
http://www.r1-forum.com/forums/101-98-99-r1-mechanical-help/291640-slow-rpm-return-idle.html
YZF600R Forums View topic High Idle RPMs
1998 1999 Yamaha YZF R1 Service Manual R1 Moto Data Project
May 26, 2012 | 1998 Yamaha YZF-R1
2003 yamaha yzf600r carbureted, When I twist the throttle (fast or slow) it sputters for a second then revs up and just sits at 4000 rpms, even if i just poke the throttle at idle it will rise up to 4...
Hi, Striker_1011 and the usual suspects are:
YZF600R Forums View topic Weird idle surge issue
May 02, 2011 | 2003 Yamaha YZF 600 R thunder cat
I have a 2005 suzuki ozark 250. the transmission won't come out of nuetral and it revs kinda high...
Hi To help you to resolve your problem first check your throttle gaz cable for damage and adjustment.. Same thing with your clutch cable see if those cable are in good shape...Then your carburetor look on the side you will find two srew H. and L. and on the top of your carb you will find another adjustment, this one adjust the gas throttle to your handle if your rpm is to hi it will be imposible to change gear the correct idle is arround 1000 rpm.. for two stroke same think for 4 stroke
Oct 13, 2010 | 2005 Suzuki RM 250
Boating Logo
180 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
