Question about Sony DAV-C700 System
How to remove protect on a DAV-TZ140 ? - Sony DAV-C700 System
HOW DO I FIX MY CENTER SPEAKER
Rear and center speakers not working - Tom's Guide
www.tomsguide.com/answers/id.../rear-center-speakers-working.html
Sep 4, 2013 - Hey guys. I bought a Sony DVD Home Theatre System DAV-TZ140 about a year ago.And it worked perfectly, but all of a sudden my center and ...
Audio Troubleshooting 101: Getting Your A/V System ...
www.audioholics.com > Home Theater Setup > Home Theater Calibration
Jul 14, 2009 - Audio Video Troubleshooting 101: Get your AV System Working Again. ... It's time to put on your propeller head and get down to the business of fixing your system and enjoying it to its ... Problem: One or more of my speakers isn't working ... your Blu-ray player to your AVR and let the played do the decoding.
Tips for fixing common sound problems - Windows Help
windows.microsoft.com/.../tips-fixing-common-soun...
Microsoft Windows
Jan 05, 2016 | Audio Players & Recorders
Sony dav tz140 displays protector
Sometimes caused by bad wires or cable shorting. Check that all cables and connections are good and retry. If it doesn't clear you might have blown / shorted an output device in the amp section.
Jul 03, 2015 | Sony Audio Players & Recorders
I can't get the tv to have the surround sound work
This effect varies greatly from one set to another, it may only barely perceptible.
Dec 25, 2014 | Sony DAV-TZ140 Home Cinema System Home...
NO DISC ERROR
The drive cannot handle a cleaning disc, senses it as some foreign object.
Mar 26, 2014 | Sony DAV-TZ140 DVD System
Region code sony dav-tz140
sorry you fix yoy problem i have the same one
Jan 19, 2013 | Sony DAV-TZ140 DVD System
Display panel says protect as soon as switched on and can get no responce from any command
The protect message is an indication that a problem was found at the final stage of the amplifier. Typically, this is caused by defective output transistors. A confirmation of this can be made by removing the speaker wires and turning on the unit. If the protect message still appears, the problem is internal to the unit and it will require repair. The DAV series of units are not the easiest to work on and replacement parts are limited. I would suggest that you get a detailed repair estimate from an authorized Sony service center. Post the results here and we should be able to walk you throught the actual repair.
Dan
Nov 20, 2009 | Sony DAV-S400 System
PROTECT UNPLUG
This is a common problem with sony it means unplug me or i will explode, it is a protection of the heat sync and usually means that a cooling fan has shorted out. If under gurentee return to Sony for repair if not under guranebntee as is generally the case check on the net for a replacement fan motor - as far as i know sony were sourcing thier fanns from Sunon there is a German based headquarters - just google sunon europe
Aug 09, 2007 | Sony DAV-DZ100 System
Sony DAV-C700 System Logo
156 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
