Question about Bosch AQUASURF Patio Cleaner
Karcher problems the circular attatchment which was working fine last year doesn't seem to spin and just leaves lines
GS550 Electrical Problems.
try carefully shorting a screw driver accross solenoid the two big nuts with ignition on . try a meter on continuity starter casing to earth
Jul 18, 2013 | 1980 Suzuki Gs 550 L
Cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Apr 14, 2012 | Sony CDP-CX300 CD Player
It's a gas water pressure karcher, I had in in storage for 3 years, it's new was used once, I wonder why it doesn't start do I have to replace the gas, they were pratically none visble in it...
I would strongly recommend that you take it to a local small-engine repair shop. When an engine is stored for that length of time, the gasoline that is in the fuel tank, line, filter and, most importantly, carburetor breaks down and leaves a gummy residue behind that will clog the system.
Jun 13, 2011 | Karcher 2500 PSI Pressure Washer
It's a Karcher presure washer K2.54, one and a half years old. Was working fine last time but when turned on now there is very little pressure through the hose and the water seems to be filling up inside...
this sounds like the seals may have been damaged inside the pump or that the water inlet/outlet could be damaged. If you take off the front cover (use a star bit screw driver) then run the pressure washer you will be able to see were it is leaking from and then you can get the right part to replace it.
Mar 16, 2011 | Karcher Garden
DeWalt 742 Flip over bench/chop saw. 110v. Approx 7 years old, and used infrequently. The saw tries to start and momentarily spins for a second or two. Then it seems to trip out 'internally', and if...
The motor or brushes are burn by symptoms you refer.If you can,try to open the saw case and look inside.At the motor check for the cooper wires and the brushes if there some "carbon like burn".
Nov 10, 2010 | Saws
Press. Washer Honda engine gx 390 will not start
did you leave fuel in it from last year, if so remove all fuel from tank, drain carb. (remove float bowl if it doesn't have a drain bolt) put in fresh fuel, check your oil level and you should be good to go. if not, please take it to a qualified tech. for carb. cleaning.
Doc
May 17, 2010 | Karcher G3025OH Pressure Washer
Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Apr 16, 2010 | Karcher Garden
Bosch AQUASURF Patio Cleaner Logo
24 people viewed this question
Top Bosch Garden Experts
roeb
George Merkley
George Merkley
Are you a Bosch Garden Expert? Answer questions, earn points and help others
