Question about Siemens Freezers
Why does our ice maker in our siemens fridge freezer overload regularly the lever doesnt seem to stop the machine from making ice, there also seems to be an issue caused by this in that the drip tray overflows during the night.
jason0110
  • 66 Answers
SOURCE: hotpoint rfa70 fridge seems not to be staying cold
just give it time as the freezer has to come down to temp first
Posted on Jun 16, 2008
Healeyman
  • 1198 Answers
SOURCE: freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
Posted on May 04, 2009
  • 185 Answers
SOURCE: The ice-maker in my Daewoo Fridge Freezer
is there ice in ice maker but it wont empty?
the ice maker has built in heater underneath. thats how the ice detaches itself from the ice maker and the fingers rotate them out.. if you have ice in the ice maker then replace ice maker
hope this was helpful
Posted on Mar 31, 2010
Testimonial: "Thank you, Matt. "
myrlex
  • 674 Answers
SOURCE: american fridge freezer siemens KA58NA50GB. Freezer not freezing
If you are not capable to do that much better to call service Engineer to avoid big damage of your Freezer.
Posted on Apr 04, 2010
heatman101
  • 43501 Answers
SOURCE: Bosch FD8709 Fridge Freezer (American Style)
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Aug 05, 2011
Testimonial: "Thank you for your generous support. I found a lot of dust under the unit, turned it off, cleaned-up, and it appears to be working at the moment."
Good day. My Samsung fridge/freezer SR-S22FTFB runs normal for the first few hours when been switched on, both fridge and freezer temperatures were set for (- 18 and 2), both fans are running and when
Hello Danie;
My name is Peter. I am a retired field service refrigeration technician.
The normal setting for a freezer is -2 to +2 degrees F., and the normal setting for the fresh food section is +35 to +40 degrees F.
You only have one source of cooling and that is your freezer. With the settings that you have, you are asking your unit to do what it is not designed to do.
The ice maker is struggling because if it is a cast steel ice cube mold, the heater beneath it is not designed for the current to break the ice cubes free @ -18 degrees F., or if you have a plastic flex ice cube mold it is too ridged to flex enough to break the ice cubes free. Normally your ice maker should dump 8-10 times in a 24 hour period.
A note on food storage. Make sure you do not overload your freezer of fresh food section to the point where food product extends beyond the edge of the shelves.
Nov 17, 2014 | Samsung Freezers
Siemens American fridge freezer with ice maker, freezer too warm and pipe that water flows from to ice maker is hot, not making ice?
That is a very bad sign, but before you unplug it pull the machine out from the wall and check to see if it feels hot back there as well. Then remove the lower cover and find the condersor fan motor. Its the only fan back there. I'd willing to bet that the fan is not running. The purpose of the the fan is draw air across the compressor and blow it through the condensor therefore lowering the temperature on both parts. When its not working/ running, the heat from the compressor and the condensor is pass onward to the machine and the machine then acts as a heat sink
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 11, 2012 | Siemens Freezers
The ice maker is no making ice. There doesnt seem to be any water in the line. What do we do?
dear sir/madam
please make sure first freezer compressor is working if its,s working and still low cool then it can be low gas problem please contact to your maintenance personnel for refill the gas,
hope answer the question
please vote!
Aug 31, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
American fridge freezer siemens KA58NA50GB. Freezer not freezing
Apr 03, 2010 | Freezers
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Not making ice
need to check your water supply...if good then see if ice maker has water in the maker itself. if not then replace ice maker
Jun 22, 2009 | Freezers
Freezer stopped making ice two days ago. Today fridge and freezer warm
May 04, 2009 | Freezers
ICE MAKER MOTOR RUNS CONSTANTLY AND WONT' TURN OFF ICE IS FULL
It's not too difficult to remove the ice maker. A few screws and the unit will unplug from the fridge. Then you can see why the bar is not turning it off. If it's really broken, check pcappliance.com for parts or a replacement unit. Meanwhile the fridge can keep on working, and you can use trays to make ice.
May 03, 2009 | Jenn-Air Freezers
Freezers Logo
143 people viewed this question
Top Siemens Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Phillip Hicks
Phillip Hicks
Are you a Siemens Freezer Expert? Answer questions, earn points and help others
