Question about BSRSoft BSR Screen Recorder
Serial key for max recorder 1.026 - BSRSoft BSR Screen Recorder
Serial key should be on the box or in the package it came in. If you purchased the software via digital download, you should have received an email with the serial number.
Apr 06, 2014 | BSRSoft BSR Screen Recorder
Tip
Getting the highest value in a column less than some other value
This is good really for SQL Server, Oracle, or anything that can handle SQL.
Most hacks know about MAX(), as in:
SELECT MAX(col_name) FROM table
So if the column has a max value in it of 10, you get 10 back. But what if you want the highest value in the column that is less than a certain amt.? This for example is good for getting back the next most recent record when col_name is an incrementing key column and you want to exclude the most recent record (ID'd by it having the current maximum value key) in the column. Now you are faced with writing an SP or egad, traversing a recordset client-side. Ugh.
Here's the fix:
SELECT MAX(col_name) FROM table WHERE col_name < {some_value}
This works. It works even when the key column is not guaranteed to have continuous sequential values, such as when records are added and deleted over time and the key values assigned all stay the same (which is what happens in 99.9999999+% of all cases).
Have fun.
Homework: Haven't tried it but I am betting you can also do this:
SELECT MAX(col_name) FROM table WHERE col_name < MAX(col_name)
Whoa... well, try it and see if it works. Some SQL interpreters don't like aggregation/sub-computational functions on the right side of the comparator. In that case, you'd get MAX(col_name) first with a simple SELECT stmt., assign it to a variable, then use that variable as the right hand side modifier for the '<' comparitor.
Seems simple, right? But oh, the pain these kinds of situations cause. Hope this helps some of y'alls.
on Mar 26, 2008 | Microsoft SQL Server Enterprise Edition...
Serial key
if d 000-0000... serial no. and 00000 product key doesnt work den wat shuld i do (3dsmax)
Aug 30, 2013 | Autodesk 3ds Max for PC
Keygen/serial key
Contact the software manufacturer or distributor, they will be able to assist you. Otherwise the serial number will have been provided on the paperwork that came with the software when purchased.
May 01, 2013 | Mediaccurate Desktop Video Recorder
Register code for boldbeast 3.4
IMEI NO of my phon is 357022041700165, i wanna reg code for boldbeats recorder 3.40 .. thnx...
Sep 03, 2012 | Nokia E5 Cell Phone
Face of max serial number
I'm sorry but this is not a warez site...We do not give out activation keys or access codes.....
Jul 11, 2012 | Computers & Internet
HOW TO GET BOLDBEAST RECORDER REGISTER KEY
my phone is Nokia is N8. Please send me boldbeast recorder v 3.40 imei no-352847056297953
Jun 06, 2012 | Nokia N79 Cellular Phone
I need a valid serial number and product key for 3ds max 2010
if d serial no. whch u sed 000-0000.... and product key 00000 is not working n givng 30days trail den wat shuld v try? pls ans as soon as possibl
Aug 05, 2011 | Autodesk 3ds Max for PC
Autodesk 3ds max 2010 serial number
i need the serial number and product key
Apr 11, 2010 | Autodesk 3ds Max for PC
Max payne cd key
hope this helps...
http://www.ddlsite.com/max-payne-crack-serial-keygen-rapidshare-download.html
Jun 09, 2009 | Macsoft Max Payne for Mac
Computers & Internet Logo
137 people viewed this question
Top BSRSoft Computers & Internet Experts
David Payne
David Payne
Are you a BSRSoft Computer and Internet Expert? Answer questions, earn points and help others
