Question about Garden
Yardman dx70 wont start no noise when I try start it ?
Mower worked when person delivered it but nothing sin ce been switched iff, no noise at all when I turn the key,
5 Suggested Answers
SOURCE: could anyone help me with manuals for mtd yardman dx70 ride on mo
My HE4160 goes like hare in reverse and like a turtle forward.
Any drawings showing how the springs are fittted behind the left back wheel.
tks
Posted on Aug 07, 2009
Testimonial: "Thanks for the tip."
buffalonyman
  • 1865 Answers
SOURCE: mower sometimes will not start. Has new battery
You have to use a volt meter and test the ignition circuit to find out where the voltage stops. If you have 12 volts going in to and out of the switch, then switch is good
Posted on Nov 02, 2009
  • 13 Answers
SOURCE: nothing happens when you turn on the lawn mower
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Posted on Apr 16, 2010
  • 100 Answers
SOURCE: I have a john deere LT 150 that will not start. When you turn the key nothing happens. I've checked the seat switch , the mower engage switch and a new brake/clutch switch. Battery is good. You ca
you have a safty switch problem you have 4 to 6 switchs the easest way to test them ,startin with the seat get a ohms metter they are open or noramly closed
Posted on Oct 25, 2012
Can anyone help me and tell me the part number for a blade for a dx70 Mtd yardman 8.5cc
Duncan, Blade #, MTD Part No 742-0578, 27.5" should be replacement bade for Yardman DX70. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GENUINE 27 5 Blade for Yardman DX70 MTD Beatle Lawnflite 503G Ride on Mower
YARDMAN DX70 MODEL 310 SINGLE BLADE MOWING DECK FG424 5900
Yard Man 13A 325 402 Operator Manual
May 21, 2016 | Mtd Garden
Mtd yardman
There is probably a switch in the reverse lever that shuts of the mower. It is probably a normally open switch so when you pull the lever to reverse it pushes the switch closed killing the engine. If you unplug the switch or cut the wires going to it, it would never think it is in reverse and you could always mow.
Feb 03, 2014 | Mtd Garden
Yardman model 131784GWhere exactly is the safety switch??
there will be several. one is under the seat that works when you are sitting down one is on the gear lever so that unless you have the brake on it wont work and one will be on the cutter lever. they are relatively small around 2" long about 3/4 " high and maybe 3/8 " wide. with a lever or button on one side and 2 wires
Jun 03, 2013 | Garden
Yardman mower
Try this. Disconnect the one single wire going to the solenoid. Use an ohm meter to see if there is 12 volts DC at this wire when you turn the key switch in the start position. If you have voltage then your solenoid is bad and needs to be replaced. If you dont have voltage, check the safety switchs for proper operation.
Apr 27, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
Blades will not turn on lawn mower
You haven't given enough information of the problem. The blades themselves wont turn when you try to spin them by hand or they wont turn when you engage them with the lever or the switch?
Jan 11, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
Pto won't engage after it had stalled out when in reverse
Did you take it out of reverse? You need too look closer at the linkage and at wear it gos, look for the switch on the trans mission, it going to work one of two ways positive or negative if it work from ground unplug it and see if it will work, if it doesn't try running a wire from one side of the connector to complete the circuit .
May 18, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
Could anyone help me with manuals for mtd yardman dx70 ride on mo
tks
Apr 04, 2009 | Mtd Garden
Garden Logo
11 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
