Question about Epson Office Equipment & Supplies
Cannot open port switched offline mode x700
Why does my new epson xp700 always say offline when its clearly online
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
This happening is dew to usb port conflict. any other usb devices also you have then make them on and connect. then uninstall your printer driver and reinstall it. if you have knowledge in hardware then, you can solve this by maintaining usb port setting.
Posted on Jan 03, 2015
Lipi6306 matrix printer not going to offline mode always in online configure 1
step 1 : change the panel cable
step 2 : change the control panel
step 3 : download firmware as follows :
T6306 FIRMWARE DOWNLOADING PROCEDURE
  1. Connect the printer to pc through parallel port.
  2. Press "FF + ^ + CONFIG" at the control panel and power on the printer .
  3. Panel will show "ready to download".
  4. In dos mode type "vdv3000r -pb" and enter .
  5. After completing the firmware loading printer may show NVRAM fault.
  6. Press "CLEAR"and printer will restart to finish.
Mar 02, 2014 | Tally Line Matrix T6050 Printer
Why does my epson nx100 printer always show up as offline when I try to print to it on my local network
Go to control panel>printer>find that particular printer icon and right click it. Left click use printer online...exit out. Hope this clears the problem up.
Jan 05, 2011 | Epson Stylus NX100 InkJet Printer
Cannot connect internet as it shows internet is offline
Always check your LAN cable between your modem and the router and try a new cable. Login the make certain your router is configured correctly to connect to your mode.
Jul 13, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Epson Aculaser CX11NF Printer is offline
you need to go to settings ,then printers then right click from your mouse on your printer ,then put it online..thats it...i hope it will work..
Mar 25, 2010 | Epson ACULASER CX11NF All-In-One Printer
Windows says printer offline, but it is not offline. network settings confirmed. windows firewall turned off. scanner works perfectly over network, but printer is "offline"
The printer offline error mostly troubles windows 7/8/10 users, The printers loses connectivity even when it is connected and operating. The status message displays offline on the computer, and the printer does not print. An Offline status indicates that the computer has failed to communicate with the printer. In some network conditions, the printer might get offline unexpectedly.
Before going to the solution for this you must know when and why printer offline error takes place:
The error may appear when Windows 8 diagnoses that the printer is unavailable, but unfortunately, most times it fails to tell whether the printer is really offline or if it has connectivity problems or printing errors. Reasons why your printer appears to be offline, include problems with hardware, such as disconnected cables or malfunctioning equipment, and problems with software, such as corrupted or incompatible driver files.
These might occur when:
1. The connection between the computer and the printer is slow/unresponsive.
2. The printer has encountered an internal error
3. There are multiple unfinished print jobs in the queue.
There are some simple steps you can follow before going to any complicated way:
Your printer offline can be a problem with the driver software. This is a small piece of code that Windows and the printers use to "talk" to each other. If the driver software is outdated, corrupted or incompatible with the version of Windows that you have installed, you may need to update it.
Restart the printer and the computer or unplug its USB cable.
Do check that the printer's power cable is plugged into an electrical outlet. If the printer is connected to a power strip, make sure the strip itself is connected to the electricity supply and is turned on.
In case you are using a network printer both wired or wireless, You restart the router as it may cause due to network failure.
Different manufacturers come with their own diagnostics software which can inform the user about the problems coming up (Ex : HP's Print and Scan Doctor), Use it as it will be really useful.
PRINTER OFFLINE ERROR Solution 1 :
Type in Services in your windows searches and hit the enter key. Click on Services option from the set of search results as shown below.
A new window for Services opens up. Scroll down and find the entry named Print Spooler.
Now right-click on Print Spooler entry and then on Properties option.
Set Startup type as Automatic from the drop-down menu.
As next, hit the Start button and wait till windows start the Print Spooler. Once done, hit Apply button.
Now if you look at the status of the Print Spooler, you can see that it is Started.
Solution 2 :
If the above method doesn't work for you, you can always try our second method. For that, type in Devices to the windows search and choose Devices and Printers from the search results.
Now find the printer that is offline and right click on it. Click on the option See what's printing from the context menu that appears.
A new window opens. Now click on the Printer tab and uncheck the option that says Use Printer Offline.
Aug 04, 2009 | Canon PIXMA MX850 Multifunction Printer
Program is switched offline, cannot open port
Sir please go to your computer settings here are the option given bellow go to start>control panel>add hardware and then connect your mobile and click on add hardware.thanks
Jun 01, 2009 | Samsung SGH-D500 Cellular Phone
Printer is offline
go in control pannel> printer> right click on your printer there was option use printer online click on it
Jan 17, 2009 | HP Deskjet 3915 InkJet Printer
6630 offline
press the side button or check the phone's user profiles, there you will need to select the phone to connect online.
you will need to set your phone to become connected
Nov 22, 2008 | Nokia 6630 Cellular Phone
61 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
