Question about Milwaukee 6950-20 12-inch Dual Bevel Miter Saw w/ Digital Miter Angle Fine Adjust
How to change the blades on milwaukee ms 305 DB compound mitre saw
How to replace blades
3 Suggested Answers
  • 39 Answers
SOURCE: Is there adjustment for the blade on 6320 milwaukee ban saw
Your rubber tires probably need to be replaced. Also when your blade is off are the pulley wheels loose at all? If they are tighten them up. Make sure your roller bearings are also rolling.
Posted on Apr 24, 2012
  • 39 Answers
SOURCE: blade comes off milwaukee 6230 ban saw
Where do I get a bushing for the guard on a 10 inch mcculloch mitre saw
You probably mean a Milwaukee mitre saw. McCulloch does not make a mitre saw. Go to eReplacementparts.com and enter your make and model number. If they don't have it, its probably not available anywhere. You'll have to go to a machine shop instead. Look it the yellow pages for "Machine Shop".
Oct 04, 2014 | Saws
Milwaukee magnum miter saw blade change
See page 9 of this manual: http://documents.milwaukeetool.com/58-14-6955d3.pdf.
The manual is for a 12 inch saw, but the instructions will be similar. UNPLUG THE SAW FIRST!
May 10, 2014 | Milwaukee Tool 10" Magnum Compound Miter...
How do you replace the blade on as Protech 8 1/4 inch compound mitre saw? i can't get the blade to stop spinning and i can only get to one side of the attachment bolt.
there should be a spindle lock on the opposite side of the blade bolt,, make sure that when you replace the blade that you install the flanges correctly and if there a spacer that it is in place.
Dec 22, 2009 | Bosch 12" Compound Miter Saw 3912
How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
May 29, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Solution for "changing blades on a milwaukee miter saw
Have you removed the old blade yet?
The blade lock my be broken off -- it should be a button on top of the motor.
This saw has left hand threads -- turn clockwise to loosen the bolt/nut.
If you can't find the blade lock, lower the saw onto a piece of wood llike a 2x4 to keep the blade from turning.
May 02, 2009 | Milwaukee Tool 10" Magnum Compound Miter...
Mitre saw won't cut square
You will have to use a regular square to check out the crafstsman and find out where it is wrong.
Jan 16, 2009 | Bosch 12" Dual - Bevel Compound Miter Saw...
How to replace lockdown pin DW708 12" sliding compound mitre saw
you are going to have to drill the inside pin out. be sure to center punch and drill a pilot hole. hope this helps
Oct 26, 2008 | Saws
Milwaukee 6950-20 12-inch Dual Bevel Miter Saw w/ Digital Miter Angle Fine Adjust Logo
56 people viewed this question
Top Milwaukee Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Jim London
Jim London
Are you a Milwaukee Saw Expert? Answer questions, earn points and help others
