Question about Case Logic Wired Keyboard Black KD-600
No start
Re: Microsoft wired 600 keyboard/sticky keys... Wanting to know how do I enable sticky keys on my Microsoft wired 600 keyboard pls?
Sticky Keys is a software function. I am assuming you are using Windows - open the Control Panel, select the Ease of Use Center, select Make the keyboard easier to use. In here, you can turn on and setup Sticky Keys.
Dec 21, 2016 | Microsoft Computers & Internet
When I press any key, why does it repeat?
Look at the keyboard set up in control panel. You may have the repeat key set up too sensitive
Aug 08, 2015 | Logitech 920002232 model G110 Gaming...
How do I unlock the keyboard
Wired keyboard usually do not have locks, However some wireless keyboard do. A switch is usually on the top side of the keyboard that slides back and forth.
However you may also be seeing "Caps Lock" which means the Caps lock key is engaged. Simply press the "Caps Lock" key again to unlock it. The caps lock key is located at the left side of the keyboard.
Dec 12, 2014 | Microsoft Wired Keyboard 600
Comfort curve keyboard 2000
Have you tried my solution for keys not working here?:
http://www.fixya.com/support/t3015431-microsoft_comfort_curve_2000_v_1_key
Mine is toward the bottom, with the video
Good Luck
Jan 07, 2013 | Microsoft Comfort Curve 2000 Keyboard
My microsoft wired keyboard keeps freezing
Sub out your ram memory one at a time, it looks like you have a bad stick of ram.
Apr 21, 2012 | Microsoft Wired Keyboard 600 Usb...
I cant use the number pad on my keyboard microsoft wired keyboard 600
Dear chilos,
Just check whether Num lock key is on/Off.
Make it ON and try
Cheers
Jun 14, 2011 | Microsoft Wired Keyboard 600
Wired and Installed a jvc KD-R610 deck in my 95 mustang and deck will not turn on
You should verify your wiring .Also check all fuses. that is on the radio and for the power wire (red) .
May 12, 2010 | Car Audio & Video
My Microsoft Wired 600 keyboard has suddenly malfunctioned and the keys "1" "Q" "A" and "Z" (as far as i know these are only ones) just wont work anymore, help?
Well, it's in a bad shape, but if you still wanna fix it, try remove all the nuts, then see for the rubber connector inside it, clean it with soft cloth and alcohol, then on the electronics board, clean it with it too.
Also recheck the PS2 connector ( if using PS2 ), sometimes this cause the problems.
Oct 23, 2009 | Microsoft Wired Keyboard 600
Case Logic Wired Keyboard Black KD-600 Logo
54 people viewed this question
Top Case Logic Computers & Internet Experts
Lawrence Oravetz
rdjagger
Are you a Case Logic Computer and Internet Expert? Answer questions, earn points and help others
