Question about Polaroid FLM-2601 Television
What would cause no 24v power from power supply?
Power supply has standby 4.99v. what would cause no 24v supply?
    Problem Solver:
  • 23 Answers
Hi aqhnc,
You need to change the whole power supply unit. Your transformer inside it might broken and need to fix.
I hope my solution may help you.
Thanks for using Fixya...;-)
Posted on May 06, 2014
Bought a new power supply and now screen is black power supply has 52.7v going to the inverters but it should b 24v can someone help
leakage current problem because this cause to increase the current, indication of some short capacitor, diode short, etcTest the resistance method by to findo the problem or use the current method to isolate the problem. use the schematic diagramGod bless you
Apr 05, 2013 | Olevia 42" 242-t11 1080i widescreen hdtv...
Power Supply Issue - Green LED ON..no power up
tried to disconnected the 24v supply connectors going to the power inverter board which may the cause of voltage drop. after you disconnect then if still no output 24v dc coming from the power supply board the cause will be bad power supply board. check for an open resistance or bad regulators going to the 24vdc out. by the way you should connect all the connectors going to the main board to turn on the processor and the inv_on voltage going to the inverter board.
Nov 01, 2012 | Toshiba 65HT2U 65" Class Full HD LCD HDTV
Cant start my sharp aquos tv
does the power supply board has complete output dc voltages?.if yes, check the 24v dc voltage supply at inverter board if drop to low voltage then the cause will be the inverter board.
Jul 26, 2012 | Televison & Video
Hi there, i have a baird lcd model j047baird\r\nthe fault i am having is, it stuck in stby. power supply look fine all voltage is there. if i disconnect the lead j5 from main board to invertor the screen...
there is 2 problems that makes this tv have standby fault.. so here they are,!
1.)main av board ---the 8 leg eeprom loses programing just under LVD CABLE TO SCREEN -£14.99 from a guy or if you can program yourself 4.99 for the flash to reprogram,.
2.)POWER SUPPLY FAULT IS MLT199TL PSU. (UA4)AREA, SG3525AN (16 leg) Regulating pulse width modulator.
the first fault all votage at psu will be there ,, 5v / 12v / 24v
the second fault psu will have 5v standby but no 12v or 24v this will stop the secondary from fireing up.. hope this helps.
Jul 31, 2011 | Televison & Video
How do I tell if my power board is out
You can check that the power supply is getting power from the power cord. then check the fuse on your power cord. Last you can check the output power of your power supply. You can get parts from www.interliquidparts.com
Jun 08, 2011 | Memorex MLT3221 32 in. LCD TV
I have a Bush 26" lcd tv. when i try and power the
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Can't answer more than this without any details.
Mar 27, 2017 | Televison & Video
When i go to turn my tv on all it does is blink that it is in standby mode. The individual i got it from had a surround sound system hooked up to it and i dont know if they have a remote. They are looking....
The first thing you need to do is to check whether your power supply is working well.
To do this, you need to open the back cover of your tv.
You can immediately reach the power supply. Test the power output using a multitester. There must be an output of 5v,12v, and 24v.
24v is for the screen to lit up.
5v is for the the cpu supply.
12v is for the audio...
You can repair the power supply if it is not functioning or buy a new power supply.
To repair the power supply repace the regulator transistor,the opto isolator, the ic that gives the signal to the opto isolator and check for open resistor near the regulators.
I hope this will help.
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Please tell me about power supply problem and solving diegrame
The power supply for HDTV is the board where the AC plug goes into. It is a very sensitive circuitry that can be easily damaged. Under normal circumstance it is very reliable. This is how they work basically. The AC current is rectified (converted into DC). Then filtered by means of large capacitors. The DC Voltage ( about 180 DC volts from 120 AC) is supplied to power transistors (usually FET or field effect transistor). The Transistor are switched at high frequency( usually over 100KHZ or 100,000 times per second) Which drives the transformers to step down the voltage. When the TV is off there is a standby voltage which is on at all times, and it is typically 5V. This standby voltage is the first thing a technician check for when troubleshooting power supply problem. When the TV is turned on everything in the power supply comes to life supplying power to every circuit boards which are of diffrent voltages such 12V, 24V etc. HDTV power supplies are very complicated using the latest technology employing power saving chips that minimize power usage on standby mode. Explaining the it in great detail would require many pages but this is just the basic.
Jun 26, 2010 | Sampo PME-42V3 42 in. Plasma Television
Polaroid 26inch lcd tvred standby light on but power wont turn on. I've unplugged the tv, changed the batteries in the remote. The tv stays with the red standby light only.
You need to open it up and checking the voltages in the power supply sections, you should have 5v (for logic circuits), 12v for sound, 24v for backlight inverter circuits. Look for bad caps with bulging tops in power supply also.
Jan 12, 2010 | Polaroid FXM-2611C 26 in. LCD Television
Polaroid FLM-2601 Television Logo
54 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
