MPC2500 CONTROL PANEL DEAD - Office Equipment & Supplies
SMTP Scan to email problem on a Ricoh MPC2500
Ricoh scanner uses a email account to send the scan to email. That email account has the wrong password on Ricoh settings, probably someone changed the password and now needs to be updated. I hope it helps.
Apr 29, 2014 | Ricoh Office Equipment & Supplies
12 RES - Control Panel Dead With New Battery
If it won't start in manual, you have a short and/or a bad control board. Make sure battery polarity is correct, did you disconnect battery charger before removing old battery? If not charger can push DC volts over 20V and can damage control board.
May 26, 2013 | Kohler Electrical Supplies
MPC2500 my machines are saying INDEPENDENT TONER.
This happened when you take of the toner bottle, replace a new bottle and that put it again the bottle that as bean there before.
You can enter in SP mode and disable this messages.
Try this:
press yellow key
press 107 in the key pad
Old the red key at least 3 sec.
After that press "COPY SP"
Press on the key pad 5051001 and than #.
Press the OFF button and than press OK on the bottom.
Exit all the way out and reset your machine by turning OFF and turn ON.
Hope that helps.
See you
Apr 23, 2011 | Ricoh Office Equipment & Supplies
Mpc2500 mode button snapped off. i opened the mpc and removed the mode button. How can I get a new button?
You might try this site:
http://www.mpcstuff.com/mpc2500stuff.html
If the shaft/actuator snapped off a part on the board, then you will have to do unsoldering and soldering. Removing solder from the boards without the proper tools may damage the circuit board.
Jan 03, 2011 | Akai Mpc2500 Music Production Center
My MPC play back something entirely different from what I record. It appears to record the pad hits late.
Here is a link that may help you:http://www.akaipro.com/tipsmay09 Here is a link to the latest updates, manuals etc:http://www.akaipro.com/mpc2500
Oct 25, 2010 | Akai Mpc2500 Music Production Center
Os update promblems mpc 2500
Try this site:http://www.akaipro.com/mpc2500 Try downloading all the the release notes for ver.1.24 if you haven't already. Download the ver.1.24 which seems to be the newest to your computer first and install from there. It might have gotten corrupted the first time you tried it. You will have to email them using the form for the newest release notes and the installation instructions:http://www.akaipro.com/mpc2500 http://www.akaipro.com/content1924.html and http://www.akaipro.com/mpc2500 are the URLs you need. Hope this helps.
Apr 16, 2010 | Akai Mpc2500 Music Production Center
How do i load and chop samples
Try asking these guys( they'll help even if you didn't purchase there):http://www.sweetwater.com/store/detail/MPC2500 Also I'd recommend joining this forum:http://www.mpc-forums.com/
Mar 04, 2010 | Akai Mpc2500 Music Production Center
How do you earse internal memerory
http://safemanuals.com/user-guide-instructions-owner-manual/AKAI/MPC2500-_E This is a free download. Try pages 14 and 15 also 23 also44 also page 66 also 83 also 90(purge samples) 103 (memory cards) 11 formatting page 108 deleting data in memory before loading, I'd suggest page 112 (save the contents by backing up to computer) then wiping the memory card. I don't have one of these units and I see the hard drive is an option which I don't know if you have. Read the manual from beginning top end and always save your work before deleting anything. Hope this helps.
Aug 05, 2009 | Akai Mpc2500 Music Production Center
RAM MEMORY SLOT EARS BROKE OFF--MPC2500
Replacing the slot on your machine will no only include soldering, but you're talking about soldering AT THE VERY LEAST 168 connections. When a slot goes bad, it is not deamed a "repairable" situation. The best solution, unfortunately, is to replace the motherboard and salvage the processor, ram, etc.
Cheers!
-E
Feb 02, 2009 | Akai Mpc1000 128mb Ram Expansion System
20 people viewed this question
k24674
