Kenwood Suzuki Swift Dzire Steering Wheel Interface Adaptor Stereo Patch Lead Logo
A
Anonymous Posted on May 05, 2014
Error code p1600 - Kenwood Suzuki Swift Dzire Steering Wheel Interface Adaptor Stereo Patch Lead
I have a 95 Lexus es300 and it's throwing a code p1600
All the infoemation about this fault code is at the link below. P1600 Lexus ECM BATT Malfunction
2answers
How can Toyota code p1600 be fixed
hi i wish i knew if the car had more codes or if it runs good with this code you should be having some other problems because this the main battery supply to the ecm and the memory retention voltage sourse for the computer that is fed by a fuse in the fuse box so i would check all of my ground wires and check to see if any wire is damage or threding
Engine code P1600 and P1449
Hi:
The P1600 code is usually a IMA fault, and the P1449 code is a battery deviation fault.
Both are usually early warning of some sort of hybrid battery issues.
You need to have a system tech give the hybrid system a good look over, but most likely your IMA battery pack is most likely suspect
Engine code P1600 and P1449 what do they mean?
P1600 IMA system malfunction. A P1600 code is a generic code that is set in the engine computer to tell you that there is a Hybrid system problem. In order to find out what is wrong with the Hybrid system, you will need to take the vehicle to a Honda dealer so that they can read the code in that system.
P1449 Battery module,battery module deterioration, battery module overheating, battery cell overheating. Either way you need to take the car to a Honda dealership to find out the actual cause of the P1600 and replace teh battery module
I have a honda civic hybrid 05 VIN: JHMES96605S024356. I had my engine light on as well as my IMA battery. I went to check it, got a p1433 and p1600 code that one of MIDAS mechanics told me to go to t
Hello there,
Apparently, from here http://www.greenhybrid.com/discuss/f50/help-p1600-p1433-28749/
This means the battery is on the way out !!!!!
and here another forum
' Okay got your answer. p1600 is generic telling you there is a manufacture specific code and that becasue of the p1433.. This code is becasue of weak batteries. You will need to plan on battaries soon. They are spendy.'
And here http://www.automotiveforums.com/t1037023-discuss2005_hybrid_with_recurrent_engine_ima_lights.html
Sorry friend this is gonna cost thousands :(
This battery guy says he will provide assistance http://www.hybridbatterysolutions.co.uk/common-fault-codes-honda-civic-hybrid/
1helpful
Honda civic hybrid code p1433 and p1600
The P1600 is a generic OBD II code. It just means that a more specific code (Honda) has been set. To find the specific code you have to take it to the dealer or have a Vetronics Mastertech scan tool to get the actual code. The P1433 indicates thats the the main battery contactor or the by-pass contactor is staying active when it should not. Using an Actron pocket code reader will only read generic OBD II codes. Hope this helps.
How do i get the code to activate bd-p1600 to netflex
  1. Connect your device to the internet
  2. Find and start Netflix on your device
  3. Netflix will provide the activation code on your device
  4. Go to Netflix and enter the code at the "instantly to your tv" tab.
2helpful
P1600
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
