Question about M-Audio FastTrack Recording Interface
My m audio fast track usb the signal for the mic peaks out when the mic isnt connected when i connect the mic it works for 2 seconds then cuts out i have all the right drivers tweaked my comp just for music production and nothing
  • 74 Answers
Sounds like you need to check that you have phantom power switched on. that could be your problem, make sure its on for a condenser mic
Posted on May 06, 2010
No output signal for vocalist live 3
If the mic is a low Z- mic, that might be the issue. Check the mic straight into the sound card of the mac and see if it works or if it is shorted. Is there a switchon the mic? it may be dirty.
Jan 28, 2012 | Music
My m-audio fast track usb interface has been working but all of a sudden lately my computer recognizes it when I plug it in but the interface will not pick up a signal from a direct line or from a mic so I...
Hello, try going into Sound & Audio Settings through control panel. From there, click on the Audio Button. Toward the bottom on the left, UNCHECK the box that says 'USE ONLY DEFAULT DEVICES'. Then Under RECORDING section, pull down the drop menu and select M-Audio. And Click APPLY & OK to close. I would reboot and it should be working after that.. ok? Good Luck & PLEASE DON'T FORGET TO RATE MY SUGGESTION, OK? THANK YOU :)
Oct 19, 2010 | M-Audio Fast Track USB (FASTTRACK) Audio...
I have a mic Behringer C1u and would use it with an M-Audio fast track usb interface. How can I do it?
You will need to turn on the phantom power which will be a switch labled eithe PHANTOM or +48V to use the condenser mic. YOu MUST use an XLR to XLR cable.
Sep 10, 2010 | Behringer C1U Microphone
How do we connect an m audio fast track pro to my pc and mixer (dp-01fx)?
All you have to do is to connect with 2 cables your mixer's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Anyway in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 20, 2010 | M-Audio Fast Track Pro Mobile USB...
Connecting an M Audio Fast Track USB to a Behringer XENYX 1002
I suppose that you connect the behringer mixer master out (just one of the two channels in case of two) to the guitar input of the Fast Track. Have you tried to hear your mic from the phones output at the front panel of the Fast Track? Try changing the guitar gain and the output level at the top of the Fast track.
I'm waiting for your results or clarification, please post.
Thanks and regards
Stelios
Oct 21, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
No sound recognized in Audacity from Fast Track M-Audio
First thing is what operating system is on the computer.
Second is what does device manager say about the recording interface?
Third in audio properties from the task bar icon, what is the default device for recording?
Feb 23, 2018 | M-Audio Fast Track USB (FASTTRACK) Audio...
Using m-audio fast track usb with Behringer mixer
Use the taope outs. They're the RCA plugs located in your manual as "20".
Sep 01, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Low record level for guitar
first of all you want to have your guitar amp at a decent volume but too loud, just enough to be able to get a good signal. when you have done this turn up the gain on your mic channel so that your VU meter (level meter) on the recording software shows a reading of about half way up the meter. If you can not achieve this with the soundcard alone increase the gain on your channel in the software.
This sound guarantee a good signal but as with most recordings you will still have to boost the signal without it peaking. to do this use a compressor or a limiter and turn the gain up. if you use these dynamic effects correctly you will achieve the guitar level you want.
Jan 25, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
M-Audio FastTrack Recording Interface  Logo
112 people viewed this question
Top M-Audio Televison & Video Experts
Paul Bade
Are you a M-Audio Televison and Video Expert? Answer questions, earn points and help others
