Question about Samsung Televison & Video
Pn50a450p1d Plasma tv has poor picture quality even when i change the settings. Fuzzy like it has too much contrast.
Highdefjeff
  • 124 Answers
SOURCE: Sharp Aquos LC-65D64U Picture Quality
You need to change your TV's settings and enhancements. Directly from the store and out of the box, the settings are adjusted for easiest sell in the store. That means that:
Your contrast is cranked to 100. Move this down to 50 to 60.
Your brightness may also be cranked up high. Lower it to a level nearer the middle range but not so dark as to lose detail in the shadows.
Your TV is set on "Dynamic" or "Vivid" mode. Pick "natural" or "normal" or standard.
Your sharpness is at least on, if not cranked up. Turn sharpness down or off, and the same with "Edge Enhancement" and "VSM", all to off.
Lastly, I bet you upgraded size and you are now sitting too close to the TV. Roughly, if you are sitting closer than 130 inches (about 11 foot) you might do some rearranging or save some money and get a smaller TV.
Posted on Apr 08, 2008
Agent Dort
  • 216 Answers
SOURCE: HDTV has fuzzy picture
Greetings blueberrie,
Many times the cables that you are using can contribute to picture quality. You will want to utilize the best connection possible, in most cases HDMI or component cables. Also, you may want to invest in a line filter, sometimes known as a surge protector. Many of these items are able to control the inconsistencies in power your unit receives, giving you clean power, which will influence picture quality.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Posted on Jun 23, 2008
  • 5 Answers
SOURCE: Best Picture Quality
Check this link out. I think it should give you all the info you need for optimal picture settings.
http://help.cnet.com/samsung_LN_T4061/9602-12576_39-0.html?messageID=2510125&tag=tip-2510125&kw=samsung+LN-T4061
Posted on Jul 15, 2008
  • 11 Answers
SOURCE: Picture settings
The settings is on the remote (menu)
Posted on Jul 31, 2008
  • 92 Answers
SOURCE: LG 50PX1D Plasma TV with dark and fuzzy picture
Z-Sustain PCB will cure it.
It is inside the TV, on the Right Hand Side.
www.chsinteractive.co.uk or Google for a replacement.
Posted on Sep 08, 2009
What are the best settings so that i can get the best picture from samsung plasma tv model PS50A457P1D?
hi can i just add? I have recently got this tv but for some reason when i set setting to Normal they reset to dynamic?? After about twenty mins? I keep having to change back to normal or if i set it to perfect brightness etc... it just goes back to dynamic again? i.e cell light 100% and contrast up to 100%!
Why is this??
Mar 09, 2012 | Samsung PS50A457 50 in. Plasma TV
Poor picture and colour quality on hd through hd box red is pink fuzzy hd picture
You need to check the resolution of your TV thru your input setting, try to check which will give better picture quality between 1080 or 720 settings. Also secure that your input setting as either HDMI 1 or 2 or 3, you can use the original remote and change setting by pressing input in cycle.
Jul 08, 2011 | Televison & Video
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
Just bought the Samsung 550 Plasma Hd Tv can you tell me if we just use a regular cable from the wall to the Tv will the picture quality be sort of off.. WE have an HM MI cable from the cable box to the TV...
unfortunately cable does not give you the best quality picture and "fuzziness ' is the reduced resolution being displayed on the tv.
the easy way to check the picture quality is to get a decent hd antenna and scan using it for free hdtv signals, if these are also fuzzy, on all channels then the tv has a problem but if it is only on a few lower resolution channels then its just the way it is until everyone is hd 720 or better.
Jan 31, 2010 | Samsung 50 in. Plasma TV
Poor picture (fuzzy ghost image/aura)
well you should check the settings and read menual
Jul 22, 2009 | Panasonic TC-P50G10 Plasma TV
Poor Picture Quality
Todd, In the user menue there has got to be adjustments for the brightness, contrast, sharpness,etc. I know there is no such thing as a simple tv anymore. On some sets if you do not have a remote control, you cannot make any adjustments. If you have one for this set and it works, trust me, the settings are in the on screen menue.
Hope this helps,
Skyassoc
Jun 18, 2009 | RCA L23W10 23 in. LCD Television
TV has fuzzy piture, all colors, but contrast is awful
I think you'd have to look at how much a comparable set would cost. I know that flat screen sets are coming down in price.
One thing you could try is to adjust the focus control although if it just went all of a sudden, then this may not help. There are two controls on the flyback transformer. Follow the thick red wire from the top of the picture tube down to the transformer that it's connected to on the circuit board. There will be two controls, the upper one being focus (marked with an "f" or the word focus). Try adjusting this while watching the picture. A mirror may be helpful. At the same time, be very careful what you touch in there, any metal part could have high voltage on it. As long as you are just touching plastic parts you should be ok. A good rule of thumb is to keep one hand behind your back as you work so as you don't inadvertantly ground yourself to the chassis while touching something with a high voltage on it.
If this scares you a little perhaps it's worth taking the set to a shop for an estimate.
Oct 08, 2008 | Toshiba 32AF42 32" TV
Need settings because of rubbish picture
There is no right or wrong setting for the TV, but I find the following give about the best results:
  • Contrast - 65 maximum
  • Sharpness - 2 maximum
If these are set any higher, the picture becomes very grainy, particularly around defined shapes.
  • Contrast + - OFF
  • NR - ON (If applicable)
These settings will need to be changed for each of the following:
HDMI 1& 2
  • EXT 1, 2 & 3
  • Analogue tuner
  • Digital tuner
The problem you describe, is usually with a satellite or cable box.
Unfortunately, there's nothing much you can do about the dead pixels, but the settings may make them less obvious.
May 01, 2008 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Logiteck quickcam communicate
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Troubleshooting: Image Quality for Cameras trnsp.gif Detailed Description This article covers some standard troubleshooting for issues such as fuzzy, grainy, out-of-focus or off-color camera images. trnsp.gif Answer The information in this article applies to the following software
QuickCam 9.x and below
ImageStudio 7.x and below
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens. This will allow you to focus the camera image on objects at different distances. Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter. For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher. To change the color palette please perform the following steps:
  1. Click on "Start," "Settings," and "Control Panel."
  2. Double-click on the Display icon.
  3. Click on the tab labeled Settings.
  4. In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
  5. Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost." If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software. To do this:
  1. Open the QuickCam software.
  2. At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
  3. Choose "Advanced Camera Settings".
  4. Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
  5. If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
  6. Click OK when your are done.
Mar 05, 2008 | Logitech QuickCam Communicate STX Personal...
Le40m86bdx picture not sharp
I have a two and a half month old Sharp, LC-19SK24U-W. It was fantastic with fantasic, clear, beautifully colored picture until two weeks ago. All of a sudden, the picture starting getting darker and darker. Nothing had been adjusted from day one when I set up contrast, etc. This comes and goes but most of the time is an issue. I can make it a bit lighter but then it is so fuzzy and grainy it is a very poor picture. Also, while this began, one time the television turned itself off and then back on without a power surger or anything.
HELP!
Jan 09, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
