Hi, I left for work this morning and the air con was working fine. Arrived home to find the air con wasn't on. The thermostat on the wall was flashing an L on the screen but the green light was on the honeywell. If I press any of the buttons it doesn't do anything. I've switched it off and back on but still it flashes this L. Could you help me please? many thanks! The thermostat is attached to the wall and doesn't take batteries or not that I can see anyway!
It means that your battery is low and you need to change it. 2 AAA's
Posted on May 27, 2014
2 Suggested Answers
  • 571 Answers
SOURCE: my honeywell thermostat has a flashing message of (bat lo) what does this mean?
Replace the batteries...should be double A's
Posted on Dec 17, 2013
Good morning: I used you trouble shooting web page. Went home and de-iced my fridge freezer. The bottom fan (at the bottom in the back) is working but the fan in the freezer is not going. Does this fan...
HI,
It is possible your fan motor in the freezer has failed and by not moving air into the upper chamber can cause frosting on the back wall of the freezer. Also lack of air movement can cause your air returns to seal shut with ice and still not work if your fan is replaced. The part number your will need is 63001057 for the fan motor itself. I would verify all air ports are open when you replace the fan motor. It not a difficult job, access would take a bit to get into the back wall of the freezer to replace the motor. Amana has been known to use fan delays to pre-chill evaporator before allowing the fan to run, if our model does this, the thermostat in the freezer would need to be checked also. When the thermostat closes, it sends power to the fan motor to run, if it fails, fan does not work. I would check this prior to ordering of replacing the fan.
Kidlmo
Jul 26, 2011 | Amana ATB1832AR Top Freezer Refrigerator
CS /CU-903KR.. had a series of power blackouts and the air con was on. In the morning turned it off but the exterior box was still running (without us knowing) and both the interior and exterior froze......
Power straight a way to out door unit through jammed /struck contactor . When you start power on,power not going to out door by transmission of indoor thermostat calling.
Replace out door contactor.
Jan 05, 2011 | Panasonic Heating & Cooling
1999 chevy cavalier. wasn,t getting heat to inside. put in new thermostat. heated up fine for a couple of miles, then cool air. shut off when got back home. anitfreeze was bubbling back out of reservoir....
make sure you get ALL the air out run it without cap until you see water circulate turn heater to hot NO FAN ABOUT 5 MIN close cap ,see if that works
Nov 29, 2010 | 1999 Chevrolet Cavalier
Wireless network has disappeared.
After resetting it (pressing that inset button with a paperclip or pencil), try connecting to it with a wire (cat5 network patch cable). Login with the default of no username and "admin" password. If that doesn't work, it hasn't been reset yet (unless the manual tells you otherwise). Make sure the wireless is enabled AND that the SSID is set to broadcast, not remain hidden.
Feb 24, 2010 | Linksys WRT54G2 Wireless Router
AC will only work in the early morning. I recently moved into an old home with 2 identical AC units, the one on the west side of my house only works during the early morning and will not respond during the...
If your AC only works when it is cool outside, then you probably have a dirty condenser coil, you're overcharged on refrigerant or the outdoor fan is not running at full speed.
Sep 25, 2009 | GE Zoneline AZ55H07D Air Conditioner
I have year 2000 (Old shape) audi 1.9tdi and the air con has been topped up but is still not working.
You may need to check the thermostat and have your clutch bearing checked for your ac pump.
Jun 01, 2009 | 2000 Audi A4
Heating & Cooling Logo
90 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
