Question about Garden
Where to find diagram of throttle linkage / spring for Craftsman 6.5HP mower 917.376070?
I have a small spring whose exact location I don't know, i.e. where it goes...governor, throttle? It popped off while I was trying to correct a problem with alternating normal- and low idle.
  • Garden Master
  • 2,478 Answers
Hope this helps where to find diagram of throttle linkage / spring - 2785c09c-e985-4f0d-a6f2-4e43122d3214.jpg
Posted on May 06, 2014
panilling9
  • 284 Answers
SOURCE: Throttle doesn't work properly
try sears.com go to parts and enter your mod# from under your seat IE:358. and so on.
Look around for prompts and info for you mower from your entered mod#
Posted on May 25, 2009
smartr10U
  • 1305 Answers
SOURCE: Craftsman mower with 20hp B&S Intek won't start/run
That throttle cable issue sounds like it may be the culprit. the cable housing (the outer casing for the wire throttle cable) may not be anchored correctly. Which may be allowing you to move the throttle without any change at the butterfly control on the carb. make sure the cable housing is anchored at both ends.. by the throttle control and at the carb area.. That may be your problem... hope it is that simple...
K
Posted on Jul 23, 2009
  • 124 Answers
SOURCE: have a craftsman 18.0hp riding lawn mower. Has a
Most likely it is the governor spring but you could have a stiff throttle shaft or a needle that is not closing properly allowing the carb to flow too much fuel into the engine.
Posted on Sep 20, 2009
  • 146 Answers
SOURCE: Craftsman 22hp 7500 zero turn mower 3years old.
Be careful - running ungoverned will quickly destroy the engine. Look at the carburetor throttle lever. There should be two linkages attached -- one from the manual throttle lever, another from the governor. The linkage to the governor is usually a spring. Perhaps that came off or broke, or a foreign object is wedged in there.
Posted on Jul 15, 2010
  • 100 Answers
SOURCE: craftsman ys4500 mower-- starts great and runs ok at low speed but at full throttle sputters and pops and of course loses power
sounds like your choke is not opening up all the way fast easy test,take a sharpe pen and mark priar adjustment on choke cable. next; remove cable from carb,then hold chokeopen start give full throttle{no difference} carb kit
Posted on Oct 25, 2012
I need a diagram or schematic of the carb showing the throttle and choke linkages so I can set my linkage for choke and throttle
U need a service manual unless you know someone who knows what is what. Nest time you will take a picture in advance before you disassemble something.
Jul 18, 2015 | Garden
Throttle linkage diagram for toro 22035
This is the site I use frequently. There is a blowup diagram of the linkage. http://www.partstree.com/parts/?lc=Toro+Consumer&mn=22035
Dec 13, 2014 | Toro Garden
How do you assemble the two springs on a sprint 375 briggs and stratton ?
The ends of both springs hook at the loop of the metal linkage connecting the governor vane and throttle shaft. The other end of the small spring hooks onto a small upright plate approximately 1 inch towards to the front of hooked end of the spring. The longer spring hooks onto a large hole in the throttle plate.
A problem that does occur is the plate becomes bent when the mower us pushed under shrubs. This drops the speed of the mower to a low idle. If this is the case then with a pair of pliers, gently twist that metal plate to obtain a RPM setting of 3,100. Don't be tempted to increase the revs to much or the conrod will break and punch a hole through the engine block.
May 07, 2014 | Craftsman Garden
Throttle linkage & broken ground wires
I suggest you take this to a local shop that repairs garden equipment.
Mar 17, 2017 | Craftsman Garden
Jul 15, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Have a craftsman 18.0hp riding lawn mower. Has a
Sep 20, 2009 | Garden
May 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
May 19, 2009 | Garden
Carb linkage hook up
Hello rebel_auto:
>>Send me the Make, Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you.
However, this File may Help.
**The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and the Other End of this Spring Attaches to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 14, 2009 | Craftsman Garden
Garden Logo
126 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
