Question about Car Audio & Video
I have recently installed a head unit in my 08 tundra when i turn the truck off the unit will not turn back on. everything worked fine until i turned the truck off?
5 Suggested Answers
SOURCE: Jensen VM9311/ UV7i wont turn on!!?
Yo, I've got the perfect solution to your problem. Pull out the head unit from your dash. Then, remove the wiring harness carefully from the unit. Now, push in the yellow power wire (even jiggle it a little) making sure it's tightly snug the small port of the wiring harness. Then, plug the harness back into the unit and try turning it on. I've found that the wires come lose easily on this unit. hit me back up at Darkintel74@aol.com.
Posted on Mar 28, 2008
SOURCE: light problem with x400gbt
You have to un hook the orange dimmer wrie. It's the solid orange wire. I tried to figure this one out for about 3hrs and this is the problem solver.
Posted on Oct 07, 2008
SuperTech-11
  • 1591 Answers
SOURCE: Installed ceiling mount monitor to
Sounds like the colorburst frequency is off.
I don't however have a schematic for this board
However somewhere not too far from that video out will be the circuit that generates the video.
This will usually be a 3.579545 MHz crystal or oscillator.
Close to this crystal will be an adjustment that usually looks like a Phillips screw head (very small though, and encased)
This adjustment will need to be tweaked either clockwise or counterclockwise until the color syncs up.
If you can provide good resolution snaps of the circuit board near the video out, or even better, near the colorburst crystal / oscillator pack then I can probably tell you where the adjustment is.
It's best to get a 12V source (like maybe a PC power supply or battery etc) to run it on a bench while making the adjustment. That way you can adjust til you lose color in both directions, and make your final adjustment as in the middle of where it loses sync in both directions.
Posted on Apr 11, 2011
  • 141 Answers
SOURCE: Today while driving to school i crossed two sets
Sounds like going over the tracks might have knocked a wire lose behind the dash. The only way to know would be to take out your head unit to reveal what's behind it. Make sure all the cables are securely fastened and it should work again.
Posted on May 03, 2011
How to install a toyota 08 tundra door handle on the passenger side?
take the door card off look where the handle is should be ether 3 to 4 ten mil nuts take the nuts off with anything else that is attached the replace and do everything back wards
Oct 12, 2014 | 2007-2013 Toyota Tundra 4-Door Crewmax...
Frigidaire ac unit model number fra065at7 keeps resetting
I'm willing to bet the unit is not draining properly. Be sure it is level or pitched outside and the water is draining. Good luck.
Mar 26, 2017 | Heating & Cooling
1998 chevy s10 Head unit and dash display not working
You may have damaged the instrument cluster. The PCM has to receive a code from the instrument panel to start. Its part of the security system. Beyond checking fuses you are going to have to take it to a qualified mechanic with the proper diagnostic equipment. It sounds like you wired something incorrectly
Jan 18, 2014 | Cars & Trucks
I disconnected my battery in 08 tundra and now it wont idle
disconecting batt resets the computer. now it needs to learn how to set everything to run again. disconnect batt for atleast 60 seconds, re atach, start car it will start and die(dont press gas) do this over and over until it idles (could take up to 10 times). by pressing the gas you make the computer think it is idling to high so it keeps turning down the idle. it will idle fine after reseting computer and starting several times without hitting gas peddle.
Mar 09, 2013 | 2000 Toyota Tundra
On adjusting headlight on 08 tundra does clockwise
clock wise should pull light up. counter clock wise should tilt down
Mar 07, 2010 | 2008 Toyota Tundra
Temp gauge doesn't work
Replace your temperature sending unit. Actually it does matter if it doesnt work. You wont know if it has overheated until it is too late and you have blown a head gasket.
good luck.
Jun 01, 2009 | 2003 Toyota Tundra
1/2 water through shower head 1/2 through tube
patmac make sure the clear hose is a overflow first. then make sure all connections are correct,sounds like an areator problem,some after market shower heads don't come with one you can purchase one at your local plumbing store.
Apr 05, 2009 | Home
Mar 03, 2008 | Jensen VM9510 Car DVD Player
Works sporadically
Sounds like your head unit is on it's way out, you could try cleaning the contacts of the face plate plate with rubbing alchol and a q-tip. Make sure you get both sets of contacts, the face and radio.Because the display is working it's definatly not a power problem, clean those contacts and if still doesn't work invest in a new radio, sorry to bear bad news if it's not the contacts. L8R
Sep 18, 2007 | Alpine CDA-7894 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
