Question about Gard Aquascape Black Waterfall Foam Accessories for Water en, Stream, Pond Use
Water stops flowing
When the water flow stopped, I was advised to pay attention to the reservoir and add water when it was low. That worked for awhile, but yesterday when I added water, the flow stopped while I stood there with the hose! I'm beginning to think my pondless waterfall is more trouble than what I paid for it.
Is this a pump problem? What can I do to fix it without calling the landscaper who installed it?
Problem solved. When all else fails, do the obvious. In this case, check the fuse box. We had blown a fuse. There really ARE dumb questions!
Posted on Jun 23, 2009
Fl0 code
Flo ? for Flow Error?
That would for any number of reasons that the Flow Switch is not sensing enough water flow to trip the sensor/pressure switch or actual true water flow switch.
Heater will not run or heat, if there is not enough water flowing!
The heater will sense this. So, whatever will restrict or stop sufficient water flow is the problem.
  • Dirty filter
  • Closed valves
  • Not enough water in tub or pool - low water level
  • Clogged pump impeller
  • Clogged baskets:
    • at pump or at skimmers
  • Clog / stopped up plumbing line
And finally, you may have a bad flow switch/sensor
Sep 06, 2014 | Jandy Pool & Spa
I had a 2003 buick hyderf rent it keep getting hot chang thevwater pump theomasant still hot what next?
Radiator is stopped up and/or it has dirt & debris preventing air flow through the outside wire venting.
Leave radiator cap off, Start the engine, let it heat up and watch to see if the water is flowing past where the cap fits. If water level drops-add water. If water does not flow/move then the radiator is stopped up. Take the radiator to radiator shop and have a professional flush.
If you have good water movement & it gets hot then the air flow through the outside venting is restricted. You may be able to use your garden water hose with high pressure jet stream & spray all the venting areas that may be clogged with dirt, bugs& debris. In any case DO NOT KEEP THE AUTO RUNNING WHILE DOING THIS.
Another problem may be that one of you hoses could be collapsing and the water will not flow. I advise changing all of your hoses based on the age of your vehicle . End of msg.
Aug 07, 2014 | Cars & Trucks
Eurig B70 empties the entire reservoir when turned on
Buy a saeco you'll never look back
I've had mine for four years and do the cleaning as required
It has pulled 15468 coffees and still going strong
It did cost a pretty Pennie but you get what you pay for
My condolences to your coffee machine
Jan 04, 2014 | Keurig Platinum B70 Coffee Maker
Ice Machine does not have water flowing into reservoir
Have you done all the maintenance on the unit?
http://files2.appliancesconnection.com/attachments/D1292347546.pdf
What is the water pressure that you have? Do you have any filters installed?
Nov 20, 2013 | Kitchenaid KUIC15PLTS 15 Inch Wide 25lb...
Bosch Aquatak Clic 125 running problems - keeps pulsing and unable to reach continuous full pressure - has been working well up to now - water pressure OK
After the machine has stared the wash cycle stop the machine. Check the water level in the sump. It it is below the required fill, the pump will drain the sump, suck air resulting in pulsing.
Add a modest amount of water about a quart or so and try continuing the wash. see if it reduces the pulsing. Continue to add to determine if it is the water level.
If you confirm that the water level is low, depending on the model it usually fills on a timer. If it had been working properly then either the stop valve under the sink has allowed the internal rubber washer to dislodge into the flow path, or the inline filter at the connection to the dishwasher is clogged or the electric solenoid at the washer is failing and not allowing the water to enter at the prescribed amount.
Hope this helps?
Below the stop valve do to the hot water is known to have the rubber seal fail which can plug the hose limiting the water flow. The valve can be repaired without removing it. The stem with the house water off can be removed and a new rubber seal installed. remember to remove the debris from the failed seal.
12215403-owoa52fq3dbvw0lom3ojbzgr-3-0.jpg The screen can clog in the image below restricting the water flow. Disassemble and clean.
Mar 29, 2012 | Dishwashers
How do i remove engine coolant cap on 2001 cadillac dhs
WAIT UNTIL YOUR ENGINE IS COLD,YOUR RADIATOR PRESSURE CAP IS LOCATED ON THE COOLANT OVER FLOW RESERVOIR, THATS WHERE YOU ADD COOLANT WHEN COOLANT LOW,YOU POUR COOLANT IN THE OVER FLOW RESERVOIR UNTIL COOLANT LEVEL REMAIN AT FULL COLD MARK DONT OVER FILL OVER FLOW RESERVOIR, WHEN COOLANT LEVEL STOP DROPPING WHEN ADDING COOLANT AND COOLANT LEVEL STAY AT COLD MARK ON THE RESERVOIR YOU RADIATOR HAS THE CORRECT COOLANT LEVEL IF COOLANT LEVEL KEEP DROPPING CHECK FOR COOLANT LEAKS AROUND RADIATOR AND THE TOP AND BOTTOM RADIATOR HOSES, LOOK FOR COOLANT LEAK AT WATER PUMP GASKET OR SEAL OR LEAK AT WATER PUMP WEEP HOLE IF YES REPLACE WATER PUMP.
Oct 23, 2011 | 2001 Cadillac DeVille
I have Paloma PTG2 42PVN No water flow when I open the faucet. I turn the water heater off at the remote and then back on and I get water flow for about30 seconds and the water is warm, then the whole...
Question is not clear.
Does all water flow stop? Or does hot water flow stop?
Open following links for possible help.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/pdf/No-Error-Code.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
I have a 1hp sta-rite above ground pool pump. The pump model number is MPRA6E-147L The pump is about 4 years old, and during our summers it runs about 12 hours a day (May through September) and during...
It sounds like there was a lack of water to the reservoir, which is, I assume the inlet reservoir with the basket strainer in it.
1. Is your water level in the pool high enough to keep the reservoir full?
2. There is an o-ring or gasket on the reservoir cover, is it there and lubricated so there is no air leakage?
3. Put a garden hose into the open reservoir to see if the pump moves this water out.
Do all of this with the filter set to just go back to the pool so you can see the results.
Try this and comment back.
Good Luck,
Gary
Dec 11, 2010 | Sta Rite Pool & Spa
No cold water
  1. Make sure filter is installed right.
  2. Disconnect water line see if water is flowing from line. May have a water valve in line not working.
  3. reconnect line but leave lose open inline valve just a little see if water flows out. No water PSI may be to low to reach up to fridge or valve stuck closed.
  4. Got water to connection tighten check dispenser for water.
  5. No Water If your system has a reservoir to store & chill water Your float may be stuck locate & check unstick if needed.
  6. Still no water May have faulty dispense value. Check value replace if needed.
Please rate hope this helped. If I can help further I'll standby.
Mar 09, 2009 | Samsung RS2534 Side by Side Refrigerator
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
Gard Aquascape Black Waterfall Foam Accessories for Water en, Stream, Pond Use Logo
135 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
