Question about Samsung Clx 3185 Multifunction Printer Copier Scanner Color Laser
How do I fix Samsung Clx-3185 Fuser
Hi, I am getting paper jams inside the fuser unit. What happens is that the paper just rolls around the fuser instead of coming out the paper tray. Is there anything I should look at to try and fix it. I have removed the unit, cleaned it and put it back and 3 pages later it did it again on me.
    Champion:
  • 411 Answers
The micro "flag" located at the fuser has been broken or dislocated or some gears broken and fuser not spinning.
If you cannot get spares, buy a new printer
Posted on Aug 05, 2014
Fix paper jam 2 on a Samsung CLX-3170 printer
paper jam 2 is a jam in the fuser/exit area.
did the paper jam come out in one piece? if not reassemble the torn paper to see how much is still inside.
sometimes there will be a small fingernail size piece of paper holding open the fuser/exit sensor flag.
sometimes the sensor flag itself is dislodged and needs reassembly.
attached is video in how to dissassemble the printer if required
Sep 24, 2014 | Samsung Office Equipment & Supplies
How do i fix paper jam2
Paper has jammed In the fuser area (open back door to fuser area) or Check Inside around the toner cartridge
Jun 10, 2014 | Samsung CLX-3170FN All-In-One Laser...
Samsung clx 3185 error code u1-2112. turn power off and on but still wont fix the unit
firstly restart the printer, if same error is comimg.
then,
fuser error. replace fuser unit
Oct 26, 2013 | Samsung CLP 315 Laser Printer
Samsung CLX 3185FW. ..paper stuck in fuser unit
I have clx3185 and paper was jamed inside fuser. So. These 4 screws from behind + one screw close to power outlet and then u need to lift up plastic side of printer,start from bottom - will be very hard. If done - remove from main board 2 connectors and release cables to fuser unit
Nov 10, 2012 | SAMSUNG CLX-3185FW COL LASER MFC Projector...
How to resert the counter of the fuser of samsung clx 3185
Do it in Tech mode
Menu # 1 9 3 4 Menu
Navigate through the menus to find the Counters menu, fuser is in there from memory (I reset imaging unit only recently on CLX3185FN but saw fuser in the menu as another option)
Or you can wipe EVERYTHING with "clear all mem" option
Password 1934 worked fine for me
May 03, 2012 | Samsung CLX3185 Printer
I have a Samsung CLX6210FX. I get this error Paper Jam 2 Check Inside. I check the paper tray and the toner door but could not find where the paper jam is. Please help
This can be very difficult to find especially if they are small pieces. If you remove the toner cartridge and with a flashlight look all around for any evidence of paper. Also check thoroughly all the doors that will open and all around the rollers. Lastly and this is difficult is the fuser in the very back of the printer. These rollers are extremely hot and sometimes when the fuser goes bad, it will keep the paper in the fuser causing the jam. On the menu you will probably see error codes as well. Hope this helps.
Mar 19, 2011 | Samsung CLX-6210FX Laser Printer
I have a Samsung CLX-3160FN, and after every page
it is most likely that the fuser actuater arm is not sitting back to the sensor properly. open the back door you will be able to see the fuser, on your right hand side you should be able to see a fliper that sit in between a sensor. try to adjust the fliper flag and see if it works.
if it still continue to give you the same error. try remove the fuser four screw 2 side on each. adjust the flag again and fix it back. it should work and double check for any lose small pices of paper jam in the printer.
May 15, 2010 | Samsung CLX-3160 All-In-One Laser Printer
Display reads paper jam 2 check inside
Open the Top Half of the Copier. The Scanner Section pops open by pushing up.
Underneath the Scanner Section is the Fuser Unit. Check in the Fuser Section, you will find paper Jam in the Fuser Section.
Apr 27, 2010 | Samsung CLX-6210FX Laser Printer
How to remove covers and fuser unit?
Ive got the same problem :( and because i used compatible cartridges, it apparantly voides the warrantly, so staples will not fix it :( so im now stuck with a £260 uselss printer :( good luck getting it fixed.
Sep 28, 2009 | Samsung CLX-3175FN Printer
Samsung Clx 3185 Multifunction Printer Copier Scanner Color Laser Logo
237 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
