Question about SCOSCHE Universal USB Solar Power Car Backup Emergency Battery and Charger for Blackberry Style 9670 Oxford
Where can I find the schematics for an enercell 23-972 universal battery charger
Components in my enercell 23-972 universal battery charger started burning. I opened it and found what I believe to be two burned transistors. The letters on them start with ALJ and end in P 02. The middle numbers/letters are burned on both so they are not completely legible, though they end with 2. Two transistors that are still intact read "ALJ D882 P 02".
Need battery case for flashlight, four AA from Enercell light from Radio shack
fixya doesnt sell products either look on line or call customer service for enercell
Apr 17, 2017 | Radio Shack Camping, Backpacking & Hiking
Enercell battery charger won't charge my battery
these things are not repairable just buy a new one
Oct 19, 2013 | Computers & Internet
Enercell Laptop Battery Charger Doesn't Work When Plugged In?
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery.
hope this helps
Sep 04, 2012 | Computers & Internet
Need adapter/charger
Radio Shack no longer markets a charger/adapter made specifically for the PRO-82, but the 6-volt Enercell AC adapter with a size C Adaptaplug will work with your scanner. Radio Shack total retail for the pair is $30, and you can probably find them on line for even less. You might even luck out and find a compatible 6v wall wart on eBay.
Bill B
Mar 08, 2010 | Radio Shack Pro-82 Scanner
2Wire Power Supply
My 2Wire just died - I did not know because of the adapter or the router.
I went to Radio Shack to buy what Glen Smith suggested. They do not have them -
I bought Enercell 3/5/6/6.5/7/7.5VDC 2A (Serie 2730333) - plus using old Adaptaplug (I took from other Universal AC Adaptor). AND IT WORK !!!
Jun 16, 2008 | 2wire 1800HG Router (RG1800HG00)
Battery donĀ“t work
try to replace new battery charger.
Feb 22, 2008 | Astar Trent PD-3070
SCOSCHE Universal USB Solar Power Car Backup Emergency Battery and Charger for Blackberry Style 9670 Oxford Logo
Top SCOSCHE Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a SCOSCHE Cell Phone Expert? Answer questions, earn points and help others
