Question about Kodak ESP 5 Printer
Kodak ESP 5: Does not print dark, even on -3 setting: Cleaned printhead, added new cartriges??
  • Lynn Bowersox May 06, 2014
    I ended up getting rid of this printer. There was no support from kodak and the problems too numerous.
sajid_najmi
  • 31 Answers
SOURCE: replacing printhead on Kodak ESP 5 Printer
you need to lift printer front access door , take both ink cartridges out,
the carrier (black piece) is called printhead.
When you see carefully at the center , there is a gray latch. you need to "pull it up", it will release the printhead.
MS
Posted on Jun 13, 2009
  • 295 Answers
SOURCE: our kodak esp-3 is printing a blank page with new
go to www.kodak.com/go/printheadsupport.click on 3rd link on how to replace a printhead. then take cartridges out and printhead out, after 1 minute,insert printhead back into the carriage and install both cartridges, go to kodak aio home center on ur desktop and from there on maintenance under help and select printhead cleaning. then try to print.ur problem will be resolved
Posted on Jul 28, 2009
SOURCE: Replaced printhead and ink cartiages on a Kodak ESP.3
I had my esp3 stop printing black also. I bought new cartridges even tho' I knew the ones in the printer were at least half full. Still not printing black. I finally called Kodak support and got a tech who was the first tech from India who could speak English well. He was very helpfull but in the end he told me he would send me the printer head because that was the problem. My printer was not used for about a month and the head dried up. The tech said that printer must be used about twice a week and the best way was to print the test by using the 'Scan' and 'Copy' at the same time. There was no sense telling the tech this is a huge flaw in the printer as he must have been hearing this for a long time. After I received the new printer head it prints fine. This is an absolutely huge flaw in this printer. If they can't make a different style of head for this printer these will stop being used................. So if you have the ESP3 (I don't know about the other models) and don't use it often the head will dry up and you can't clean it (according to the tech I talked to). Kodak should send these free for the life of the machine in my opinion.
Posted on Aug 08, 2009
  • 15 Answers
SOURCE: My Kodak ESP 3 all-in-one printer will not print
you may try to clean the printhead and recalibrate the printer. if this will not correct the problem, you need to replace the printhead. I suggest contacting Kodak technical support to have a replacement printhead.
Posted on Apr 17, 2010
  • 4 Answers
SOURCE: Kodak ESP 3250 won't print black. Changed
I fixed my ESP 3250 print problems by removing the cartridges and print head. Using a Q-tip and warm water, added drops of water to each of the print head ink wells until the water / ink from the wells bled thru onto a cleanex. Did this several times. Dryed the print head fairly well. Then added a drop of water to each cartridge for each color. Reasembled and ran an alignment and to my surprise, it works! I hadn't used my printer in a while, so the ink had dryed on the felt for both the print head and cartridges.......
Posted on Nov 20, 2012
Kodak esp 5 not printing properly and no yellow
Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy.
Dec 17, 2009 | Kodak ESP 5 Printer
Kodak ESP 5 new cartridges color prints fine black will not print. Only have used Kodak replacement cartridges. How can this be fixed.
Try cleaning the printhead.
Press Menu > Select maintenance > Select clean printhead.
If still black does not print, call Kodak tech support, printhead will be replaced free of charge
Nov 22, 2009 | Kodak ESP 5 Printer
PUT IN NEW INK CARTRIDGES BUT COPIES STILL BLANK AND PRINTING EVEN CHANGING ALL SETTINGS
how did the paper exit inot your pritner? Its act like printing or its fast and smooth? If its act like printing you just need to clean the printhead or if cleaning printhead did not solve the issue you need a printhead replacement, Now if the paper exit in your printer fast and smooth you need to replace the printer and the printhead., You need to call kodak for support toll free 1 800 421 6699 ext 05., The troubleshooting may apply also for blank documents using word or any other application.,
Nov 16, 2009 | Kodak ESP 5 Printer
Printer is not printing any blue despite new printheads being added
If you have tried new printheads, I believe you mean new cartridges, then the panel that makes contact with the ink catridge needs to cleaned. you may to confirm that the panel on the ink cartridge that makes contact with that panel inside the printer is very clean. Usually cleaning should be made with tissue/cotton wool and methylated spirit. Improper contact of these panel is the other reason a particular ink will not print.
Sep 09, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3 printer won't work
For that problem kindly try doing the ff:
  • Re-seat the inks both color and black then try printing
  • Re-seat the Printhead of the printer then print again
  • if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Aug 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 printer does not print YELLOW
no,kodak replace printheads free of cost, and if they send a printhead and that doesnt solve issue and in next 30 days,u have same issue,then kodak sends a replacement printer. and esp-3 printers are considered o be in warranty tilll now even if they are 24 months old. kodak is the best.. ur issue will be resolved.dont worry
Jul 23, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
PRINT FADES OMPLEELY OUT EVEN WITH NEW INK CARTRIDGES
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.. do not worry.
Jun 24, 2009 | Kodak ESP 5 Printer
My kodak esp-3 printer is printing with a pink tint to all my pictures. can you help?
open printer access door.remove printhead and cartridges again reseat both of them.. press copy $ cancel for 5 seconds and wait for caliberation sheet to print.. or if u have connected ur desktop, open kodak home center, go 2 maintenance and click on clean printhead. now see if ur documents are printing properly. if not kodak will replace ur printhead.
Jun 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Even with brand new cartridges, the colors aren't even close.
If you go under the printer settings there should be a maintenence file. Try to clean the heads.
Jan 31, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I need to change the printer head on my Kodak 5100 all in one printer
To install the printhead and ink cartridges in the: Additional search terms: print head, tank, replace
Jan 22, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak ESP 5 Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
