How to remove the gear box - Washing Machines
  • 15,935 Answers
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. Remove the water pump. This is a small pump located in the front of the washer directly under the wash tub. It has two hoses leading to it. LEAVE THE DRAIN HOSES IN PLACE and remove the two retaining clips. The front of the clip pops off with a gentle pry of a screwdriver, while the back is in a keyed slot. Once released from the pump, turn the clip to remove from the slot. Pull the pump off the motor shaft and push it aside while leaving the hoses attached.
8. Remove the Drive Motor. Remove the electrical connection(s) first using care not to break any of the wires. Loosen the two 1/4" hex bolts that hold the Drive Motor retaining clips in place. Now, place one hand under the motor and lift gently while prying the top retaining clip with a screwdriver. This will release some of the tension on the clip and make it slightly easier to remove. (WARNING: the motor has some weight to it, so be prepared to support it when you release it). Once the top clip is released, the bottom one should come out fairly easy. The clips are similar to the ones that hold the water pump in place. They are inserted into a keyed slot and are slightly longer.
9. Once the Drive Motor has been removed, the Motor Coupling is directly behind it. There are two plastic three-pronged pieces with a rubber bushing connecting the two. One plastic piece is inserted on the Drive Motor shaft, while the other piece is inserted on the transmission shaft. You may have to use a screwdriver to remove the old pieces. Inspect both halves of the coupling for signs of wear. Replace if necessary (part #285753A).
10. Uninstall the motor mounting plate from the gearcase by removing the two bolts.
11. Remove the agitator by removing the center cap. Locate the center nut under the cap and loosen with a socket and ratchet. Lift both portions of the agitator straight up, exposing the gearcase center shaft. Remove the agitator clip and agitator washer from the shaft. NOTE: If there is a recessed square slot under the agitator cap, use a 3/8 inch to ½ inch socket adapter with extender to remove.
12. Now take the washer and lean it backwards so that you have full access to underside of the washer. Loosen the three bolts holding the gearcase in place. When you get the last bolt, loosen slowly as the gearcase will begin to drop from under the washer. Slide the entire gearcase and shaft out of the washer.
13. Remove the clutch and brake assembly from the top of the gearcase by removing the retaining clip. Do not forget to retain the washer that is under the clutch.
14. Inspect new gearcase assembly. Open the breather hole (covered by a dab of paint) using an awl or similar tool. Install washer on gearcase shaft and install clutch and brake assembly. Slide gearcase shaft up through the agitator shaft from under the washer. Hold in place and get one bolt started. Insert remaining bolts and tighten them all evenly.
15. Insert new coupling by tapping one piece onto the transmission shaft with a hammer. Use a dowel or something solid to tap the center portion of the coupling until the opening of the coupling is flush with the shaft. DO NOT hit the prongs or they will break. Do the same for the Drive Motor. Make sure you place the coupling on the correct side of the motor. If you forget, remember that the electrical connections are on the RIGHT HAND SIDE of the motor and that the coupling goes on the REAR shaft of the motor.
16. Place the rubber bushing over the side of the coupler that is connected to the transmission. Rotate the bushing so one empty hole is facing up and the other two are facing down. Now, rotate the coupler on the motor so the prongs will line up with these holes. It's a little tricky trying to get them to line of sometimes. I usually place the lower retaining clip in its keyed slot so that it is resting on the floor. That way, when you get the motor in place, you can reach down while holding the motor up and snap the lower bracket in. You will still need to support the weight of the motor until you get the top bracket keyed into its slot and snapped back into place.
17. Reinstall electrical connector to the Drive Motor.
18. Reinstall Water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly. Make sure you re-install retaining clips.
19. Re-install agitator washer and retaining clip on the gearcase drive shaft and then re-install agitator. NOTE: DO NOT over-tighten center nut. You can crack or break the agitator.
20. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
21. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
22. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
23. Reinstall console.
It seems like a rather lengthy process, but it is a simple repair if you follow the instructions step-by-step. Read through everything thoroughly before beginning any repairs. I hope this information helpful.
NOTE: Under Line Item 10. - after you remove the motor mounting plate, make sure you disconnect the wiring harness from the the gearcase housing if it is mounted to it. Otherwise, you may damage the harness when you remove the gearcase assembly. Make sure you re-install the wiring harness in the fashion when repairs are completed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
How to take gear box off?
Gear Box Removal:
Drain the gear box oil by removing the drain plug.
Here is the input for the speedometer cable drive. If the gear box is in the frame, you will need a 10 mm wrench to loosen the bolt holding the cable. Back the bolt out until you can pull the speedometer paddle drive free.
If the gear box is on in the frame you will also need to remove the neutral switch wire with a 13 mm wrench and slotted screw driver to keep the adjustment screw from moving.
You can refer to the complete process here: http://myural.com/gearboxremoval&install.htm
China OBD2 car diagnostic tools wholesale on CareUCar
Nov 10, 2014 | Cars & Trucks
How much gearbox fluid do i put in 1997 Mitsubishi Legnum vr4 gear box and in my transfer box?
Manual remove filler plugs from the side of gear box and transfer case pump oil in until the oil runs out that's the correct level.
Sep 16, 2014 | IBM 06F0164 Oiler Belt Motor Gearbox Mfr...
How do you replace the clutch on a 1969 morris minor?
remove the battery lead. remove the drive shaft at the diff flange and remove it from the gear box. undo engine mounts/ cross member at rear of gear box if necessary. undo bell housing bolts around rear of engine. remove gear lever if stick shift . If not remove linkages at gear box Pull gearbox rear wards and lower to the ground . A point of interest here is that when a clutch sudders it is advisable to firstly check all the engine mounts are not soft as this affects the clutch operation especially if you have a cable operated clutch
Jun 20, 2014 | 1969 Morris Minor
Remove gear shift assembly
There will be 4 bolts on top of the gear box that fix the gear selector turret in place . Remove any trim and rubber boots to get to these bolts . undo them and lift the gear lever ass. out of the box.
Mar 23, 2014 | 2007 Ford Freestyle Limited
Steps to Replacing a Clutch on mitsubishi express
for the full steps then get a workshop manual as there are some details that will be missed . Basically it is Remove the battery terminal. remove the rear drive shaft ( front also if 4wd). Remove the gear lever at the tower bolts on the gear box. Drain the gear box or be prepaired for the gear oil to run out the end of the transmission when you pull the box. . Place a bottle jack under the sump at the rear of the engine . Place a trolley jack under the gear box. undo the rear transmission mount cross member Undo all the bell housing bolts. lower the jack and the trolley jack and pull the gear box back. Undo the bolts holding the pressure plate on the flywheel a bit each at a time as you go around the plate . Remove the plate and the clutch plate ( be aware that the clutch plate will only go back in one way so watch the way the clutch hub was facing. Remove and replace the bearing in the back of the crank shaft. clean up the flywheel face ( good idea for a good non shudder job is to have the flywheel re-machined ) fit the clutch plate the right way and fit the pressure plate . Use a clutch aligner tool as it will be impossible to fit the gear box with out it. Replace the clutch throw out bearing. Now re install using the reverse processes As I said a manual shows it all
Dec 14, 2013 | Cars & Trucks
Changing impeller on 90hp v4 johnson 2000
Remove Linkage Under Carburetor
Remove Bolts Securing Gear Box Remove Gear Box
Do Not Turn Shift Linkage
Remove Water Pump Housing
Fit New Impeller
Re Fit Gearbox Follow Procedure In Reverse
Mar 16, 2013 | Boating
How to replace the gear box on a 1997 k1500 4x4 chevy suburban
remove the p/s lines to the gear box, take the nut of the pitman arm and seperate the center link of the pitman arm, remove the front shield, remove three bolts from the side of the frame holding the gear box onto the frame, you will need a puller to remove the pitman arm off the gearbox, reverse procedure to install. add fluid.
Aug 10, 2010 | 1997 Chevrolet Suburban
I installed a new clutch and cant get 5th or reverse.
remove gear stick and check its in properly, if you removed the gear shifter quadrant box bolted to top of gearbox you more than likely put it in while a gear was selected, remove and make sure gear box selectors are all lined up in nuetral then refit quadrant box and then gear lever.
Aug 09, 2010 | 1995 Isuzu Trooper
Replacing gears
you have to disassemble the tool completely. Remove chuck, remove battery, remove all screws holding body parts together, remove one side of body. Now you can see motor and gear box. Pull out both of them and twist gearbox a bit (just few degrees or millimeters) if it goes, then just pull gear away from the motor. Be carefull, some gear parts may drop of, so hold gearbox down and motor up. Juraj
Jun 04, 2010 | Makita 18V 1/2"CRDLS Drill Kit
Gear link or box problem
Sounds like a piece of linkage came loose. If it were an internal tranny problem, doubtful that the stick would be loose. Examine all linkage for something very obvious.
Oct 07, 2009 | 2005 Volkswagen Microbus
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
