Question about Dishwashers
Problem with my Viking DFUD140 dishwasher
A few years ago someone asked" My Viking DFUD140 just stopped working. The control panel is still lit up, but the buttons for the various settings do not respond when pressed, including the start button. Has anyone seen this problem? Is there a way to reset the unit? Please help!" I have the same problem with the same dishwasher. Have reset and turned off breaker, wont work. Odd thing is that if it sits for about a week, it works. Have done this 3 times. Does that give a clue. My only guess is something has to dry out or electronics clear. Trying to assess if this 13 yr old dishwasher is worth fixing or should replace. Any advice appreciated!
    Top Expert:
  • Dishwashers Master
  • 40,304 Answers
There is no economic sense to repairing a 13-year-old dishwasher.
Posted on Apr 06, 2017
2 Suggested Answers
SOURCE: Dishwasher will not start
you can hold the start atop button down for 5 seconds to re set it or you can turn off the circuit breaker to the dishwasher for 20 sec. That should help. If not, it probably is a bad celenoid which a repairman needs to replace
Posted on Nov 19, 2008
Replacing ignitor
That is not really enough to tell us what you need.
We repair a lot of Viking model barbecue grills and stock all the various ignition parts. As Viking changed fabrication strategy the appliances have gotten much better through the years. An electrode purchased today for a Viking will not look the same as the original electrode but the new, longer, double-pronged electrodes work a lot better, are built a lot heavier, last a lot longer and cost less than the originals.
The only difference between the module and electrode and button architecture in a Viking when compared to any other high-end grill is the inner firewall. Between the control panel and the inside firewall inside the grill where the burners connect to the valves, there is a second firewall designed to hold-off heat damage created by certain problems (usually resulting from poor assembly after cleaning). The new Viking electrodes are long and thick but the back-end is also long which makes sure the electrode wires are far away from the heat of the firebox.
Other than that the 9volt module, button and electrodes are no different from any other high-end grill.
We do have exploded schematics of where all the grill parts belong in a Viking so contact us if you want copies of this information.
Jan 25, 2014 | Viking VGBQ410-3RT Grill
Burner will not ignite but electroic spark s are working, sparks will not stop after burner is manualy lit
I have had this same issue with continuous sparking after a burner was lit.
Problem 1. Wet or dirty ignitors/burners. Solution: clean and/or dry (I assume this resolves electrical issues). This has usually solved the problem
Problem 2. Stuck or dirty control switch. Solution: remove knobs and spray electrical-cleaner into switches. AMAZING... no more clicking plus burners now burn hotter when set to HI. I assume this frees-up the movement of the switch to prevent it thinking you are pushing it ON... and thus asking for spark... plus greater range of switch and/or higher flame settings available once lit. A no-cost miracle! ( I used "PureTronics" brand Electrical Contact Cleaner spray can, 1 sec, 2X).
Mike S
Sep 15, 2011 | Viking 37 in. VGSU161 Gas Cooktop
My Viking vgsu cooktop has the igniter go on continuously when I try to turn on 4 of the 6 burners
My Viking stove igniter won't stop clicking. Both igniters on one side are clicking over and over
May 21, 2010 | Cooktops
30" viking downdraft goes up & down fan runs and will not responed when pushing on touch panel
After 11 years of use, the same problem just happen a few days ago - fan keeps running, doesn't respond to the on/off switch. Also cannot reset filter alert. As far as I can tell the entire switch panel isn't working. Or worse, shorted out. Might have to replace the ribbon and some switches.
For example the switches can be found at For example -->
There's a another thread on this forum:
I'll post the exact solution as soon as I have it figured out completely.
Mar 11, 2010 | Viking VIPR101 Kitchen Hood
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
The buttons on the front stopped working, no display
It is still under warrantee if under a year. Contact your dealer who you bought it from-it should be repaired or replaced free of charge.
Oct 03, 2009 | Microwave Ovens
Nov 17, 2008 | Viking 24 in. Professional Series DFUD140...
Failing dash lights and cruise control
Pull the instrument panel connector off at the rear of cluster and look for any damaged connections, clean it and reconnect, that may cure the issue, the cruise problem may be the rotating contact in the steering wheel, it is called the clocksprimng contact because that is what it looks like, changing this part is not for the DIY mechanic, the driver airbag must be dis-armed correctly or serious injury will occur if the bag goes off, the very least it will scare the H... out of you, if you are lucky....
Jul 13, 2008 | 1999 Ford Crown Victoria
Dishwashers Logo
74 people viewed this question
Top Dishwashers Experts
