Question about Lincoln Electric Lincoln Easy MIG 140 Welder 120 Volts 140 Amps
Lincoln hd 140 barely sparks
Haven't used welder in 6 months or so tried sat and it will barely spark any ideas?
  • bryan lawless
    bryan lawless May 06, 2014
    Check the obvious first. Tighten tip in gun, grind off a place for a good ground. Check to make sure your selector swith and rheostats are turning and engaging as they should. If it still doesn't work try a squirt or two of electronic cleaner in the rheostat(arc/puddle control knobs). With the machine unplugged of course! If and only if your comfortable with it take the cover of and look for obvious signs of corrosion, oxidation, condor nest or burnt wires. A 140 amp machine will kill you dead. Unplug it. Avoid touching or safely discharge the capacitors. Good luck. Bryan
    New Friend:
Try switching the a,b,c,d back and forth a couple of times a corrosion builds up and causes a week contact so there isn't enough voltage to work . This has happened to me a couple of times . The first time the fan was running and I had no wire feed action and then a local repair guy told me that corrosion is very common with the portable Lincolns . You shouldn't even have to take it apart to clean it just switch it back and fourth and that does the trick. Good luck.
Posted on May 10, 2014
2 Suggested Answers
luis_david
  • 407 Answers
SOURCE: Where can I get a gas diffuser for a Lincoln
Gas diffusers are sold at any welding store, look up praxair site for your nearest location. The part number you are looking for is: TWE-35-50 about 6.00 bucks or less.
Posted on Jun 14, 2011
Why won't it start?
as with any gasoline engine, you need, fuel, spark & air, take a moment to follow the progression of each of them, you will figure it out: example, test your ignition switch, clean, new fuel, getting spark to the plug? do you have a fuel stop solenoid attached to the carburetor?
Sep 11, 2015 | Lincoln Electric Welding Tools
My lincoln mig 140 feeds the flux wire through, but it just sparks, will not weld
Make sure the ground clamp has a good connection to both the work piece and to the welder Sometimes the welder connection is overlooked.
Jan 13, 2014 | Lincoln Welding Tools
G8000 welder
Check the coil. Make sure the wires going into the coil are "intact". If you have a volt meter check continuity to all the wires going into the coil and out. That's the plug wire. Make sure its not old and broken inside. Also make sure the coil isn't shorted out via a bare wire or the like.
Dec 14, 2013 | Lincoln Electric Welding Tools
I am having weak arc issues and will not weld at any of 5 settings. Any idea what my problem may be?
does the machine buzz a lot louder then usual if so you could have a diode gone on the welding rectifier if not check all connections even if the look good
Oct 26, 2013 | Lincoln Electric Lincoln Easy MIG 140...
I have the lincoln 180 my wire is being fed but not getting any spark any ideas?
First make sure you have a good ground clamp and the line well tight to the machine. This problem is a common one.
Jan 07, 2011 | Lincoln Electric Lincoln Easy MIG 180...
My lincoln 140 welds fine on a low setting but when im welding on a high setting the spark starts out strong but seems to fizzle down and it does not burn in good. Please help MIKE
You may be exceding the duty cycle of your welder
Check your operstors manual to see how long you can weld at higher amps before giving the welder a chance to cool down
Oct 18, 2010 | Miller matic 140 Mig Welding Package W/As...
Lincoln Electric Lincoln Easy MIG 140 Welder  120 Volts 140 Amps Logo
189 people viewed this question
Top Lincoln Electric Welding Tools Experts
oleolson
Level 1 Expert
joe_jochoa
Level 1 Expert
ray gallant
Are you a Lincoln Electric Welding Tool Expert? Answer questions, earn points and help others
