Question about Asrock ConRoe1333-D667 Motherboard
I cant access the internet.
LAN was already activated but no internet access. i tried to install a LAN card. the card was installed and detected but still i've no internet connectioin. i plugged the RJ-45 to other cpu, it works..i think there's something wrong with my motherboard.
  • 1,272 Answers
Check if you are able to ping a website say yahoo.com from the concerned computer.
you may even have to disable firewalls on the computer or assign static IP address.
Posted on Jun 22, 2009
    Sergeant:
  • 220 Answers
If you have the cable plugged to your modem, connect the cable to the pc and then restart the modem.
Also try a reboot and make sure you don't have windows firewall on nor static IP.
Cheers
Windows 10 upgrade on my Laptop shows limited internet , can't get online, any ideas?
Try installing the correct lan and wifi drivers from the computer manufacturer. If there are none available, win10 is not compatible.
Aug 10, 2015 | Computers & Internet
I installed new XP on my comp. and cant get to the internet ... shows that there is connection but cant get in .... and internet explorer say what you can try ... Diagnose Connection Problem ... then it...
hi! I think u need to install drivers in your PCI internet/LAN Card or built-in LAN
Please check the brand of Motherboard if it is built-in or the PCI Card Brand. and browse it in the net with another PC with the NET connection, to the manufacturer websites. and search it with corresponding model of the motherboard or the PCI Card. and download the Driver's and save to USB and paste it to ur PC and install it.
if this tips is helpful. please rate it. thank you.
Feb 21, 2011 | Computers & Internet
Linux 5 is not detecting my broadband modem
The connecting to internet is very easy in linux .
There are many steps but i am saying simple one
Initially configure the adsl router with ppoe over ethernet and enable dhcp address option.
Next plug the ethernet cable from router to the inteface of lan card.
Boot the redhat machine.
In the system-->Administration-->network options check whether lan card is detected and active .
If the lan card is not active activate and save
In lan card select option assign assig ip automatically
check whether ip is assigned by using command ifconfig .
Mar 11, 2010 | Red Hat Enterprise Linux ES Basic Edition
Have 604 router. all of a sudden only two computers can be active through the router and it does not allow the other two to work. things were working fine with all computers getting browser access... now...
On the computers that are not getting Internet access, check the LAN cables to the router. Does the Link LEDs on the router for these computers are ON?
If the LED lights are off then the LAN cable and/or network cards are faulty.
Check Device Manager on these computers to see if the LAN card is working and enabled. If not re-install the LAN drivers. If the driver installation cannot detect the LAN card then most likely the LAN card is faulty and needs replacing.
Get back to me with the results of these tests and I can advise what to do next.
Nov 16, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
My dell lan card is not working,i cannot connect to internet.
Either the LAN card is faulty or the LAN driver is not installed and/or not configured properly or the LAN cable is faulty.
Check Device Manager to see if the LAN driver is installed, working and enabled. If not then re-install the LAN card driver.
If the LAN driver won't install or detect the LAN card then it maybe faulty and needs to be replaced.
Try a different LAN cable.
Is all the LEDs on in the modem?
Try rebooting the modem (power it off for 30 secs and power it up again).
Nov 14, 2009 | Dell Ethernet Card Network Adapter
Installed new motherboard now LAN not found? How to fix
Does the new motherboard have onboard LAN? If not you will need to install an ethernet or wireless card depending on your setup. Hope this helps.
Dec 22, 2008 | E-Machines T6216 (827103077834) PC Desktop
Can u help?
Are you sure that you have internet access activated by your mobile operator? It needs to be activated on their end for you to be able to access the internet.
Apr 12, 2008 | Sony Ericsson K800i Cellular Phone
Cant connect to internet
Hi ianzky, If the PC with the ECS P4VMM2 motherboard is connected to a network with a hub or router check if you can see the other PCs assuming their sharing is turned on. If yes then it is possible that you have to simply set the IP Add, Subnet, specially the Internet gateway and DNS in your IP/Networking configuration of the P4VMM2 PC assuming you want to manually install these numbers and not to Auto Obtain. Just make sure you follow the numbers of the other PCs except for the last digit(s) of the P4VMM2 PC IP Add. If you can not see the other PCs in your network, then it is possible that your lan cable is defective, try checking if the lights in your hub/router and/or at the back of your lan card lits up when you plug your cable both ends. If yes then it is good if not you have to replace your cable. Since you installed a new LAN card, I will assume that you have checked if the drivers are installed in the Device Manager and there are no conflicts or yellow mark(s). Both versions of the ECS P4VMM2 (7.3 & 8.1) have built-in LAN, if you want to continue using the new lan card it might help conserve resources if you disable the built-in lan in your bios or use the original built-in lan instead and reconfigure. In Win XP, try uninstalling the lan in Device Manager, on reboot it will be auto reinstalled and you can manually configure again. If by a remote chance that you are using 98SE, try checking your root file MSDOS.sys and see if there is an entry that say Network=0, change it to 1. I doubt if the motherboard is defective since you already tried installing a new lan card. Good luck. Pls post again how things turn up. Kind regards.
Jul 21, 2007 | EliteGroup P4VMM2 Motherboard
Asrock ConRoe1333-D667 Motherboard Logo
118 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
