Question about Alpine IVA-W505 Car DVD Player
How to set the DVD player - Alpine IVA-W505 Car DVD Player
Hi, i have a portable dvd player & the battery is 2 hours. now it only lasts 30 minutes. is there something i csn do to boost it or do i need a new battery. thank you, medina
Your best bet is simply to replace it with a more reliable battery. However, starting the dvd player without a disc so that the settings appear should allow you to change the options on the DVD player. This should allow for the brightness and picture settings to be adjusted to preserve battery to the best of the DVD players ability.
Step One: Remove Disc
Step Two: Turn On DVD Player
Step Three: Enter Settings
Step Four: Adjust the picture and screen settings to maximize the battery life (make the screen less bright for an example)
There may be a setting specifically meant to maximize battery life. Hope This Helps.
May 13, 2011 | TruTech PVS12701 Portable DVD Player
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
Dvd player causes the tv screen to roll when trying to play a dvd. tv works finf when the player is off
Have you ensured that the dvd player settings are set to pal and that if the disc in use is an ntsc disc that the dvd is set to ouput pal60 or pseudo pal
Dec 29, 2009 | Insignia Televison & Video
Wrong regional disc
Hello mperona,
The reason you are receiving this message is due to the region settings on your dvd player. Dvd players use region settings to allow them to only play dvd's from certain parts of the world. Your dvd player's region settings do not match the region code of the dvd disc.
The only way is to make your dvd player multi region....you will need to post the make and model of your dvd player so I can search for a solution that will work.
Thank you for choosing Fixya!
Jun 14, 2009 | GPX D1816 DVD Player
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD picture rolls vertically
Somehow the TV setting on the DVD player was set to PALS so we changed it to the proper setting.
Dec 15, 2008 | Digix HT1056A DVD
Coby DVD screen setting wrong
check on the cover of the player the info to reset should be there
Oct 26, 2008 | Coby DVD-514 DVD Player
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Alpine IVA-W505 Car DVD Player Logo
66 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
