Question about American Audio VMS 4.1 Pro DJ 4 Channel Midi Controller
Lost american audio vms 4 serial number
Lost the serial number of american audio vms 4
I have a browning 16 gauge. serial number is A8999. was wondering what info you can provide
The "A" prefix serial number on your 16 gauge denotes "American made Browning patent" by the Remington Arms Company. Your shotgun was made between years 1940-1953. The 4 digit number hints to early manufacture dating to 1940-41.
Mar 17, 2016 | Optics
Lost stero code for 1997 acura
Go to https://radio-navicode.honda.com/ Information You Will Need If you dont know the Phone Number and Zip, call American Honda's customer service desk at 1-800-999-1009
Jul 18, 2011 | Car Audio & Video
Ever since I replaced the battery in my '96 Acura tl, the radio/cd playerwon/t play. It displays C0DE:E. Is there a general code?
You have to go to an Acura dealer and they will be able to give you the code when you give them the serial number.
Also keep in mind that Acura is known to put the radio code on a sticker, place in an odd location of your car, such as the trunk, glovebox, etc.
Furthermore, you don't have to remove the head unit in order to find out its serial number. Just follow the instructions below:
RETRIEVING THE AUDIO UNIT SERIAL NUMBER
To reduce warranty and customer costs whenever an anti-theft code is lost, the audio unit’s serial number can be retrieved without having to remove the unit. To recall the serial number, follow these steps:
1. Turn the ignition switch to the accessory (I) position.
2. Turn on the audio unit. Make sure “CODE” appears on the display.
3. Turn off the audio unit.
4. Press and hold the number 1 and number 6 preset buttons at the same time, and then turn on the unit. The serial number will appear in two parts – the first
four digits followed by the last four digits, and then the sequence will repeat.
5. Enter these eight digits into DCS to retrieve the antitheft code.
Aug 05, 2009 | 1996 Acura TL Series
No Cd...No Box...Only the program
Sony is a serious company. If you registered your product then you can easily get your old serial number. Try their support at:
http://esupport.sony.com/
Otherwise, you are practically asking for a cracked Serial and such cannot be posted here.
Asta la vista, baby ;-)
Jun 24, 2009 | Sony American Idol Extreme Music Creator...
Serial Number on Magix Music Maker
hey, here is the best solution for you. if you want to download magix audio cleaning lab 12 with serial no check out the following links
MAGIX AUDIO CLEANING 12 PART-01
MAGIX AUDIO CLEANING 12 PART-02
or if you want to download MAGIX Music Maker 14 Producer Edition with serial, please check out the following link
MAGIX MUSIC MAKER PART-01
MAGIX MUSIC MAKER PART-02
Jan 13, 2009 | Magix Audio Cleaning Lab 2005 for PC
Change number of rings on incoming call before it goes to VMS
Changing the vms hunt delay on a Partner ACS system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#505"
the display should say vms hunt delayand mode:
enter 1 for day mode or 2 for night mode
enter line you want to program in 2 digit format (line 1 =01)
enter number of rings (2)
press feature "00" to logout
hope that helps
Jan 05, 2009 | Comdial Avaya Partner ACS Phone
Lost serial number
You can load it but you need to call the software maker to get the key again!
Oct 07, 2008 | Computers & Internet
SUNHILL
If an audio unit with theft protection is disconnected from electrical power, you must enter a unique code number into the unit or it will not work. This code and the audio unit’s serial number are listed on the anti-theft ID card that comes with the vehicle. If this card is lost, you must obtain the audio unit serial number in order to get the radio code. Some newer vehicles allow you to retrieve the audio unit serial number electronically from the radio. Refer to your owner’s manual for the specific procedure. Some older vehicles (model year 2003 and older) require a visit to the dealer in order to retrieve the audio unit serial number. Once you have the audio unit serial number, you can call Auto Customer Service at (800) 999-1009 or have the dealer look up the radio code.
Aug 07, 2008 | 2004 Honda Civic
Serial NO lost
the serial number for this product is on the bottom of the box that the card came in, also look on the card
15 digit # that starts with12970
Aug 03, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
American Audio VMS 4.1 Pro DJ 4 Channel Midi Controller Logo
95 people viewed this question
Top American Audio Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you an American Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
