SOURCE: Toshiba Satellite 5005-S504 3 USB Ports not functioning
I don't think a wire is the problem as they are soldered to mobo. It is more than likely a power problem. If you go to the hardware tab in device manager and go down to usb root hub>right click and properties then look at the power tab and you will see a 500MA allowance on usage. You can easily go above these if you are using them, so check that they are all active. Also go to control panel>admin tools>services and look down list for 'plug n play' and make sure it is set at automatic and 'universal plug and play' is set at manual
SOURCE: Hi! My touchpad mouse has stopped working in my
While holding the "FN" key, press the "F9" key and that should re enable your touchpad.
SOURCE: can the toshiba satellite L305-s5947 lcd screen be
Yes it can be replaced.All you have to do is to make a call to Toshiba.Please dont go to any local computer shop.
Here is the support number for Toshiba (800) 457-7777
For more help
http://www.ikarmatech.com
SOURCE: I have a toshiba satellite L305 and the wireless
Sounds like a virus or malware....might be, might not be, just on the safe side, go to the link below and download the program MalwareBytes. Let it update when it installs and then it will perfrom a quick scan. When it is finished, click on the "show results" button, delete all that it finds and reboot.
http://www.filehippo.com/download_malwarebytes_anti_malware/
SOURCE: no hdmi port
u can buy USB to HDMI converter cable...just check the manual for ur TV if it supports it also can try AV to HDMI converter cable
